Old 5th October 2006, 21:33   #41  |  Link
agressiv
Registered Loser
agressiv's Avatar
If you see what I have selected in the dropdown, I dont want this file to conform to a particular size.
I just want this to say "Use profile setting" or "N/A"
agressiv
agressiv is offline
Old 5th October 2006, 22:40   #42  |  Link
buzzqw
HDConvertToX author
for custom size just overwrite , as example 1 CD or 1/3 DVD, with your wanted size in MB
so write 300 for an output size of 300 MB
i will look tomorrow for bitrate issue, sorry
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 6th October 2006, 08:07   #43  |  Link
buzzqw
HDConvertToX author
UPDATE www.64k.it/andres/data/a/AutoMKV17.exe
fixed bitrate issue (0.17)
if neroAacEnc.exe is missing then automkvc will switch to ogg vorbis audio (0.17)
CRF and QP quantitizer is parsed from SharkTooth profile ( example: in CQ-ASP_Q2_eq(crf).xml there is one row <BitrateQuantizer>18</BitrateQuantizer> , 18 is used ) (0.17)
and sorry again for bitrate issue (even if i think is due to x264.exe...)
BHH
buzzqw is offline
Old 6th October 2006, 15:37   #44  |  Link
DDogg
Retired, but still around
DDogg's Avatar
Looks like bitrate issue is fixed. I'll do 2 or 3 more tests and edit in the results.
I noticed if neroAacEnc.exe is missing AND you have chosen original-original (ac3) then the ogg routines are still activated. A small thing as neroAacEnc.exe should have been in the BeSweet dir except I redownloaded yesterday and forgot to put it back in.
DDogg is offline
Old 6th October 2006, 15:52   #45  |  Link
buzzqw
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV18.exe
about Original Audio > fixed (0.18)
fixed some info about audio in log file
BHH
P.S. my best thanks to DDogg for his test !
buzzqw is offline
Old 6th October 2006, 16:53   #46  |  Link
DDogg
DDogg's Avatar
Since it looks like the bitrate thing is now working, I need to ask you some questions to better understand your automatic resizing thing -
As a hard test I chose a source of 90 minutes and selected the original AC3 (314 MB (329,891,072 bytes)) with a target of 1 cd using 1P intermediate.
Obviously this is not a good idea, but I wanted to see how your autosizing would work. What I am seeing is a bitrate of 532 and the movie.avs is still 704x304. I assumed the purpose of the automatic resizing would be to move that resolution down to more match the available bitrate. Am I confused, or should the resolution have been reduced? [Maybe it can't work right with 1P? That would make perfect sense as one would not use a 1P for this]
Personally I would not use that feature much, if ever, because I would be using x264 to create HQ stuff and would never want the resolution to be reduced. Still, I would like to understand it better so as to provide some decent testing for you in the future.
I CAN see a mode where a person would like to specify a resolution, quality and the size of the slices and let an automatic mode make the decision on how many slices to produce to yield the specified quality. But that is something to talk about in the future if you are interested as is [the companion topic of light compression enhancing] conditional filtering being triggered if the auto decision showed itself to be on the short edge of adding another incremental slice.
Btw, a process priority selection would be welcomed as x264 does a great job of maxing out my dual not leaving much CPU available for anything else unless I manually reduce the priority.
buzzqw, thanks for your work and let me know how I can help.
Success - The above described encode came out as 692 MB (725,651,061 bytes) - Change: The quality was suprisingly good given the 532 bitrate, 704x304 res, and using 1P intermediate. I think if the proper 2pass mode had been used it would have been quite good. X264 is amazing me more and more. Log attached.
DDogg is offline
Old 6th October 2006, 16:54   #47  |  Link
agressiv
Registered Loser
agressiv's Avatar
I will try leaving that size field blank. I never ever encode fixed sizes, I always just want target bitrates.
I dont have a lot of sources here at work, but the one I tested with has a large audio delay:
Movie T01 3_2ch 448Kbps DELAY 62224ms.ac3
Audio was desynced - and checking the log, it doesn't look like its attempting to compensate for it, nor can I see where I could compensate for it manually -
I frequently use this source because it represents a challenge
Attached is the log -
Other question - anyway of opening the various command line windows minimized or otherwise hidden?
agressiv
agressiv is offline
Old 6th October 2006, 23:12   #48  |  Link
buzzqw
HDConvertToX author
basically i encode 5% of full movie (look at resmovie.avs) and look at the resulting size.
Based on this sized i calculate the "better" width
as you said 1pass mode isn't well suited for compression test, and, probably, if you had chosed 2 pass encode the width should be lower.
before i allowed the editing of bat files automkv launched all encoding in idle priority. But since i allow editing of bat files, automkv cannot more choose these priority (since now i launch bat files no more x264.exe directly) . I must search another solution....
if you want target bitrate you know the resulting final size (since is based on bitrate !). Write on size box your wanted size.
.... i think there is something wrong with this delay... try re-ripping and relaunch dgindex. Audio fix is based on delaycut by jsoto, an excellent application
there no hidden window. if you want to check bat files before automkv lauch these files, just check "pause before encoding"
BHH
buzzqw is offline
Old 6th October 2006, 23:40   #49  |  Link
DDogg
DDogg's Avatar
Second test on same source using 2P Main Profile sized out at 691 MB (724,595,637 bytes). I used Deen() which is a little too heavy but maximizes compression. Resulting res was still 704x304 but it looked quite good with no artifacts. Maybe AutoMK felt the 704x304 was correct given the increased compression effects of Deen().
I'll try to do another with a strong sharpening filter. That should trigger a resolution change if it is ever going to do so, given a 550 bitrate. I attached the log if you need any information.
DDogg is offline
Old 7th October 2006, 06:53   #50  |  Link
DDogg
DDogg's Avatar
buzzqw, this whole resolution thing got me going today. I found the method you are using does not create a different filesize even when one sample had Deen() in it and one had a crazy Sharpen(1). This should have near doubled the size of the sample.
So, this was the result http://forum.doom9.org/showthread.php?t=116773
As an exercise copy one of your resmovie scripts. In one put Deen() and the other use Sharpen(1). Use your normal res encode batchfiles and note very little difference in size (because you are using a bitrate specified method).
Now substitute a -crf 30 and see the filesize nearly double as it should because a constant quality mode is used and the additional complexity caused by the Sharpen(1) causes large bitrate increases as the use of Deen() will cause lower complexity and lower bitrate averages.
The deen() and sharpen(1) is just a quick way to fake movies of different complexity.
Btw, try using only a 1 or 2% sample. That should be fine. SelectRangeEvery(600,12) will give you a 2% and my tests showed it was pretty accurate.
DDogg is offline
Old 7th October 2006, 11:29   #51  |  Link
buzzqw
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV19.exe
added possibility to specify % of movie to test for autoresize routines (0.19)
added possibility to use CRF (and value) instead of bitrate for autoresize routines (0.19)
added about button (0.19)
"extra" directory into \exe\encoder folder could be deleted
@DDogg : my test has show that x264.exe , not as xvid, isn't good when encoding in cbr mode (or 2 pass mode) when working with selectrange script. While xvid seems to jump bitrate correctly (from scenes to scenes) , x264.exe isn't so linear... , i think that CRF could be the GOOD answer for compcheck. THANKS for your test !
BHH
buzzqw is offline
Old 7th October 2006, 22:00   #52  |  Link
DDogg
DDogg's Avatar
Auto Resolution seems to working ok. On the above mentioned encode I chose crf 20 and it moved the resolution down to 464x192. I then reran with a crf of 25 and it chose to keep 704x304.
I still don't understand why someone would want this feature, but I admit my ignorance on many things mp4.
Temporarily for testing and only if it is an easy thing to do, It would be great if pressing the OK button reran the comptest and resolution decision IF AutoMK sees a time stamp change on the movie.avs file. Dunno, maybe more trouble than it is worth.
It is coming together nicely and should be able to already do most of the encodes that "set it and forget it" people want to do. Clearly a batchmode needs to be thought about at some stage to build upon the ease of use.
Folks wanting to get deep n the guts and mess around always have MeGUI. So concentrating on the "Auto" and "easy to do it" does seem to be the way forward for AutoMK and resisting adding too many odd bells and whistles (including mine) is something for you to think about . AutoMK can't be all things to all people, so let it be really, really good for it's targeted users.
Nice job!
DDogg is offline
Old 7th October 2006, 23:40   #53  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Hi DDogg,
I hear you but would there be any chance of adding the following options: -
  • Elementary stream input option (.M1V, .M2V)
  • A manual bit-rate encoding option
  • A manual output resolution option
I think the inclusion of these options would suffice most users requirements....
Great little GUI by-the-way and very simple to use
Very nice work indeed
SeeMoreDigital is offline
Old 8th October 2006, 00:00   #54  |  Link
DDogg
DDogg's Avatar
Howdy, SMD,
I think 2 things:
1> If the buzzqw is having fun, and if there is an experienced person like you to help test, adding advanced stuff is always cool, but,
2>Seems there would nearly have to be an separate advanced functions menu/window so the clean simple front-end targeted at 95% of the users doesn't turn into the mishmash we have all seen so many times.
AutoGK had a little of that, but I always wished it had an additional advanced menu which would let me drill down/step through to the guts of the process on those few times I wanted to do so. Still, I understood the authors reluctance to deviate too far from his target user. He is a pretty smart guy
DDogg is offline
Old 8th October 2006, 10:13   #55  |  Link
buzzqw
HDConvertToX author
could be done in two way: by modifing the avs script or modding the x264 parameters in bat file
I could wait for modifing then relaunch autoresize. Stamp on log the resize gained, then if ok, read the x264 bat and the resmovie.avs.... sorry i think is beyond the scope of AutoMKV... anyway i will think on it (thanks for suggestion)
or using my MkvMagic
is already possble ! ... well... in list of support input just choose ALL file. AutoMKV will ask for audio file, just hit Cancel if you haven't any audio to process (anyway i had already added to list of support file these two extension)
is on the way
now is possible to specify the width of video. Your input file will be autocropped and then resized to your choice.
Is also possible to NO RESIZE (no autocrop/no resize), just choose NONE in Resizer list
Manual crop and manual width/height could be done by checking "pause before encoding". Edit your avs file and click ok. (anyway an advanced panel is to considering)
thanks all for your kind words
BHH
buzzqw is offline
Old 8th October 2006, 15:49   #56  |  Link
DDogg
DDogg's Avatar
No problem whatsoever, but let me make sure we are speaking of the same thing. I was suggesting you set the archive bit or note the timestamp when you create the movie.avs. When OK is pressed and IF the archive bit is gone or timestamp changed you just loop back to the resmovie routine, else continue as normal. Thought that would be a simple thing, but understand if not as I don't know how your code is structured. Certainty not worth hardy any effort if it is not that simple.
DDogg is offline
Old 8th October 2006, 16:59   #57  |  Link
buzzqw
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV20.exe
added bitrate encoding: used in 1 pass encoding or 2 pass encoding (and ofr autoresize routines if not checked use CRF). Specified MB size is ignored. (0.20)
added an Advanced Panel:
moved here : Pause before encoding, Use CRF for Autosize..., Custom Comp% check, Specify Bitrate (0.20), Custom Matrix, Deinterlacer (0.20)
added (in advanced panel) Manual Crop&Resize:
if manual crop and resize is checked then automkv will use those crop parameters AND width/height written. (0.20) (user should use dgindex or gordianknot for finding values...) (0.20)
@DDogg
... i simple thing can be this:
i add a check: "Multiple AutoResize", if user tick this check i can allow
1) to modify avisynth filter from box list
2) x264/xvid profiles
3) resizers (simpleresize/lanczos...)
4) change value of "Use CRF for autoresize"
5) Allow/modify "Custom Comp check"
6) Switch to "Specify bitrate mode" (only for 1 or 2 passes encoding)
after each encoding i ask to continue or redo the autosize
what you think ?
BHH
buzzqw is offline
Old 8th October 2006, 17:30   #58  |  Link
buzzqw
HDConvertToX author
anyway i had already done it
www.64k.it/andres/data/a/AutoMKV21.exe
added (in advanced panel) "Allow multiple autoresize", if checked automkv will ask to redo autoresize.
allowd changes are
7) change matrix
thansk again to DDogg for suggestion !
BHH
buzzqw is offline
Old 8th October 2006, 17:53   #59  |  Link
DDogg
DDogg's Avatar
You are freaking amazing! I think the advanced tab is well thought out and will not needlessly confuse people taking their first look at AutoMK.
It may be this evening, but I'll do a complete set of tests (need to finish my test CRF encodes first). Hopefully SMD can give it a workout also. Between the two of us we should be able to break it if it is breakable
Add: very, very nice! Selected multiple auto resize and input crf 22, got 608 res - said yes to redo, and changed to crf 25 and got 703, then did it again with crf 18 and got 368. Seems to be working nicely and I wonder if you should not remove the other size check or at least make crf the default?
I think you have nailed a good balance between user friendly and advanced use in one easy to use package. I will really try to break it later today.
DDogg is offline
Old 8th October 2006, 18:54   #60  |  Link
buzzqw
HDConvertToX author
@DDogg
breakable ??? is breakable like a crystal glass than iron ! (or lead !!!)
i agree about CRF resize, in next version "Use CRF for autoresize" will be check by default. At 18 value ? (should be enough)
and... i missed in changelog: added m1v and m2v to supported input
BHH
buzzqw is offline
