Old 28th March 2013, 13:08   #61  |  Link
Jenyok
Warm and fuzzy
There are some functions in PhotoShop
"Menu -> Flter -> Sharpen ->
...Sharpen
...Sharpen Edge
...Sharpen More
...Smart Sharpen
...Unsharp Mask"
Question.
Which functions and scripts in AviSynth are corresponded (~equal) to functions in PhotoShop ?
See text upper.
Warm and fuzzy (white and fluffy)
Jenyok is offline   Reply With Quote
Old 22nd December 2014, 03:54   #62  |  Link
gildardo
A couple of questions
I've been fiddling with the settings of this filter --- great one, by the way, so thank you Didée --- but I have to ask, what is the equation implemented by it? I'm playing with lstr and pstr and though I see some changes, I have no exact idea as to what I'm changing exactly. Also, I am not sure that what the exact effect of ldmp is mathematically --- I can SEE an effect, I'm just not sure what it is that I'm seeing.
Last edited by gildardo; 22nd December 2014 at 04:55. Reason: Correcting punctuation to clarify
gildardo is offline   Reply With Quote
Old 24th November 2019, 09:21   #63  |  Link
Magik Mark
Is it now compatible with 2160p hdr sources?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 12th April 2020, 16:19   #64  |  Link
real.finder
try with this https://github.com/realfinder/AVS-St...FineSharp.avsi
See My Avisynth Stuff
Old 18th February 2021, 03:03   #65  |  Link
WorBry
I've been testing various denoiser and sharpener combinations for post-processing of 1080p60 Cineform (Filmscan 2) avi exports graded in DaVinci Resolve. Unfortunately, NR is only available in the Studio version of Resolve and I'm using the free version. Denoising before importing into Resolve would mean transcoding the native clips (HD-AVC.mp4), which is a PITA.
Testing KNLMeans with Finesharp there is definitely some benefit in a 10-bit pipeline (p210) even if the final target is 8bit 4:2:0 - I'm seeing less sharpened residual noise than when processing in YV12.
Typical script:
LWLibavVideoSource("{Path}:\Cineform_export.avi", fpsnum=60000, fpsden=1001,format="YUV422P10")
KNLMeansCL(h=1.5)
Finesharp(sstr=3.0)
ConvertBits(8)
ConverttoYV12(interlaced=false)
KLNMeans in combination with CAS gives quite nice results (clean any way), but that's not really the kind of adaptive sharpening I'm looking for.
Are there other AVISynth sharpeners with HBD support to test?
Edit: Oh, I see LSFMod was ported for HBD also.
https://forum.doom9.org/showthread.p...05#post1813105
That's good to know. Haven't been on the forum for a good while.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
