Old 17th April 2020, 18:58   #1  |  Link
tugatomsk9
tugatomsk9
50fps HEVC with VHS video
I have a ton of home recorded and edited motorsports videos on VHS that I'd like to capture. It will have to be done with composite cables and a MAGIX pen because at the moment I can't afford either a better PC or a better video capture device... (all PCI and PCIe slots are in use).
My goal is to produce QTGMC deinterlaced 50fps at approximately 576p (probably less due to some slight cropping needed) with an average video bitrate of 800-1000 kbps.
I've heard that HEVC is extremely useful at low bitrates, so I was thinking of using the "very slow" preset given the high framerate. Is it overkill? Should I also use 10bit for the banding?
Or is HEVC not all that's cracked up to be and I should just go with 8bit x264 at a higher bitrate?
tugatomsk9 is offline   Reply With Quote
Old 17th April 2020, 19:25   #2  |  Link
Sharc
I don't know what a MAGIX pen is an what it does. Is it a capture HW/SW package with an on-the-fly encoder?
First of all you should capture your VHS tapes lossless using HUFFYUV, Lagarith or UTVideo codec. Composite video is not the best choice as it is prone to producing dotcrawl and rainbows, but I understand you have no other choice.
Once you have succeeded with the lossless capture (no dropped frames, etc) you can view the captured video and only then decide on next steps like cropping, denoising, deinterlacing/bobbing. You have to do some test encodes using x264 (AVC) or x265 (HEVC) and see what CRF or bitrate gives the desired quality level. Finally, one needs to mux video and audio in a container format of your choice.
The first step is very crucial though. If the VHS capture is flawed it is nearly impossible to recover any losses at a later stage.
Old 17th April 2020, 19:52   #3  |  Link
tugatomsk9
tugatomsk9
https://www.magix.com/int/video-editor/vhs/
It is bundled with a below-average capture software and a proprietary video codec that did not please me at all.
Yes, I did plan to capture using Huffyuv of Lagarith from the start.
My doubts about which encoder to use arised from my PC being very old and low-spec: intel i3-2100, intel HD graphics card...
Is S-Video a better option even though it's still VHS? I do own a Sony RDR-HX710 DVD video recorder, but I wanted to avoid recording using mpeg2 before reencoding to x264/x265. The Sony does have S-Video line in and line out, though. Is there any benefit from using the Sony as a pass-through between the VHS VCR and the USB capture drive using S-Video?
EDIT: BTW, the VCR in question is a Panasonic NV-FJ623 Hifi Stereo with 6 heads bought in 2003 and operating in good conditions.
Old 17th April 2020, 20:13   #4  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Regarding s-video vs composite, it depends heavily on the quality of the comb filter.
VHS is a composite format, period. Splitting it into separate luma + chroma requires a comb filter, and it either happens on the player when you're making S-Video, or on your capture card.
Old laserdisc players for example had shitty comb filters by today's standards, so with a pro capture card you'll get much better results with composite. Not sure if that's the case with your basic capture device Try it both ways and see which method produces less dot crawl.
Regarding compression, HEVC is a good fit for this if you don't mind spending the compute. Use 10 bit. With an i3 doing the encoding I'd say it's overkill though
Why do you want the bit budget to be so low? You're using QTGMC so presumably you do care about the quality! I'd have transparent quality be a top priority. Just use low CRF encoding with x265 or x264.
Old 17th April 2020, 20:37   #5  |  Link
RanmaCanada
x265 is really not advisable for SD content. You will get far better results with x264. As Sharc says, try to use Huffy lossless for your capture. VHS is a noisy medium, and you will need to keep as much of the original footage as possible.
Old 17th April 2020, 21:39   #6  |  Link
benwaggoner
Yeah, on a low spec machine, the quality @ perf of x265 might not be that much better than x264, since you might be able to run x264 in slower and x265 at medium for the same total encode time.
Ben Waggoner
My Compression Book
Old 17th April 2020, 21:51   #7  |  Link
tugatomsk9
tugatomsk9
Both produce dot crawl. :\ At least now I know the cause of it.
I know there are avisynth filters for dot crawl, it's just that I've never been a big fan of the usage of avisynth; some of its filters are rather complicated to set up. But I guess I'll have to give it a try.
Oh, the values were more of an example. I was aiming for 230MB for a 25min 50fps video, for example. The main reason is hard drive constraits. Hard drives are not that cheap in my country - the coronavirus ins't helping at all - and I've been unemployed for quite some time, so I was trying to be as filesize efficient as possible. Being unemployed also prevents me from bying a modern, up to date PC with a proper video capture card that I've been wanting for years...
There's something I forgot to mention: the recordings are mostly second or even third generation recording using two VCRs at the time for the editing. There are some which are first generation, but they're not the norm, sadly. Also sad is that my father never owned a S-VHS video, which would have been ideal for such edits. But what is done is done. :/ I know there isn't much to retain, but I do want to retain the original smoothness of high speed sports such as motorsports, which is why I wanted to double the framerate and not let the video bitrate go through the roof.
Old 17th April 2020, 21:59   #8  |  Link
tugatomsk9
tugatomsk9
I did ponder to use x265 at the "very slow" preset despite the looooooong encoding time due to my old i3... But it's not set on stone.
What I was going for is that how much am I gaining with HEVC versus x264 with SD footage using the same preset and settings, like "very slow": is it worth it or is it just peanuts?
Old 17th April 2020, 22:11   #9  |  Link
Sharc
I would suggest to stick to x264 in your case. But why don't you just try and judge yourself?
As I said, start with the critical lossless capturing process with your setup. The subsequent encoding (apart from filtering) is almost peanuts IMHO.
If you have problems with the lossless capturing use your DVD recorder and set it for the best mpeg-2 quality (highest bitrate) and leave as is. Only if file size really matters reencode to AVC (x264).
Old 17th April 2020, 22:26   #10  |  Link
tugatomsk9
tugatomsk9
As I said, start with the critical lossless capturing process with your setup. The subsequent encoding is almost peanuts IMHO.
Oh, absolutely, I'll capture lossless.
I had the feeling x264 would be the more sensible option given my hardware, but I wanted to sort things out once and for all about this. Thanks, guys. If I had a proper computer, though, I'd go all out with HEVC.
BTW, would it be of any help if I uploaded an excerpt to youtube and show you what it's going to be like 70% of the time? It'd be from the only DVD I burned with my Sony recorder, the portion of the original VHS recording that no longer exists.
Check out my youtube page at https://www.youtube.com/user/tugatomsk/
Old 17th April 2020, 22:33   #11  |  Link
tugatomsk9
tugatomsk9
Filesize is always an issue to me - I have many, many hours of tape to transfer -, so I'd always reenconde it to x264/HEVC.
I also considered using the Sony recorded as a video capture device. There's even a HQ+ option which raises the video bitrate to 15Mbps, outside the original MPEG2 norm. But even if I were to burn it to a DVD+RW and rip it on my computer, the burn itself would have to be an MPEG2 reencode itself due to a limitation imposed by Sony, which is a shame.
But even if I recorded in standar HQ (1h), HSP (1,5h) or even SP (2h) and fill the Sony's 160GB harddrive, I'd still have to burn my DVD+RW a massive number of time. It's a very long and boring process... (Of course, if there was a way to extract the original mpeg2 videos onto my PC, especially if they were HQ+, I'd be all over it.)
Not to mention that I was under the impression that mpeg2 was in itself a poor codec compression-wise?
Old 17th April 2020, 22:37   #12  |  Link
Sharc
BTW, would it be of any help if I uploaded an excerpt to youtube ….
Youtube reencodes again. Hence it is not apropriate to judge quality. Upload a few seconds to a filehoster which keeps your original format intact. But I would just guess that your DVD recorded video is blocky …..
Edit:
I had a quick glance to your MAGIX converter and I would assume that it supports lossless capturing with a codec of your choice (Huffyuv). So that's the way to proceed.
Old 17th April 2020, 23:09   #13  |  Link
tugatomsk9
tugatomsk9
Edit:
Righto.
Old 20th April 2020, 02:12   #14  |  Link
benwaggoner
For compute-constrained encodes, using --preset slower --limit-sao 3 will give you most of what HEVC is capable of.
Ben Waggoner
My Compression Book
Old 22nd April 2020, 08:28   #15  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
If you really do want to scrape the bottom of the bit budget, x265 will always be better than x264, and likewise AV1 will always be better than x265 -- when compute time is no obstacle. But if your electricity is metered, it would probably be a lot cheaper to buy an extra terabyte or two and not go that route. At the fairly reasonable 1 megabit for SD video, the only reason to go with x265 would be if you edited and cleaned it to the point that banding will matter and built-in 10-bit will be meaningful. But if you're trying to keep closer to what a raw VHS capture actually looks like, even with some basic filtering, 8-bit x264 will still do plenty of justice at an extremely fast speed.
Old 22nd April 2020, 19:28   #16  |  Link
benwaggoner
Well, AV1 is a bitstream and x265 is an encoder; comparing x265 would be versus a specfic AV1 encoder. While various assertions have been made about AV1 being "20% more efficient" than HEVC, most of those claims fall apart when subjective comparisons are made between an optimally-tuned x265 and an optimally-tuned libaom or rav1e. The 20% number was comparing mean PSNR at a fixed QP without any rate control, dynamic frame type selection, and a bunch of other constraints typical of reference encoders but far from how anyone actually encodes video for people to watch.
Ben Waggoner
My Compression Book
Old 22nd April 2020, 19:40   #17  |  Link
Stereodude
...At the fairly reasonable 1 megabit for SD video, the only reason to go with x265 would be if you edited and cleaned it to the point that banding will matter and built-in 10-bit will be meaningful. But if you're trying to keep closer to what a raw VHS capture actually looks like, even with some basic filtering, 8-bit x264 will still do plenty of justice at an extremely fast speed.
There's always 10-bit x264 also.
Stereodude is offline   Reply With Quote
Old 23rd April 2020, 23:59   #18  |  Link
benwaggoner
Alas, supported on fewer devices than HEVC 10-bit, particularly mobile.
Ben Waggoner
My Compression Book
Old 24th April 2020, 15:44   #19  |  Link
Stereodude
For hardware decoding, yes. But it's SD resolution, so software decoding shouldn't be an issue.
Old 24th April 2020, 16:29   #20  |  Link
benwaggoner
Really depends on the playback platform and players being used.
Ben Waggoner
My Compression Book
50fps, hevc, vhs, x264, x265
