Old 23rd July 2006, 13:10   #21  |  Link
BergH
Simplifizissimus
BergH's Avatar
Hello again !
No success , same strange behavior as described above.
Can you see anything from the Logfile attached ?
regards BergH
BergH is offline
Old 23rd July 2006, 13:23   #22  |  Link
buzzqw
HDConvertToX author
here is the 0.10 http://www.64k.it/andres/data/a/AutoMKV10.exe
now automkv window is no more hidden, and can be minimized, also a window will popup with the log of varius operation.
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 23rd July 2006, 13:24   #23  |  Link
buzzqw
HDConvertToX author
@bergh
please post the log, otherwise a mod must be validate the attach
also ... try with latest version
BHH
buzzqw is offline
Old 27th July 2006, 05:46   #24  |  Link
killerhex
can mkv be input thru .avs
killerhex is offline
Old 27th July 2006, 08:34   #25  |  Link
buzzqw
HDConvertToX author
for sure !
pay attention to vfr file. audio should be encoded separately.
thanks for your interest
BHH
buzzqw is offline
Old 28th July 2006, 20:56   #26  |  Link
Henrikx
Henrikx's Avatar
@buzzqw
Question :
Output Size < 1/4 CD . What to do ?
Is something like Custom Size (AutoGK) planned ?
THX for your Work !!!
Henrikx
Henrikx is offline
Old 28th July 2006, 22:08   #27  |  Link
buzzqw
HDConvertToX author
just a note: if you write 200 (for example), overwriting "1 CD" you will got a 200MB final size. The same if you write 800 you will get a 800mb final size. The second number (usually "1") is the multiplier of slice.
let's say: 1 cd , 1 -> 1 cd as final output
2 cd , 2 -> 2 slice of 1400 mb
also 300 , 3 -> 3 slice of 300mb
do you understand ? (i hope so !)
BHH
buzzqw is offline
Old 29th July 2006, 07:32   #28  |  Link
Henrikx
Henrikx's Avatar
Yes I understand !!
THX
Henrikx
Henrikx is offline
Old 2nd October 2006, 14:49   #29  |  Link
DDogg
Retired, but still around
DDogg's Avatar
A note for folks casually trying out this program - Make sure you download NeroAAC to the AutoMK\exe\BeSweet directory. Else, you will get an exasperating looping flickering command window without an error being indicated.
DDogg is offline
Old 2nd October 2006, 15:34   #30  |  Link
buzzqw
HDConvertToX author
thanks for the info
but is already diplayed in first topic (from 23/07)
BHH
buzzqw is offline
Old 2nd October 2006, 16:55   #31  |  Link
DDogg
DDogg's Avatar
thanks for the info
but is already displayed in first topic (from 23/07)
BHH
Yes, but I wanted people to know what the result was.
[Changed - The error I am having now seems to NOT be anything to do with audio. Rather, it seems to be something caused by using the CQ-ASP_Q2_Eq(crf) profile.] More later.
/add2: Yep, when I choose CQ-ASP_Q2_Eq(crf) profile the process stops before (or during?) the creation of the resmovie.mp4 file. I can then change only the profile to CQ-ASP_Q2_equiv and press start again and it works. Or, at least the resmovie.mp4 is running as I type. What is this resmovie.mp4 file for? Seems to me the CQ mode needs nothing but the encoding pass anyway?
Later: Chose CQ-Q2 equiv space 1/3 dvd - Ended up with a 1.25 gig file with a resolution of 336X144! (scratching head)
I appreciate your work on this program. It did a great encode [when the default settings were used] and is easy and comfortable to use.
/add: a few comments -
1> Although a user error, it is easy to forget to change the output directory to the HD when the input is a virtual drive. No error is thrown, just a crash.
2> If I chose H (my Vdrive) in the uppermost right drop down, should it pick up the dvd structure automatically? If so, it is not working. After start is pressed, DGIndex comes up and hangs open like it is waiting for input.
DDogg is offline
Old 3rd October 2006, 07:56   #32  |  Link
buzzqw
HDConvertToX author
AutoMKV 0.11 UPDATE
i can confirm that this 2 mode was totaly broken. (fixed in automkv 0.11)
automkv will auto resize movie based on medium choosed. if you don't wat resize just choose NONE in Resizer ( added automkv 0.11)
not easy... but i have one idea... (checking for free space...)
usually you should input to one ifo, automkv would choose then the main movie.
thanks for your test !
buzzqw is offline
Old 3rd October 2006, 22:05   #33  |  Link
DDogg
DDogg's Avatar
Just finished an encode using the CQ-ASP_Q2_Eq(crf) profile and it completed and looked good. Thanks!
That brought up several deeper questions. I hope you don't mind.
I noticed a fair speed difference between AutoMK and MeGUI while using the identical profile so took a look a little deeper as a learning exercise.
Btw, I noticed AutoMK was not picking up the matrix that was hardcoded into the profile and copied to AutoMk's profile
folder (so I added it, hopefully in the correct place). I took both command lines from AutoMK and MeGUI and slightly modified
them to both use the same exe, matrix, avs, and destination folders.
The AutoMK cmdline showed 21.30 fps after 3% and the MeGUI line showed 15.58 fps after 3% (not very scientific, I know).
For some reason, I had in my head that using a profile pretty much caused the cmdlines to be the same in any program.
Probably a poor assumption on my part, but this x264 stuff is all new to me. I wonder if someone more experienced can spot
the difference in the cmdlines that made the speed difference.
Here are the cmdlines -
AutoMK 21.30 fps
c:\apps\x264.exe --crf 18 --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 3 --filter
 -2,-1 --direct spatial --vbv-maxrate 25000 --me umh --weightb --b-pyramid --b-rdo --bime --analyse  p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct
 --threads 2 --cqmfile "C:\apps\extra\eqm_avc_hr.cfg" --output "D:\temp\auto2\movie.mp4" "D:\temp\auto2\movie.avs"
MeGUI 15.58 fps
c:\apps\x264.exe --crf 18 --ref 3 --mixed-refs --bframes 3 --b-pyramid --b-rdo --bime --weightb --filter -2,-1 --subme 6 --trellis 1
 --analyse all  --8x8dct --vbv-maxrate 25000 --me umh --threads 2 --thread-input --cqmfile "C:\apps\extra\eqm_avc_hr.cfg" --progress
 --no-psnr --output "D:\temp\auto2\movie.mp4" "D:\temp\auto2\movie.avs"
Also, on another subject, you mentioned a "NONE" in size. I saw a blank, but no "NONE" so set it to 720.
DDogg is offline
Old 4th October 2006, 10:59   #34  |  Link
buzzqw
HDConvertToX author
new full istaller at first post (http://www.64k.it/andres/data/a/AutoMKV015.rar)
added possibility to choose matrix (0.15)
this should be true !
differcence is "subme" . megui use subme 6 , but automkv use the default , 5
NONE is in Resizer, with SimpleResize,Lanczos...
if you choose NONE , then NO reisize is applyed.
Example:
1) SimpleResize / 720: movie is autocropped then resized to 720
2) SimpleResize / Automatic: movie is autocropped and resized to for better diplay
3) NONE / 640 : movie isn't either autocropped or resized
4) NONE / Automatica: movie isn't either autocropped or resized, AND NO resized applyed
for your test
BHH
buzzqw is offline
Old 4th October 2006, 20:36   #35  |  Link
DDogg
DDogg's Avatar
Problems in test (v15):
1> x264.exe does not like your -nf argument in 1P max speed.
2> Encoding worked before with my AutoMK dir in "Avi Out" - now borks on spaces. You left out the quote marks for the first of the cmdline.
Requests:
1> Possible to allow editing of the script before encode process starts? Just a save with the process paused so one can go to dir and play it to check if it is ok before continuing. The creation of the x264 test.bat would help also because a person could tinker with the script and run the testx264.bat to gauge speed, etc. When the person was finished, they would click a continue button on the AutoMK gui popup. This would save a world of time instead of starting over every time. That is frustrating.
2> A way to change the load plugin lines so I can use, for instance, RemoveGrainSSE3.dll? Presently renaming it, but that is kind of ugly. Perhaps replace your hardcoded loadplugin lines with an import of a separate plugin script which could be edited? I think that would work. [Yep, tested - importing Path:\plugin_scr.avs works fine as a substitute for your hardcode]
Later: I see the -nf thing was dealt with http://forum.doom9.org/showthread.ph...442#post883442
DDogg is offline
Old 5th October 2006, 12:23   #36  |  Link
buzzqw
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV16.exe
the bat are created for debug pourpose. AutoMKV launch x264.exe with parameters.... anyway now automkv will lauch those bat.
Requests:
DONE (0.16). just check "Pause before encoding", this check will pause encoding before autoresize routines and final encoding.
Also you can check it, adjust the autoresize bat, click on wait prompt, and if ok de-check "Pause..." and final encoding will not wait for start
every plugin (*.dll) in \filter is automatically loaded.
thanks again
BHH
buzzqw is offline
Old 5th October 2006, 16:54   #37  |  Link
DDogg
DDogg's Avatar
buzzqw, thanks for being so responsive. The pause feature will be very helpful. [V16 is broken I think, use V15]
The 2pass and CQ modes seem to be working ok, but 1Pass with auto is weird. Note the bitrate below. As well, the movie.avs generated a 112x48 resize! Suggest anybody trying this out should not choose 1Pass or automatic resizing for a while. CQ modes seem ok.
"C:\apps\AutoMK\exe\encoder\x264.exe"  --bitrate 241155 --progress --keyint 250 --bframes 0 --qpmin 10
--qpmax 51 --no-psnr --ref 1 --filter 0,0 --subme 0 --direct auto --vbv-maxrate 25000 --me dia --merange 8 --nf --no-cabac
--no-b-adapt --no-chroma-me --threads 2  --output "C:\temp\resmovie.mp4" "C:\temp\resmovie.avs"
/add: choose 720 instead of auto on 1pass max speed - got --bitrate 679175
/add2: V16 seems to be borked > "... --pass 1 --bitrate 1555215"
DDogg is offline
Old 5th October 2006, 19:44   #38  |  Link
buzzqw
HDConvertToX author
i think problem is caused by using time.avs
i launch x264.exe, with some very quick parameter, and -nf is one of these, and encode time.avs (this parameter will be removed in next automvk build)
then a file "c:\frame.txt" is created and then read (for information about frame, width,height...)
i think i have update my the x264.exe build and not those within the "installer".
Please update your x264.exe in your \exe\encoder folder with latest one from Sharktooth, and report again. (i am not able, now, to replicate the problem)
Also i accept every suggestion and criticism
BHH
buzzqw is offline
Old 5th October 2006, 19:50   #39  |  Link
agressiv
Registered Loser
agressiv's Avatar
Can you set a target bitrate rather than a target size? (e.g I dont want to use 1/3 DVD etc, I want to use the default setting in the HQ-Slow profile)
Thanks!
agressiv
agressiv is offline
Old 5th October 2006, 20:22   #40  |  Link
DDogg
DDogg's Avatar
Was using the very latest x264 build. I will revert back and try it with an older build if I can find it.
buzzqw, is this of any interest? http://forum.doom9.org/showthread.ph...035#post884035
GOP threading:
+ Scales perfectly to decent-sized clusters.
- Requires application support / restricts API (seekable input, heavily buffered output.) Not usable for realtime streaming.
- Requires CQ or 2pass (no ABR).
I have a dual 930 running with Avisynth 2.6. No problems at all with anything.
I give up trying to understand what is happening here with all the bitrate based stuff. The CQ modes work fine and that is all I need. I will be happy to help test for you when you have a somewhat tested version you feel might be ok. When you do, please upgrade the whole package so I can make sure I am using what you tested with.
Thanks!
agressiv
Maybe I am not experienced enough to understand but isn't HQ-Slow profile a bitrate based 2 pass designed for a size target? If you just want a quality encode with no size target, try CQ-ASP_Q2_Eq(crf) profile. Did I misunderstand?
DDogg is offline
