Old 6th February 2008, 08:34   #821  |  Link
LigH
LigH's Avatar
Big Hooray, Donald. With TS support and CLI interface, you made a few milestones towards integration into some automating GUIs.
P.S.: Please check the CLI table in your manual, regarding the description of the pcrPID parameter. I assume it's not another "video stream"?
LigH is offline
Old 6th February 2008, 13:13   #822  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
OK, here's your primitive CLI:
Yippieh, thank you very much!
Deinorius is offline
Old 6th February 2008, 23:06   #823  |  Link
7oby
That is awesome!
Finally I got rid of all this nasty DirectShowFilter stuff and have a fully automatic DVB-S2 HDTV -> PS3 conversion running:
(german only):
http://forum.gleitz.info/showpost.ph...&postcount=221
bg,
7oby
7oby is offline
Old 13th February 2008, 14:46   #824  |  Link
LigH
LigH's Avatar
I tried to open the "wedding shot". Unfortunately, DGAVCDec 1.00a15 could not index it:
Error
reserved picture_structure used (can't determine NumClockTs)
Just for testing, similar issues with a transmuxed *.ts using "tsremux":
Warning
Found NALU w/ forbidden_bit set, bit error? Let's try...
Hit Yes to continue with further DGAVCIndex error/warning popups, hit No to disable them.
Hitting "No" here makes DGAVCIndex crash (with "Send report to MS?"). With "Yes" there are lots of more errors, you can try yourself (didn't want to bloat this reply; if you need, ask me for them).
Opening the raw stream demuxed using "tsremux" works well.
LigH is offline
Old 13th February 2008, 15:25   #825  |  Link
M2TS support is broken. I'll fix it in the next version, which will also have audio demux. Thank you for providing this test stream.
Guest is offline
Old 13th February 2008, 15:46   #826  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Don't forget about audio delay Thanks!
Atak_Snajpera is offline
Old 13th February 2008, 18:40   #827  |  Link
What do you mean by that? Is there some particular design that you are hoping for?
As it happens, I am experimenting in this area. At first I will release a version with no solution just to get feedback on my demuxing code. Meanwhile I'll continue my experiments and follow up with another version with some solution.
BTW, the M2TS bug is fixed and I'm just regression testing and testing all the transport streams with audio that I can find before giving you a new version.
Guest is offline
Old 13th February 2008, 19:53   #828  |  Link
Atak_Snajpera
Let's say some noob didn't cut TS files on Keyframes. Then he tries to encode file but after that he realizes that audio is out of sync. Some badly cut samples should be still available on x264.nl In Dgindex you store audio delay in file name so you could use the same method or cut audio according to keyframe. It's up to you.
Old 14th February 2008, 21:26   #829  |  Link
Need some sample transport streams with DTS and LPCM audio
I'm about to release a version with audio demuxing. I have the following supported:
MPEG audio
AAC ADTS (not LATM/LOAS yet)
AC3
I can add DTS and LPCM if needed, but I need test streams for that. So does anybody have any transport streams with AVC video and audio in a format not listed above? If so, please make the streams available so I can add support for them. Thank you.
Guest is offline
Old 14th February 2008, 22:46   #830  |  Link
Atak_Snajpera
http://www.mediafire.com/?ezyxmgmioss - m2ts with DTS
http://www.mediafire.com/?bzojtnioymt - ts with DTS , and 3 AC3
Old 15th February 2008, 02:03   #831  |  Link
But are you sure about the first one? Everything I have says there is no audio in that stream.
Guest is offline
Old 15th February 2008, 02:53   #832  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
does AC3 include EAC3?
check is offline
Old 15th February 2008, 03:21   #833  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
I can hear it when I playback in nero.
ChronoCross is offline
Old 15th February 2008, 03:47   #834  |  Link
Maybe. Do you have a test stream for me?
Guest is offline
Old 15th February 2008, 10:46   #835  |  Link
Flaarn
I think neuron2 may have some "fun" with the audio delay if he decides to implement it, my own experience with broadcast streams that have demuxed so far has always required some manual syncing as none of the demuxers seem to give identical output and what something like pts calc gives as the offset, and what the output is from the demuxer dont always marry up, what I mean here is a lot dont seem to output from what many folks would regard as a valid startpoint hence the need for some manual intervention.
Something I would like clarified if possible the switches between 2.0/5.1 do they throw a spanner in the works or not, some of the information I've come across suggests it's a change in bitrate ie 192/384 etc, that can cause an issue rather than the amount of channels but i've also come across information that suggests different, in any case I've found one size does not fit all so far.
Something that actually gets it right would be great.
Flaarn is offline
Old 15th February 2008, 23:55   #836  |  Link
It's using another "undocumented" stream type: 0x82. So I added code to interpret that as DTS and it is working now.
This is the last call for TS streams before the first release with demuxing. I now support MPA, AAC, AC3, and DTS. I can try to add EAC3 (which may work already; I've no test stream) and LPCM. If you want something supported, send me a link to a stream.
BTW, the new design allows for demuxing all audio streams at once, instead of having to demux each PID separately (as in DGIndex).
Guest is offline
Old 16th February 2008, 00:20   #837  |  Link
Atak_Snajpera
File was muxed with TSMuxer I just wanted to make sure that your app will also support files muxed with this tool.
How did you solve problem with correct audio delay? For example xport cuts audio stream according to first key frame , DGindex stores delay value in filename...
Old 16th February 2008, 00:41   #838  |  Link
Unearthly
Encoder in Training
Unearthly's Avatar
http://www.mediafire.com/?5n0czjmvxtg - m2ts with stereo LPCM.
Unearthly is offline
Old 16th February 2008, 01:02   #839  |  Link
I hope the author is following the appropriate specifications.
I haven't decided yet. The first version just starts outputing audio at the first audio frame header following the first decodable frame. Video starts at the first decodable frame. So they're likely to be close. Let me know how it works.
@Unearthly
Thank you for the test stream.
Guest is offline
Old 17th February 2008, 01:58   #840  |  Link
Southstorm
20yr Videographer
@neuron2
Just wanted to say thankyou for some excellent programs.
They make life that much simpler!
Southstorm is offline
