Old 9th June 2005, 11:33   #21  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Originally Posted by psme
Edit: sorry, just saw others are already running Decomb with MT but seems not much performance gain...
Ummm... I really wouldn't use MT with plugins that make important decisions by analyzing the whole image - if you're unlucky, you get one half of the image deinterlaced and the other weaved, or one halfs is matched forward and one matched backward, or one half is considered video and the other film etc...
Leak is offline   Reply With Quote
Old 10th June 2005, 06:56   #22  |  Link
mg262
Clouded
mg262's Avatar
Originally Posted by tsp
Also found a bug? in pixiedust. When using dynamic_cast Pixiedust throws __non_rtti_object exception. And it always complaines about "First-chance exception at 0x015327e2 in virtualdubmod.exe: 0xC000001D: Illegal Instruction" in the debugview.
I believe you can't call the dust filters more than once in a script, which your filter presumably implicitly does... one workaround is to load the DLL twice and use the DLLName_FilterName syntax.
mg262 is offline   Reply With Quote
Old 10th June 2005, 17:18   #23  |  Link
tsp
tsp's Avatar
yes that explains why it produces garbage but it doesn't explain why it crash when the dll is loaded the first time when dynamic_cast is used because at that time the constructor is not called yet so there is no way dust knows it is called many times. It's really a shame such a good filter is programmed so "bad" (and the source code is not available).
You're right about that. If/when I succeed in making avisynth.dll threadsafe I will try to make an option to process two or more frames in parallel. So such filters can be used.
tsp is offline   Reply With Quote
Old 14th June 2005, 00:01   #24  |  Link
tsp
tsp's Avatar
new version ready that includes a custom build of avisynth 2.56 that should speed this filter up.
Old 14th June 2005, 02:17   #25  |  Link
psme
Thanks for the great filter. Will try it tonight.
Will it speed up Didee's LimitedSharpen? I use it for realtime DVD playback using Avisynth in FFDShow. LimitedSharpen uses up most of my P4 3G Northwood and I can only do good flag 24fps 480p NTSC DVD. 25fps 576p PAL DVD gets stutter with 100% CPU. I'll get a dual core CPU if the filter help.
Thanks in advance.
regards,
Li On
psme is offline   Reply With Quote
Old 14th June 2005, 03:24   #26  |  Link
hartford
hartford's Avatar
Sorry for the late update; had problems.
Test was done reading from one drive and writing to another.
System is a Gigabyte GA-7DPXDWP, modified xp2400+ processors,
Tekram U160 SCSI Adaptor, Maxtor 73GB and 147GB u360 drives.
Test avi is an analog capture at 640x480.
Script:
lloadplugin("d:\plugins\DeComb521.dll")
#loadplugin("d:\plugins\MT_0.10.dll")
#loadplugin("d:\plugins\MT_0.29.1.dll")
loadplugin("d:\plugins\MT_0.30.dll")
loadplugin("d:\plugins\TBilateral-096.dll")
Avisource("d:\test-mt.avi").ConvertToYV12
Telecide(order=1,Post=0,Guide=1)
Decimate(Cycle=5,Mode=0,Quality=3)
#TBilateral(diameterL=3,diameterC=3,sDevL=2.0,sDevC=2.0,iDevL=6.0,iDevC=7.0,d2=true,gui=false)
mt("TBilateral(diameterL=3,diameterC=3,sDevL=2.0,sDevC=2.0,iDevL=6.0,iDevC=7.0,d2=true,gui=false)")
No MT = 522 seconds
MT 0.10 =
An out-of-bounds memory access (access violation) occurred in module 'TBilateral-096'.
MT 0.29.1 = 410 seconds
MT 0.30 = 534 seconds
hartford is offline   Reply With Quote
Old 14th June 2005, 03:26   #27  |  Link
hartford
hartford's Avatar
@tsp
Can't download v0.40
Old 14th June 2005, 07:48   #28  |  Link
tsp
tsp's Avatar
sorry I uploaded it compresssed as a rar file instead of zip but that should be fixed now.
hartford: thanks for the test. I did fear that version 0.30 would be slower than without mt but when using version 0.40 and the custom avisynth.dll the version should be more like version 0.10 just without the crashing
psme: It should be able to speed Limitsharpen up if you use version 0.40 and your cpu utilization isn't 100%. I don't know how well MT will work with hyperthreading but please try and report back.
Old 15th June 2005, 00:25   #29  |  Link
Shadowfax3000
Wow, 100% CPU load. This plugin is sweet! Before it I could only get CCE to use 50% of my CPU's power with the filters I'm using. I'm using a Pentium 4 3GHz Northwood (Hyperthreading). I'm using this crazy series of filters called TimeDenoise that makes it take days to encode a movie. Before this plugin I was only able to achieve a speed of 0.046 (about 72 hours to finish). Now I have 0.053 and climbing (41 hours to finish). Will shave 31 hours off the encode, can't complain about that.
Shadowfax3000 is offline   Reply With Quote
Old 15th June 2005, 13:39   #30  |  Link
tsp
tsp's Avatar
Shadowfax3000: that is impresive. I didn't think HT would make such a big difference. Wonder what a dualcore Pentium 4 EE would do.
psme: I did a little test on my dual celeron 400 MHz and using MT speed limitedsharpen up by ~12%(version 0.40) to 35%(version 0.41) using the default setting.
[Edit]
I just released version 0.41 it might be faster than version 0.40 at least it is on my computer but please try it and report back if it is slower or faster
Old 16th June 2005, 11:08   #31  |  Link
psme
Thanks tsp! I may get a DFI 865PE-TAG board $90 (the only 865 with dual core support) and a Pentium D 820 $250 in the weekend.
I once had a BP6 with 2 Celeron 500M too!
regards,
Li On
Old 17th June 2005, 05:35   #32  |  Link
Shadowfax3000
No improvement for hyperthreading it seems like. After 20 minutes of encoding the speed reached 0.057 for both v.0.40 and v.0.41. Through testing I've noticed CCE 2.50 is faster with a Pentium 4 than any later version. I've tried 2.67 and 2.70, neither are as fast as 2.50. People have been saying that later versions are faster with the P4, I think they might be wrong. Or it's because of the filters and plugins I'm using. Anyways, I'll be on the look-out for new versions of this plugin, so consider me your hyperthreading man.
Old 21st June 2005, 02:31   #33  |  Link
hartford
hartford's Avatar
Script and test avi the same as before.
Huffy Compression; read one drive, write to another
Audio included
Tests run back-to-back.
No MT: 539 seconds CPU time: 54%
MT 0.10 431 seconds CPU time: 65% to 74%
MT 0.41: 540 seconds CPU time: 54%
MT 0.41-1 with special build avisynth.dll
541 seconds CPU time: 50% to 58%
MT v0.10 isn't stable, but worked this time. It will error on loading
or it will work for the test.
If I have time, I will test on a longer capture (28000-30000 frames, or about 20 min)
Slight differences probably due to read drive being a bit full (slower read on inner tracks).
[Edit:] Clarification: Differences from June 13 test.
Old 21st June 2005, 14:56   #34  |  Link
tsp
tsp's Avatar
hartford: did you use avisynthTS=true when you tested MT 0.41 with the custom avisynth.dll and also if you have the time could you test version 0.40 with the custom avisynth.dll and avisynthTS=true compaired to version 0.41.
Sligtly off-topic but try take a look at my dual processor test computer:
here and
here
Old 23rd June 2005, 04:37   #35  |  Link
hartford
hartford's Avatar
No. I wasn't aware of that, um, toggle?
I'll do that if you can tell me where to put "avisynthTS=true"
Interesting machine that you have there
[edit]
I need to report an error that I have using the custom DLL with this script:
vid=Avisource("01-Girl2.avi").converttorgb32()
logo=AVISource("d:\masks\mask-TVpg1-2.avi").ConvertToRGB32
vid2=vid.bilinearResize(147,110)
masklogo=mask(vid2,logo)
Layer(vid,logo,"mul",128,69,40)
I get an "undefined" access error from AviSynth. The script works ok with 2.55
[/edit]
Ok, I found "avisynthTS" explination in version 0.41.
Will report soonest.
Old 23rd June 2005, 21:37   #36  |  Link
tsp
tsp's Avatar
ups forgot a & in the code. Will fix that.
I'm working on integrating MT in the sourcecode so that's why there hasn't been a new version yet.
Old 24th June 2005, 16:05   #37  |  Link
hartford
hartford's Avatar
Same script as above except added "AvisynthTS=true".
No MT = 519 seconds
MT v0.40a = 422 seconds
Old 24th June 2005, 16:24   #38  |  Link
tsp
tsp's Avatar
and MT 0.41 with AvisynthTS=true?
Old 25th June 2005, 04:23   #39  |  Link
hartford
hartford's Avatar
No Mt 519 seconds
MT v0.41 415 seconds
Old 29th June 2005, 03:16   #40  |  Link
hartford
hartford's Avatar
@TSP
Is this near release?
