5th August 2009, 05:30 | #82 | Link |
likes to tinker
Thankyou for this marvelous tool, neuron2. May I ask if the GPU does deblocking (eg of interlaced sources) and if so whether you are considering it as a new feature at some point ?
Also, am I right in understanding that it only resizes non-interlaced sources or sources where deinterlacing is specified; ie it does not (yet?) resize interlaced sources ? Last edited by halsboss; 5th August 2009 at 05:38. |
5th August 2009, 12:18 | #83 | Link |
Resizing works. Though it's slightly slower than avisynth's bilinear resizer.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
5th August 2009, 14:40 | #84 | Link | ||
5th August 2009, 14:41 | #85 | Link |
Are you sure about that? How are you testing that? Nvidia told me it is essentially free. If what you say is true, then there is no point to having this feature. I'll make some tests today.
5th August 2009, 16:31 | #86 | Link | |
I downsized the KingKong.mkv (VC1) to 1280x720p from 1920x1080p. It was 60fps with Nvidia and 62fps with avisynths bilinear resizer. Then again, I'm using a less expensive 8400 GS and my PC is a quad-core QX6850 with a 1300mhz bus. I only bought the card for cheap just to use your program since my other one was a 6200. I also tried mpeg-2 clips. Sometimes avisynth and nvidia were the same or avisynth was at 94fps and Nvidia at 91fps. Difference isn't that big.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. Last edited by Revgen; 5th August 2009 at 16:36. |
5th August 2009, 16:35 | #87 | Link |
You didn't tell me how you measured the fps!
I did a test by making the script and adding assumefps(2000) at the end and then playing it in VirtualDub and measuring the time taken to play it completely. For the one test I did on an 8500 I got this: GPU resize: 53 seconds bilinearresize(): 82 seconds |
5th August 2009, 16:37 | #88 | Link |
^Like I said before, I have a very fast CPU combined with a low-end card. It may just be my circumstances. I used virtualdub.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. Last edited by Revgen; 5th August 2009 at 16:39. |
5th August 2009, 16:39 | #90 | Link |
^Virtualdub.
5th August 2009, 17:01 | #92 | Link |
Okay, just tried the assumefps thing.
Nvidia was 55fps 1 min 20 secs Avisynth was 63fps. 1 min 10 secs Basically, it's even worse when I do that. Keep in the mind the difference between your card and mine Yours: http://www.nvidia.com/object/geforce_8500.html Miine: http://www.nvidia.com/object/geforce_8400.html The memory bandwith is about half what yours has. NVidia script Code:
dgsource("King Kong.dgv",resize_w=1280,resize_h=720) assumefps(2000) Code:
dgsource("King Kong.dgv") bilinearresize(1280,720) assumefps(2000)
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. Last edited by Revgen; 6th August 2009 at 00:55. |
5th August 2009, 19:42 | #94 | Link |
Dont know if this is a bug or not (you tell me). If I create a *.dga file, load it up in my avs script. just 2 lines (loadplugin and dgsource) and then start a encoding in x264 (2pass mode). When its encoding (doing 1 pass) I start the avs file in medieplayer classic the image will shutter alot (properly because the gpu is using all its power), but when I close medieplayer classic, my encoding will hang (x264 process goes to 0% cpu) and its not possible to restart the encoding because the CUVIDServer just freeze. DONT try to exit it using the right click on tray icon (you will have to reboot your computer to make it work again, kill it in task manager). Can anyone reproduce all of this ?
5th August 2009, 19:50 | #96 | Link |
I just found it, accessing any other AVS file that uses DGDecodeNV.dll doing encoding will kill the CUVIDServer, will multiple instance be allowed or maybe something that will prevent it from freezing, if more then one instance try to access it ?
6th August 2009, 00:34 | #99 | Link | |
likes to tinker
Darn. Oh well, thanks.
edit1: already asked and answered here http://forum.doom9.org/showthread.ph...41#post1110741 Code:
AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave() '-> TFF AssumeBFF().SeparateFields().SelectEvery(4, 0, 3).Weave() '-> BFF AssumeTFF().SeparateFields().SelectEvery(4, 1, 2).Weave() '-> BFF AssumeBFF().SeparateFields().SelectEvery(4, 1, 2).Weave() '-> TFF Last edited by halsboss; 6th August 2009 at 01:17. |
