Old 8th May 2018, 20:46   #201  |  Link
OK, something like this maybe (Just change config stuff to play with it).
LoadPlugin("<path>\PointSize_x64.dll") ## FIX THIS PATH
## ADD SOURCE HERE (RGB32, 256x224)
#AviSource("...")
###   CONFIG   ###
## (256x224 -> 2820x2160)
LQx_ARG  = 4     ## retains some jaggies (best for 'digital' look)
xBRZ_ARG = 4     ## softer gradients (best for 'smooth' look)
SPL_W    = 1024   ## Spline16
SPL_H    = 896
GAU_W    = 5760   # Gauss
GAU_H    = 4320
GAU_PX   = 37.5
GAU_PY   = 12.5
BIC_W    = 2820   # BiCubic (Output)
BIC_H    = 2160
### END CONFIG ###
LQx(LQx_ARG)      # Uncomment 1 or NONE [EDIT: Changed 'Both' to 'NONE']
#xBRZ(xBRZ_ARG)
ConvertToYV12(matrix="Rec709")
## (other filters here -- try QTGMC for example)
Spline16Resize(SPL_W, SPL_H)
nnedi3_rpow2(rfactor=2, nsize=0, nns=2, qual=1, etype=0, pscrn=2, threads=0, opt=0, fapprox=0)
GaussResize2(GAU_W, GAU_H, px=GAU_PX, py=GAU_PY)
BiCubicResize(BIC_W,BIC_H)
return Last
function GaussResize2(clip C, int target_width, int target_height,
\   float "src_left", float "src_top", float "src_width", float "src_height",
\   float "px", float "py")
    px = Default(px, 30.0)
    py = Default(py, px)
    R = C.GaussResize(target_width, C.Height,
    \         src_left, 0, src_width, 0, px)
    \    .GaussResize(target_width, target_height,
    \         0, src_top, 0, src_height, py)
    return R
EDIT: changed RED stuff.
Old 8th May 2018, 22:12   #202  |  Link
SuperLumberjack
French Registered User
SuperLumberjack's Avatar
Thanks StainlessS !
I will try tomorrow at the afternoon, because I haven't enough time any more. I work tomorrow ! Ouch !
But I have just enough time, to show you my pictures and my new scripts
Original (8:7 AR)
https://media.joomeo.com/original/5aed00897c55c.png
Upscaled to 2160p (8:7 AR)
https://media.joomeo.com/original/5af20e33ccff4.png
AviSource()
Spline16Resize(512, 448)
GaussResize2(2468, 2160, px=200/3, py=200/3)
return Last
px = Default(px, 50.0)) # I used 50.0 instead of raffriff42 default of 30.0
return R
Original (8:7 AR)
https://media.joomeo.com/original/5aed019458739.png
Upscaled to 2160p (4:3 AR)
https://media.joomeo.com/original/5af20e689b51a.png
AviSource()
GaussResize2(2820, 2160, px=200/3, py=200/3)
return Last
return R
Original (4:3 AR)
https://media.joomeo.com/original/5aed021e59505.png
https://media.joomeo.com/original/5af20e92c6351.png
AviSource()
Spline16Resize(1280, 960)
ConvertToRGB24
GaussResize2(2880, 2160, px=100/3, py=100/3)
return Last
return R
Original (4:3 AR)
https://media.joomeo.com/original/5aed02f0db60c.png
Note : Here, the aspect ratio is wrong if we compare with other videos from the Legacy of Kain saga (for the connoisseurs ) and the aspect ratio in-game. There shouldn't be black bars. So I just had to cut the black bars to have the correct AR.
Upscaled to 2160p (16:9 AR)
https://media.joomeo.com/original/5af20eea87ccd.png
AviSource()
Crop(0, 80, 0, -80)
Spline16Resize(1280, 640)
ConvertToRGB24
GaussResize2(3840, 2160, px=100/3, py=100/3)
return Last
return R
I know, finally, I put the same value to the px and py for the GaussResize2 So I could use the simple GaussResize. But I noticed a little difference when I zoomed the picture, between :
and
GaussResize(3840, 2160, p=100/3)
And finally, I prefer the GaussResize that raffriff42 did !
Ok. Have a nice night tonight !
And
SuperLumberjack is offline   Reply With Quote
Old 8th May 2018, 23:35   #203  |  Link
Oops, sorry, changed stuff in red in my prev post (was untested, online scripting only).
Still untested, sitting in pub.
Old 9th May 2018, 02:32   #204  |  Link
Imagination, not possible.
EDIT: By the way, 100/3 is 33 (integer divide) not 33.33333, use eg 1.0/3 or 1/3.0, or 1.0/3.0.
Old 9th May 2018, 15:45   #205  |  Link
SuperLumberjack
Sitting in a pub ? You are forgiven !
But there are differences ! See by yourself
https://media.joomeo.com/original/5af305d36883e.png
https://media.joomeo.com/original/5af3064138cf8.png
GaussResize(3840, 2160, p=100/3) (zoom 1600%)
https://media.joomeo.com/original/5af3067d7a24c.png
GaussResize2(3840, 2160, px=100/3, py=100/3) (zoom 1600%)
https://media.joomeo.com/original/5af306a96cff1.png
GaussResize(3840, 2160, p=100/3) (zoom 3200%)
https://media.joomeo.com/original/5af306dbd4be8.png
GaussResize2(3840, 2160, px=100/3, py=100/3) (zoom 3200%)
https://media.joomeo.com/original/5af30708778cf.png
GaussResize vs. GaussResize2 (zoom 3200%)
https://media.joomeo.com/original/5af3072e72a52.png
So, there are little differences between this :
and this :
return Last
return R
Maybe it's because I changed this ?
So it never uses decimals ?
Old 9th May 2018, 17:57   #206  |  Link
Should not really do that, if comparing with eg a RaffRiff42 example then may cause confusion as your function will act differently to his,
if 30.0 is official default, then really should keep that and use your pref as calling arg.
100 is an integer and so is 3, so 100/3 is 33 not 33.33333, an integer multiplied by or divided by or added to, subtracted from another integer, has an integer result. [EDIT: any fractional part discarded/truncated, NOT rounded]
An integer + a float (and all other above operations too) has a Float result. (The integer is converted to a float prior to the operation).
Above is true for many programming languages.
The difference between RaffRiff GaussResize2 and GaussResize may be down to the order of resize, Width, Height, or Height, Width.
Raffs does resize width and then resize height, think builtin resize chooses the longest side (or shortest, not sure offhand which) side first, and then the other.
Old 9th May 2018, 18:29   #207  |  Link
SuperLumberjack
Oki. Thank you for your explanations ! It's always a pleasure to learn from you
Otherwise, I tried the "HQx" and the "LQx" resizers, and I feel that the perfect resizer would be something in between. Sad !
Old 10th May 2018, 01:22   #208  |  Link
SuperLumberjack
Hello !
I updated my scripts a little bit
It's almost identical, but it's better when I zoom !
I just changed these lines :
nnedi3_rpow2(rfactor=2, nsize=0, nns=2, qual=1, etype=0, pscrn=4, threads=0, opt=0, fapprox=0)
I compared with screenshots, and I found it's more natural visually with "pscrn=4"
GaussResize2(4936, 4320, px=50, py=50)
BicubicResize(2468, 2160)
I still upsize 2 times and then reduce with the final resolution.
I put the original value.
Voilà !
Original (8:7 AR)
https://media.joomeo.com/original/5af38ab2ab3f0.png
AviSource()
return Last
return R
Original (8:7 AR)
https://media.joomeo.com/original/5af38afa516b3.png
AviSource()
GaussResize2(5640, 4320, px=50, py=50)
BicubicResize(2820, 2160)
return Last
return R
Original (4:3 AR)
https://media.joomeo.com/original/5af38b407e38d.png
AviSource()
ConvertToRGB24
GaussResize2(5760, 4320, px=50, py=50)
BicubicResize(2880, 2160)
return Last
return R
Original (4:3 AR)
https://media.joomeo.com/original/5af38b84c2020.png
AviSource()
Crop(0, 80, 0, -80)
ConvertToRGB24
GaussResize2(7680, 4320, px=50, py=50)
BicubicResize(3840, 2160)
return Last
return R
Bonne nuit now !
Old 10th May 2018, 12:21   #209  |  Link
Perhaps you might like to add this, ie as your own defaulting to 50.0
Function GaussResizeSL(clip C, int target_width, int target_height,
        \ float "px", float "py") {
    px = Default(px, 50.0)  # SLJ default instead of RR42 default of 30.0
    Return GaussResize2(C,target_width,target_height,src_left,src_top,src_width,src_height,px,py)
Call the new function, you still need to raff42 version.
If posting some example, either include your own stub (as well as original) or modify caller to use original func with your modified px arg (avoids confusion).
Old 10th May 2018, 12:36   #210  |  Link
SuperLumberjack
Yes, you are right ! Thanks for the advice !
I edited my posts.
Old 10th May 2018, 21:19   #211  |  Link
SuperLumberjack
Is there a way to have the EPBX scaling algorithm in AviSynth ?
Old 10th May 2018, 21:58   #212  |  Link
SuperLumberjack
No, in fact I'm happy with my last script !
I don't think I could do better. It's pleasant to my eyes !
Old 12th May 2018, 12:53   #213  |  Link
SuperLumberjack
Hello buddies
I come back to you, because I thought about one thing... an important thing !
As some of you know, Higan is the perpect emulator, close to the original experience of the Super Nes, but on the modern display
But I asked myself, how they did to reproduce the original colors, which are darker. Is it simply a way to imitate the feeling of the old CRT display ? I think yes and no... maybe !
I thought one thing : my pictures are in RGB 24 bits, so the levels are 0-255.
But at the time of the CRT display, maybe it was meant to be display in a equivalent of RGB 16-235.
No ?
I tried this, and in fact, my image was close to the image of Higan, even if not exactly (maybe the gamma).
After some other researches, I read that the gamma of the CRT was close to 2.5 too if we compare to the gamma of 2,22 on a modern display.
So I convert the gamma of the image too
Actually :
1 / 0,45 = 2,2222222222222222222222222222222
So I calculated :
2,5 / (1 / 0,45) = 1,125
So, I used this function to transform my gamma and my levels :
Levels(16, 1.125, 235, 0, 255)
And really, it's closer of what I remember of my experience on a CRT display !
Just for the example, the picture of Mr. Nutz with the spider, I remember how it was dark on my CRT screen when I was a child. It really was a dark atmosphere, the moon was very present, like almost the only comforting glow...
By the way, I was always surprised to see that it's so clear on my LCDs with an emulator
As you will see, it's not so bad... I hope !
I change this too :
nnedi3_rpow2(rfactor=2, nsize=0, nns=2, qual=1, etype=0, pscrn=3, threads=0, opt=0, fapprox=0)
With "pscrn=3" instead of 4, I noticed that it's closer that what I remember. And yes, I can see the difference !
I compare in zooming with the original picture of Killer Instinct and a the picture of the same game in a video of the Super NT (a real Super Nintendo HD, not an emulator), and it's closer now !
With "pscrn=2" and "pscrn=4", there was something weird. It didn't perfectly match !
Old 12th May 2018, 12:54   #214  |  Link
SuperLumberjack
Just to compare :
Higan
https://media.joomeo.com/original/5af6c5501a3d1.png
Super NT :
https://media.joomeo.com/original/5af6c5feba931.png
YouTube video : Episode 1 | First Time Beating Donkey Kong Country | Super NT
My script (with levels changed)
https://media.joomeo.com/original/5af6c70a49172.png
My script (without change of levels)
https://media.joomeo.com/original/5af6c79919a95.png
Higan
https://media.joomeo.com/original/5af6ca69e7656.png
Super NT :
https://media.joomeo.com/original/5af6caa61ff98.png
Analogue Super NT - Donkey Kong Country 2 (No Scanlines) 02-22-2018
https://media.joomeo.com/original/5af6cae2304f4.png
https://media.joomeo.com/original/5af6cb11444d0.png
Higan
https://media.joomeo.com/original/5af6cb6b68280.png
Super NT :
https://media.joomeo.com/original/5af6cb98de4b4.png
Analogue Super NT - Killer Instinct (Hybrid Scanlines) 02-23-2018
https://media.joomeo.com/original/5af6cbc1a8c0f.png
https://media.joomeo.com/original/5af6cc28a3095.png
What do you think ?
Here are some videos about the Super NT il you are interested :
DF Retro: Analogue Super Nt Review - a 21st Century SNES!
Super NT Console vs. SNES Classic & OG Super Nintendo - Graphics Comparison
Old 12th May 2018, 12:55   #215  |  Link
SuperLumberjack
And now, the picture of my last scripts :
Original (8:7 AR)
https://media.joomeo.com/original/5af6d35020a92.png
AviSource()
return Last
return R
Original (8:7 AR)
https://media.joomeo.com/original/5af6d37e35ba5.png
AviSource()
return Last
return R
Original (4:3 AR)
https://media.joomeo.com/original/5af6d3a82231a.png
AviSource()
ConvertToRGB24
return Last
return R
Original (4:3 AR)
https://media.joomeo.com/original/5af6d3dbd5f1f.png
AviSource()
Crop(0, 80, 0, -80)
ConvertToRGB24
return Last
return R
So ? What is your opinion about all of that please ?
Old 12th May 2018, 13:56   #216  |  Link
SuperLumberjack
I just checked one more time if there is a logic with the levels and the gamma, and without a doubt, whatever you think, in all modesty, I think I'm right
There is a balance ! I checked with the levels filter of VirtualDub.
I just changed a bit to see "14-237" in input, "15-236", "17-234"... and with the gradations, it perfectly match with "16-236".
I adjusted the gamma without watching the value. I reduced the gamma , I increased the gamma, I saw the dark tones becoming brighter, the light tones becoming darker... and I felt a balance ! Believe me or not, but I was on "1.123" for the gamma !
So "1.125", perfect ! I admit that I'm surprised, because the gamma of the CRT screens wasn't perfectly linear if I'm not wrong ! But it works !
I think it's even better than Higan or the Super NT, not like the old experience maybe on CRT, but more precise digitally (but maybe I'm wrong and it's only my own interpretation, I don't know) ! Always in all modesty...
But for the picture itself, you are the judges !
Old 12th May 2018, 20:22   #217  |  Link
SuperLumberjack
Finally, even if it works, I'm not sure of what I did...
I need some explanations !
I read that the RGB 16-235 was created to prevent clipping which could cause some artefacts and other defaults.
So, what is the signal that transit in a RGB scart ?
YCbCr signal ? Full RGB ? Limited RGB ?
This picture seams to show that it can be Full RGB :
Because if we compare with all the other pictures...
Higan
Super NT :
... there are all the informations of the pictures !
So why the 16-235 levels exist to prevent defaults of the image, if here, it seams that we have Full RGB ?
I don't understand !
Or maybe, the Raw image in RGB from the Super Nes is converted in a Limited RGB or YUV signal ?
So, there is no clipping in the extreme blacks and whites, but mapping of the "RGB 0-255" to "RGB 16-235" or "YUV 4:2:0" (with Rec.601 color matrix I think) !
Can you explain to me please ?
And for the gamma, if I understand, I didn't need to convert it ?
And so, what is the good way to display the image like it was on a CRT TV ?
Thanks for your help ! I'm so confused now !
Old 12th May 2018, 20:50   #218  |  Link
creaothceann
(why do people record a video game, indeed why do people play games is a mystery to me )
https://www.youtube.com/watch?v=KS7hkwbKmBM
creaothceann is offline   Reply With Quote
Old 12th May 2018, 21:30   #219  |  Link
Totally unbelievable.
Old 13th May 2018, 02:18   #220  |  Link
SuperLumberjack
It's weird !
This is "Mr. Nutz" with the Higan emulator, without the "Colors" filter (so, the default colors of the game with the raw picture) :
https://media.joomeo.com/original/5af78c0030bd9.png
And here is the game with the "Colors" filter activated (in the "Settings" and "Video emulation" sections) :
https://media.joomeo.com/original/5af78e096ba09.png
I understand now that it's more that only a levels adjustement or brightness/contrast adjustement.
But nothing is logical !
First, with this picture of "Donkey Kong Country", it's darker with the Higan and the Super NT picture :
Higan
Super NT :
But with this picture of "Donkey Kong Country 2", we notice, that some parts of the picture are lighter, with more details (see in the left-bottom corner) with the Super NT compared to Higan or my script :
Higan
Super NT :
There is no logic ! Can you explain to me please ?
