Old 3rd October 2013, 10:11   #20201  |  Link
James Freeman
I've been using ArgyllCMS for quite some time now.
What is the benefits of using madTPG over the built in one?
P.S
Over a long email exchange sending back and forth huge Verbose calibration reports, and receiving new fixed beta versions.
Graeme Gill managed to fix the Black Input Offset problems when calibrating to BT.1886 standard (in fact anything with the -f0 command).
Expect new version soon.
James Freeman is offline   Reply With Quote
Old 3rd October 2013, 17:06   #20202  |  Link
leeperry
Kid for Today
Goodie, so I'll soon be able to use the following?
dispcal -P 0.5,0.5,2,2 -v -yl -t6500 -f0 -G2.4 -qm bla
I can't make the test pattern area too big otherwise those silly Sammy TV's turn off their backlight completely when sent pure black. I'll get into the process of building a 3DLUT out of it later. But mVR can also trigger Argyll now, I wonder if it could do -f0 -G2.4, need to look it up.
Originally Posted by NewmanHD View Post
The best picture settings will prove adequate for a HD7730?
I'm pulling the trigger on a 2GB HD7850, hard to refuse for 110€ shipped with some serious cooling too
It's only barely slower than a 660 so that should be the bee's knees with mVR for quite a while, I'll reconfirm
Old 3rd October 2013, 18:40   #20203  |  Link
madshi
Originally Posted by StephaneM View Post
So you can have madVR added to the graph in the UI thread and have the graph in another thread (preferably with a message pump). Then the only thing you have to do is to place some madVR calls on the main UI thread (well I had to do it only for SetWindowPosition, so I guess that anything that will somehow change properties on the madVR window requires to be called on the UI thread)
All of this might change some time in the future. I might at some point offer a windowless mode, similar to EVR. That should makes things like this a bit less painful. But it will probably be some time before I get to things like that...
Thanks for your reply. Could you give me a link about the post? I can not find.
Sorry, don't have a link. Would have to search myself. Just search for posts of the user name I gave you and look at the last 100 posts or so. There should be something useful there.
Originally Posted by andybkma View Post
Win7 64-bit, with FSE On (using new path, Present Several Frames in Advance checked), HDMI or VGA out to an external monitor or projector, if I put the computer into Sleep (Standby) and then come out of Sleep, the first time (and only the first time) I go into FSE mode I seem to lose graphics output to the external monitor (the monitor goes into sleep mode) for about 3-4 seconds before finally going into FSE. If I use the old FSE path (Present Several Frames in Advance unchecked) then I have this problem when coming out of FSE mode instead of going into. Very odd. This happens only with Sleep, if I reboot the computer I don't have this problem.
Not sure what this is, but it doesn't sound like it's too much of a problem. I don't think madVR has anything to do with this. You could check if games behave the same way. Then you'd have proof that it's not madVR's fault.
Would absolutely love to get a test build with the deband feature. Pretty excited for this one based on what I've read and seen over on the flash3kyuu thread.
Alright, but no guarantees whatsoever:
http://madshi.net/madVRdeband.rar
You can toggle it by pressing Ctrl+Alt+D, or by using the file name tag "deband=low/high". Not available in the settings dialog yet.
FWIW, this test build also has a nice improvement for FSE mode, where rendering times don't decrease, anymore, when the backbuffer queue is full. In older versions a full backbuffer queue somewhat slowed rendering down. Not anymore (only Vista+).
Originally Posted by SHaKOL View Post
i have a problem with .avi files when i choose madVR as the video renderer, like this:
but when i choose enhanced video rendere (custom presenter) works normally
That's a bug in the decoder which just doesn't show with other renderers. Basically the renderer sends the decoder buffers to store decoded frames in. And this specific decoder requires the buffer to contain the contents of the previously decoded frame, only then the image looks correct. madVR works differently, it does not initialize the buffers in any way. And DirectShow does not require it to. I could make the decoder work, but on the cost of quite a bit of raised CPU consumption, so I won't do that. Use a better decoder. Maybe you can get LAV Video Decoder or ffdshow to handle this file instead of the AVI Decompressor.
I need some help regarding external pixel shaders, no matter what I try I fail to apply a shader.
No matter what I do I get 0x80004005 as result...
Do external pixel shaders work when using MPC-HC?
You'll need to have D3D9 installed and updated to the latest version. IIRC it's not installed by default, at least not with all helper dlls etc.
Originally Posted by Duffy Moon View Post
After toggling a few settings, the problem seems to disappear after switching the decoding matrix to BT.601 instead of BT.709, which is what madVR autodetects.
I was getting weird effects in, say Breaking Bad season 3 episode 1, the clouds in the Mexican sky had red blotches.
I don't see how switching between BT.601 and BT.709 could make/fix a blue sky getting red blotches. Sure, switching between BT.601 and BT.709 should change colors a bit. But *not* from blue to red!
(1) madTPG dithers, which helps dispcal accuracy and speed.
(2) You run everything through the same pipeline you later use for video playback. This way there's no potential difference (in colors, levels, whatever) between the test pattern generator pipeline and the video rendering pipeline.
(3) You can run ArgyllCMS on one PC (e.g. your laptop) and madTPG on another (e.g. your HTPC). Such a remote calibration works automatically with madTPG, if you allow the network communication to pass eventual firewalls. With ArgyllCMS' built in test pattern generator you must run ArgyllCMS and the test pattern generator on the same PC, which can be bothersome, depending on your setup.
Cool. How much of an improvement did the fixes bring? Just slightly better? Or is the result near perfect now?
Old 3rd October 2013, 18:51   #20204  |  Link
James Freeman
-f0 -G2.4
Yes, now it will give you BT.1886 without elevating the 0 black step, thus not sacrificing contrast ratio (tested).
As I have already mentioned, I am not a fan of BT.1886 (on my IPS 870:1 monitor).
I can see compression artifacts on black steps 0 to 3 (out of 255), on the purest blu-rays like The Hobbit.
Looks like random noise or squares.
For me BT.1886 is much too aggressive on my Dell U2410 poor Contrast Ratio.
On the other end, The better the monitor contrast ratio, the better and closer BT.1886 calibrated "Flatpanel" will look like a good CRT.
IMO™, anything below 1000:1, stick with Power law + BLC.
Cheers.
Old 3rd October 2013, 18:55   #20205  |  Link
James Freeman
Near Perfect.
The problem was the -f0 raised my native blacks from 0.23 to 0.29 (after calibration) thus destroying the contrast ratio (same with L*).
Now my contrast ratio stays native like the values I see on the "Report Uncalibrated Display" log.
I'll quote one of the mails:
> Can you please explain what did you do to make the calibration more
> accurate,
> for example: tightened the lower 10% dE?
not exactly. There was some code that adjusted the
targets (for purposes that are no longer clear - perhaps to
help convergence on difficult devices ?) that I removed,
as well as weighting the stopping criteria to err on the side
of the luminance being lower than the target rather than
higher for the near black points.
Not to say that I actually understood it, but I'm still very grateful.
Old 3rd October 2013, 20:06   #20206  |  Link
StephaneM
This would be an improvment, though once you know that there is a restriction, it's easy to handle (it can be tricky)
External pixel shaders are working with MPC-HC (well shaders are applied when madVR is used as the renderer)
For now I'm doing test on Windows 8, so I suppose D3D9 is up to date on this platform...
StephaneM is offline   Reply With Quote
Old 3rd October 2013, 21:19   #20207  |  Link
Thunderbolt8
I got a new laptop with a GTX 760m, but I found out that I cannot change the graphics processor to NVIDIA for media player classic, because that option is greyed out (whql 327.23). how can I solve this issue?
edit: managed to change it with nvidia inspector, I had to change the "enable application for Optimus" setting to Value "SHIM_RENDERING_MODE_ENABLE". Now I can change all the sub-settings as well.
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack)
Old 3rd October 2013, 21:40   #20208  |  Link
Thunderbolt8
regarding the nvidia settigs. its been said that leaving everything to default should be recommended. but what about the setting texture filtering quality? shouldnt that affect the image quality of movies as well? its set to high as default/global, but can be set to very high.
does this indeed improve anything? in combination with this trilinear optimization can also set to off for best image quality.
also, something I noticed is that when I use CUVID in LAV Video as Hardware Acceleration, then my GPU and my CPU usage both is lower (according to task manager and nvidia inspector) than when using no hardware acceleration at all. Can this be right? Shouldnt at the GPU load be higher, because the NVIDIA card is being utilized with LAV Video and madvr at the same time then?
Old 3rd October 2013, 22:02   #20209  |  Link
SHaKOL
How do i use LAV Video Decoder or ffdshow instead of the AVI Decompressor? because i opened LAV Video Decoder (formats) and didn't find avi .
SHaKOL is offline   Reply With Quote
Old 3rd October 2013, 23:15   #20210  |  Link
6233638
Debanding is okay, I guess...
(brightened in Photoshop)
Old 4th October 2013, 02:55   #20211  |  Link
Asmodian
Those do not affect MadVR, they are for rendering textures at an angle (like the ground in a 3D game).
CUVID doesn't use the GPU to decode video. It uses the VPU which is a different chip on the card and another sensor in GPU-Z or Nvidia Inspector (I believe it defaults to not displayed in Nvidia Inspector). CUVID will also use memory bandwidth on the video card.
Old 4th October 2013, 05:01   #20212  |  Link
turbojet
Deband works well here with some quick tests is there a way for it to save it's state?
What is F2 save icon when toggling deband?
Speaking of keys ctrl+j conflicts with a hardcoded potplayer key (open webcam), ctrl+alt+j has no conflicts.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
Old 4th October 2013, 06:02   #20213  |  Link
sheppaul
turbojet, you can disable the hotkey in preferences.
sheppaul is offline   Reply With Quote
Old 4th October 2013, 07:33   #20214  |  Link
ryrynz
ryrynz's Avatar
Awesome, I'm pretty impressed with the low setting, it not only smoothes out those strong bands but cleans up smaller areas too, giving an overall impressive smoothing. It cleans up a fair amount of artifacts too,
so definitely worth keeping active even on 10bit content which may not suffer as much from banding but still has encoding artifacts that will be improved with having this enabled.
I find the high setting is a little strong for my tastes, is it worthwhile to implement the improved (more demanding) algorithm option with the low setting as well?
Originally Posted by turbojet View Post
Is there a way for it to save it's state?
Funnily enough this is exactly what you're after. F2 saves the changed state when you press it. As you can can maybe tell it actually doesn't work for deband at this stage, fair enough being a test build.
I too would really like a build where this setting could be saved we'll just have to use the filename tags for now.
Old 4th October 2013, 10:43   #20215  |  Link
madshi
I think with a display with a higher native contrast ratio, you should see the compression artifacts just as well, if your ambient light level allows it. At least that's how I understand BT.1886.
http://www.microsoft.com/en-us/download/details.aspx?id=34429
Avi is the container not the codec. Judging from your screenshot the codec is CRAM. Try simply blocking "AVI Decompressor".
Not sure: Is that irony, or did you really expect better?
Comparable to your favorite f3kdb() settings? Or better/worse?
Well, for good quality content it is probably too strong. But it can be useful for really bad content, especially for Anime. With Anime usually image edges are very sharp while non-edges are usually rather flat. So even in "high" setting there won't be much (if any) detail loss. I could probably even add a "ultra" setting for Anime with even stronger debanding. But I guess "high" should do the trick for most situations already.
The improved algorithm consists of 5 checks instead of 1 check. The "high" setting has all 5 checks in it. The "low" setting still has 4 checks in it. So it's still improved over the original f3kdb() algorithm. But I've removed the 1 check which consumes most of the performance. That cut the rendering time in half. With the test images I can't really see a difference between having this 1 check on/off for the "low" setting, so I believe cutting the rendering times in half is the better solution.
Old 4th October 2013, 11:34   #20216  |  Link
ryrynz
ryrynz's Avatar
I guess it depends on how well this fifth check holds up with stronger settings. The ultra setting would likely get very limited use, I do think the high is strong enough, but if you felt so inclined or other people would prefer an ultra setting I wouldn't mind seeing how well it does.
For the general user I totally agree, do you happen to have any of the test images that included this extra check vs without?
I guess with a GPU upgrade coming soon, I wouldn't mind chucking extra GPU at even a small increase in PQ. Would you entertain me a build with the fifth check enabled on the low setting? I'd understand if you'd dismiss it.. Maybe one that includes the ultra setting too?
BTW your low setting isn't that far off the detail retention of my flash3kyuu settings. It's a bit softer but it does a better job overall.. I can honestly say I'll be moving flash3kyuu out of the Avisynth chain.
I like that a lot because now I can deband 10bit content without dropping down to 8bit. Pretty cool.. I'm going to watch my first MadVR debanded episodes tonight.
Old 4th October 2013, 11:55   #20217  |  Link
GCRaistlin
GCRaistlin's Avatar
As I wrote above, sometimes madVR incorrectly changes or, on the contrary, doesn't change monitor refresh rate. Is it possible to add the possibility to change refresh rate from madVR's tray icon menu manually?
Windows 8.1 x64
Magically yours
Raistlin
GCRaistlin is offline   Reply With Quote
Old 4th October 2013, 12:31   #20218  |  Link
DarkSpace
Uhm, just for your information, dropping down to 8 bit is not necessary, there's Dither Tools for high-bitdepth AviSynth output...
Also, the debanding works well here, but I think I'm getting some kind of spike in rendering times (default: ~14ms, spike ~154ms) every time it is activated from its disabled state or increased from low to high... I suppose that is expected?
Just to be clear, I get maybe 1 or two dropped frames because of this, if at all, and the rendering times do go down again relatively fast, I just want to make sure it's not a bug.
DarkSpace is offline   Reply With Quote
Old 4th October 2013, 12:43   #20219  |  Link
madshi
Yes, see the f3kdb() thread.
Is the whole image softer? Or just certain areas? In the first case it's probably not the debanding itself, but f3kdb() by default adds random grain/noise to the image. For no benefit other than to make the image noisier. I've removed that part from madVR because madVR adds noise for the last dithering step, anyway. If you like the added noise, you could simply switch your display to 7bit instead of 8bit in the madVR device settings. That will increase the amount of noise madVR adds.
I've already replied to your "above" post.
When switching any settings, madVR resets the whole rendering setup which can take a tiny bit of time. Rendering times may spike. But changing debanding settings shouldn't take more time than e.g. changing scaling algorithms.
Old 4th October 2013, 13:08   #20220  |  Link
SHaKOL
hmmm i blocked "AVI Decompressor" and then i played the video it says "cannot render the file" shows this:
