Old 7th March 2014, 16:56   #24441  |  Link
James Freeman
Wowee!!!
Looks very good.
It's very useful for folks with 6bit+FRC (and lower) panels to be 100% sure they get perfect gamma curve that visually matches the original content.
One of the fellows here even uses 5-bit for their projector... this build is very useful for him.
EDIT:
I've done more testing,
LL definitely looks closer to the the original content gamma-wise.
4-bit is watchable now (amazing for only 16 shades of grey), whether on Gamma light it was not representing the original picture correctly.
Can you please include 2-bit and 1-bit, or is it extremely unnecessary?
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410.
James Freeman is offline   Reply With Quote
Old 7th March 2014, 18:09   #24442  |  Link
seiyafan
So for 480 -> 1440, in terms of rendering time, doubling is faster because quadrupling involves another pass. But in terms of visual, which one is better? doubling and upscaling or quadrupling and downscaling?
seiyafan is offline   Reply With Quote
Old 7th March 2014, 18:57   #24443  |  Link
fairchild
It also matters what scaling factor you are using which determines when/if doubling/quad scaling kicks in. I use the following on my 7870 to my 1080p plasma:
chroma upscaling: lanczos 3 (AR), image upscaling: lanczos 3 (AR)
image doubling:
use NNEDI3 to double luma if scaling 2.0x 32 neurons
use NNEDI3 to quadruple luma if scaling 3.0x 16 neurons
image downscaling: camtull-rom (AR+LL)
Basically doubling only kicks in on 960x540 and below and quadrupling only kicks in on 640x360 and below.
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 7th March 2014, 19:13   #24444  |  Link
GREG1292
Originally Posted by James Freeman View Post
Wowee!!!
Looks very good.
EDIT:
Can't wait to test. On vacation for 2 weeks so no testing for me
GREG1292 is offline   Reply With Quote
Old 7th March 2014, 20:41   #24445  |  Link
Werewolfy
Hmmm... According to the log, my hooks are installed correctly, but they do are not called somehow. Weird. It seems you've configured madVR to switch the display mode in the moment when you go fullscreen? What happens if you switch at the start of playback? Does that change anything? Probably not, just wondering...
Unfortunately you're right, it doesn't change anything. I noticed that other users are on Windows 8.1, I'm on Windows 8. Maybe it comes from there but I don't really want to install 8.1, some video games are not compatible with it...
Werewolfy is offline   Reply With Quote
Old 7th March 2014, 20:51   #24446  |  Link
MistahBonzai
if a calibrated screen is really important to you, you may should think about getting a colorimeter.
I have a good working knowledge of display calibration but have no tools other than a multitude of test files and a DIY color temperature adjustment aid (partitioned black box, grey card(s), 6500K light source..). bottom line is that I'm satisfied that my display gamma is ~2.25 - it varies slightly dependent on luminance.
the best gamma should be choice n on your lightning condition in your room. typical 2.4 is what you want.
I adjust as needed although I'm in a well controled environment (dark room, 6500K backlight, no external light source falling on the screen).
see above setting gamma in "calibration" should't have an effect without "color & gamma" settings.
In this case a picture is worth 1K words. Screen crop of my
calibration options. The color and gamma options are completely unselected.
MistahBonzai is offline   Reply With Quote
Old 7th March 2014, 21:09   #24447  |  Link
seiyafan
I think I finally got it so I am going to answer my own question. For quadrupling the first pass uses the neurons number from doubling and the second pass uses the neurons number from quadrupling. I used to think both passes use neurons from quadrupling so that's why I asked that why would the number of doubling neurons even matter for quadrupling.
That's a mouthful but please correct me if I am wrong.
Old 7th March 2014, 21:17   #24448  |  Link
cyberbeing
Broadband Junkie
This is correct.
Old 7th March 2014, 21:37   #24449  |  Link
JonnyRedHed
Originally Posted by JonnyRedHed View Post
I'm still getting a black screen every now and again which all but freezes zoom player. No crash reporter pops up. Apart from this little issue all is good.
madshi asked:
What does the task manager say about ZoomPlayer's CPU RAM consumption when it's frozen like that?
From the 3 times I observed it this afternoon before downgrading to 87.4, cpu ram was 600mb, 800mb, 400mb. When the cpu ram was highest, zoomplayer's crash was worse and required task manger to end process. Otherwise with the lower spikes I could 'esc' back to windowed mode and then click the zoomplayer 'x' to close it after it settled its self down. The video appears to still continue playing, audio can still be heard. I can click the screen once it goes black and playback will pause as normal and then resume with another click. No madvr crash reporter pops up, nor does zplayer crash window. Just a screen that goes black during playback, apparently at random.
This black screen, and very occasional white screen has never happened before in all my years of using zoomplayer and madvr.
With 0.87.4 this does not occur.
JonnyRedHed is offline   Reply With Quote
Old 7th March 2014, 22:07   #24450  |  Link
secvensor
1600х1200@100MHz
Error Diffusion - option 2 enabled
no dropped frames on (windowed/full-screen mode):
MPEG1 640x480 30fps 104857kbps https://mega.co.nz/#!JF92jR6K!PlNXU3xJ01jO3D4cJBSFSn61aYl3zB-t3eZJdj9c0oo (the BEST test video)
MPEG4 (H264 8bit) 960x720 29.917fps 2561kbps
MPEG4 (H264 8bit) 1280x720 25fps 2698kbps
MPEG4 (H264 10bit) 1280x720 60fps 6582kbps
Win7x64
Core i7 920 3.5GHz
Noctua NH-D14/ArcticCooling MX-3
6(3x2)GB Transcend 1426MHz
RoyalHD (64MB)[Solo6c][JPLAY]/HD7850DC22GD5V2[EIZOT965]
Seasonic X-750
VelociRaptor WD4500HLHX/16TB_STORE
secvensor is offline   Reply With Quote
Old 7th March 2014, 22:50   #24451  |  Link
MistahBonzai
Originally Posted by secvensor View Post
variant 9
Oh well..it most likely needed it anyway
You're not using Zoom Player per chance are you? That could explain how you were able to jack-up all the madVR settings and still thought they were being utilized... I was able to playback '4K' files without tweaking settings (didn't even have to set the primaries/gamut in madVR (DCI-P3). Zoom player seems to have a means of dynamically shifting playback filtering when overloaded. It's automagical Of course you have no idea what settings are really in play
Old 7th March 2014, 23:47   #24452  |  Link
leeperry
Kid for Today
For those of you guys who already have signs of withdrawal from the lack of dither testing
I guess I'd very much fancy the impression of depth of A4 with the low-noise of ED11.....you've gotten us to expect the impossible, so that's kinda your fault
The algorithms are basically the same as in v0.87.6, however, I've added Shiandow's linear light processing idea.
My initial impression with mono-static A4 is that killed the impression of depth on 720p content so I just spent quite some time comparing both builds in mono-static mode, with A4 on the bluray of Captain Harlock and ED11 on very crisp 30fps 1080p video content and in both cases the new build kills the sense of depth to my eyes...the wow factor is gone, PQ is pretty dull.
I guess an extra "use LL" checkbox would be great if it does anything good to anyone in dynamic/color mode but that's a no-go to my eyes in mono-static.
Old 7th March 2014, 23:49   #24453  |  Link
Qaq
AV heretic
..here's one more dither test build:
http://madshi.net/madVRlinearLightDithering.rar
Call me a videophile but this one seems to me a huge step in right direction. MadVR's picture never looked THAT transparent. I wonder if its even possible to make it better (should be!).
No way its just Catalyst (stripped to the bone) does tricks on me
I use ED1 with both options disabled.
Qaq is offline   Reply With Quote
Old 7th March 2014, 23:57   #24454  |  Link
MistahBonzai
1600х1200@100MHz
OK..Now edit madVR settings:
  1. Goto "scaling algorithms"
  2. Drop down and select "image doubling"
  3. Select "use NNEDI3 to double Luma resolution"
  4. Drop down and select "only if scaling factor is 1.2 (or bigger)"
  5. Select "128 neurons"
Play you test 640x480/30 test video (the BEST test video) and play full screen (Alt + Enter)
  1. Still no frame drops?
  2. Yes - how much GPU are you using?
  3. No? Good!
  4. Repeat setting procedure for "Use NNEDI3 to double Chroma resolution" but select "32 neurons"
  5. Still no frame drops?
  6. Yes? That's normal with your GPU
  7. No? Ditch that Zoom Player
At that point (after selecting NNEDI3 Luma and Chrome up-scaling) my HD-7850 is maxed out. How are you doing?
Old 8th March 2014, 00:03   #24455  |  Link
TheShadowRunner
TheShadowRunner's Avatar
madshi, is madVR still using the "settings.bin" file or is it now working exclusively with the registry?
When installing the latest version, i forgot to copy over the "settings.bin" file and all my settings were there so I'm wondering.
XP SP3 / Geforce 8500 / Zoom Player
TheShadowRunner is offline   Reply With Quote
Old 8th March 2014, 00:11   #24456  |  Link
cyberbeing
Broadband Junkie
The "settings.bin" is only loaded by madVR if the "Settings" registry key is not present. Whenever settings are changed, they are written to both settings.bin and the registry key.
Old 8th March 2014, 00:22   #24457  |  Link
turbojet
Speaking of settings.bin, I don't think in doubt deinterlacing and debanding settings are stored in it, otherwise they are getting reset by new versions.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
Old 8th March 2014, 00:25   #24458  |  Link
secvensor
  3. No? Good!
MPC-HC last ver.
128 no drop GPU use 0~41~91%
32 no drop GPU use 0~41~91%
Zoom Player:
256х4
Jink 8/Jink 8 / Catroom:
drope 50-100 frames per sec. on 1600x1200@100MHz (1080p10bit60fps).
Win7x64
Core i7 920 3.5GHz
Seasonic X-750
Old 8th March 2014, 00:40   #24459  |  Link
bacondither
At least switching between 8bit and 3bit doesn't brighten up the image, anymore. So it does exactly what it's supposed to do. Let me know what you think! FWIW, it will probably cost a bit of extra performance, but I hope it will not be too much. The test build always applies linear light processing for dithering, for both ordered dithering and the 2 error diffusion algorithms.
Well, the image is not brighter anymore but darker areas are darker then they should be.
I suppose you are using Shiandow code with a decode gamma of 1/0.45. Use a decode gamma of 1/0.53, works much better with BT.709 content which most content is.
And yes, even with 1/0.53 decoding gamma a tiny amout of dark parts will be darker then then the original. But a larger part of the image will be closer to linear.
Example images(ordered dither):
3-bit linear light dither
8-bit linear light dither
1/0.45 and 1/0.53 decoding gamma applied to a BT.709 encoded gamma.
Values normalised so that y values of 1 is 100% of linear light output, y at 0.6 is 60% bright as linear light output and so on...
0 on the x axis is black, 1 is white.
bacondither is offline   Reply With Quote
Old 8th March 2014, 00:46   #24460  |  Link
cyberbeing
Broadband Junkie
Both are stored in settings bin, the only things which are not stored are things like "custom" debanding parameters, which is rather annoying. Though as mentioned, the settings.bin is ignored unless HKEY_CURRENT_USER\Software\madshi\madVR\Settings does not exist. That registry key always takes priority, if it exists and is newer.
