Old 13th July 2009, 14:23   #61  |  Link
St Devious
Hardware Aspirin
nice tool.
Would it be possible to make the x264 version user replaceable ? like MeGUI
St Devious is offline   Reply With Quote
Old 13th July 2009, 15:09   #62  |  Link
komisar
komisar's Avatar
St Devious, replace x264.exe or x264_x64.exe with your version.
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 13th July 2009, 15:17   #63  |  Link
St Devious
Hardware Aspirin
oh alright. I thought the x264 exe was included in the program exe like lame encoder i his LameXp software.
Old 15th July 2009, 08:47   #64  |  Link
JnZ
JnZ's Avatar
Nice tool, I noticed from 30fps (x264 32bit) to 33fps (yourtool) speedup, can You update to the latest x264 build commandline (no --progress param), or put some option screen to configure hidden parameters?
Anyway for nice GUI
(Sorry for my bad english, I'm czech, not englishman... :))
JnZ is offline   Reply With Quote
Old 15th July 2009, 14:46   #65  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
LoRd_MuldeR, can you update benchmark to support lattest version of x264? (--progress option trouble)
Done
The package has been updated to x264 r1181 (JEEB's builds) and the GUI reflects the new Preset/Tuning/Profile system now.
Also the GUI will work on 32-Bit OS now, but all 64-Bit features will be disabled for obvious reasons.
Last but not least there is a first attempt to implement automated 2-Pass. After some initial testing it seems to work as expected...
[EDIT]
A minor update is available now. Download link has been updated.
Old 15th July 2009, 19:38   #66  |  Link
LoRd_MuldeR
Software Developer
Yet another small update. Fixed a few minor glitches and added a "help screen" for x264 parameters. Download link updated.
Old 16th July 2009, 01:27   #67  |  Link
St Devious
Hardware Aspirin
any chance of adding horizontal scrolling in the window ?
and adding an option of using 32-bit or 64-bit x264 ?
and report the time taken to encode the first pass and second pass ?
Old 16th July 2009, 03:00   #68  |  Link
LoRd_MuldeR
Software Developer
Nope.
Why would you want to use (the slower) 32-Bit x264 and a 64-Bit system, if you have a chance to use the 64-Bit one?
Well, a report could be displayed after 2-Pass, just like after the Benchmark...
Old 16th July 2009, 03:22   #69  |  Link
St Devious
Hardware Aspirin
Originally Posted by LoRd_MuldeR View Post
Nope.
Why would that be ?
just for kicks to benchmark 32-bit against 64-bit
that would be great. anyways, it displays
encoded 3179 frames, 37.69 fps, 5764.39 kb/s
at the end. So if i were to calculate time taken manually, frames/fps ?
also getting this
Old 16th July 2009, 11:48   #70  |  Link
LoRd_MuldeR
Software Developer
Why would that be ?
The "List Box" control doesn't work like that and I don't intend to replace it.
(BTW: You can see the entire line simply by holding the mouse course above the line for a few seconds)
What do you think the "Benchmark" button does?
also getting this
...because "--8x8dct" doesn't exist any longer. Just as the message indicates
8x8dct is enabled by default now! If you want to disable 8x8dct, then you must pass "--no-8x8dct".
Otherwise you don't need to do anything...
(BTW: Please click "Show Help Screen" for detailed information about x264 commandline parameters)
Old 16th July 2009, 12:24   #71  |  Link
LoRd_MuldeR
Software Developer
Done. Download link updated.
Old 16th July 2009, 15:31   #72  |  Link
St Devious
Hardware Aspirin
actually in my case, i was encoding with ultrafast preset which has --no-8x8dct. I wanted to enable that and it gave me this error message
also is it possible to type in the input and output file box instead of having to browse around the PC ?
was that only done for 2 pass ? i don't see it for ABR mode
Old 16th July 2009, 22:33   #73  |  Link
LoRd_MuldeR
Software Developer
If you don't want ultra fast settings, don't use the "ultrafast" profile
We don't need a report for ABR, because ABR has only one single encoding pass and the info is in the encoding window.
(In contrast to 2-Pass the encoding window won't close automatically after an ABR encode)
Old 16th July 2009, 22:52   #74  |  Link
St Devious
Hardware Aspirin
I wanted to use that specific option with ultrafast presets.
Could you please leave the prompt in there, but let it be the user's choice to put the parameter in there after that or remove it ?
also, the x264 report in the end displays
Old 16th July 2009, 23:12   #75  |  Link
LoRd_MuldeR
Software Developer
Then instead of using "--preset ultrafast" you will have to specify every option manually.
You can specify all the option that the "ultrafast" preset includes, but simply leave out the "--no-8x8dct" parameter
I certainly won't allow the user to specify a parameter that doesn't exist in x264 r1177 and later
If I did, the results would be x264 aborting with "unknown option" error...
Old 16th July 2009, 23:21   #76  |  Link
St Devious
Hardware Aspirin
Alright, I'll do that. thanks
isn't --8x8dct a default parameter in x264 now , http://forum.doom9.org/showthread.php?t=148148 ?
Also please answer the "calculate time taken manually, frames/fps ?"
Old 16th July 2009, 23:37   #77  |  Link
LoRd_MuldeR
Software Developer
That's exactly the reason why "--8x8dct" doesn't exist as an option anymore. There is no need for an option that just sets the default value
You can only disable what is enabled by default. And that's what "--no-8x8dct" is good for.
In other words: Unless you explicitly set the "--no-8x8dct" parameter (or a preset that includes it), 8x8 vs. 4x4 Transform Adaptivity will be enabled.
<frame count> / <average fps> = <encoding time>
Old 17th July 2009, 17:26   #78  |  Link
St Devious
Hardware Aspirin
Would it be possible to add a "No preset" option in the presets drop down box, so that the program uses x264 default options.
Old 19th July 2009, 22:48   #79  |  Link
LoRd_MuldeR
Software Developer
It's already on the list
Please see:
http://git.videolan.org/gitweb.cgi?p...667bea608c6dee
else if( !strcasecmp( optarg, "medium" ) )
    /* Default is medium */
Old 20th July 2009, 00:51   #80  |  Link
St Devious
Hardware Aspirin
Please see:
don't know what that is , looks like a c program.
What does "Default is medium" mean ?
