Old 13th July 2011, 10:14   #101  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by kolak View Post
No problem except complex decoding-more complex than all intermediate codecs for the price of smaller size. These days storage is cheap, so I prefer easier decoding.
AVC-I 100 is CAVLC by Panasonic standard, but it's not really transparent at 100Mbit (you need something like 150Mbit).
Andrew
100 Mbits is not enough ... ?
It's certainely not transparent with loop in particular condition because lossy will be always lossy. Anyway I doubt seriousely that you can see compression artefact at this quality. I doubt seriousely that you can say "this is original and this is lossy compression". 100 Mbps for AVC at 100 Mbps is by far enough for original master ... simply because production will be more destructive and by far ...
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 13th July 2011, 12:20   #102  |  Link
kolak
Try it
AVC-I is great in many areas TVs, news, documentary, etc), but not for feature movies, grading or as BD master.
I don't have to doubt- I've tried it.
Intermediate codec should be as good as HDCAM-SR- that's the whole idea of it. AVC-I at 100mbit is not as good, by quite a lot.
Andrew
Old 13th July 2011, 14:50   #103  |  Link
poisondeathray
kolak is correct; Panasonic's AVC-I 100 isn't good enough for mastering or high end acquisition. It probably needs 150-200Mb/s.
People who use cameras with AVC-I for TV shows (e.g. HPX3700), use external recorder because AVCI-100 isn't good enough
You can see artifacts and detail loss with naked eye (unzoomed) compared to simultaneous uncompressed recording, or even compared to ProResHQ
Old 13th July 2011, 16:17   #104  |  Link
kolak
Yes- about 1.3-1.5x less bitrate than other intermediate codecs, but 100Mbit is not enough.
In the same time decoding is more complicated and these days (with cheap storage) it's not worth it.
Andrew
Old 13th July 2011, 16:27   #105  |  Link
poisondeathray
Like you said, it's fine for some purposes, but not ok for others... But it's not even in the category of "visually lossless"
There have been rumors of an "AVC-Ultra" by Panasonic , a 200Mbps 4:2:2 10-bit variant, but it never got released .
Old 13th July 2011, 16:32   #106  |  Link
kolak
All of the intermediate codecs are good and have about the same efficiency- ProRes, DNxHD, Cineform and Canopus HQX- all great and very fast, but HQX in Edius is unbeatable
Andrew
Old 13th July 2011, 16:48   #107  |  Link
henryho_hk
Any subjective measurement?
henryho_hk is offline   Reply With Quote
Old 13th July 2011, 19:10   #108  |  Link
kolak
In what terms? Speed is unmatched by any other NLE+their native codec. AVID+DNxHD is a joke in comparison
Quality- at highest setting it's almost lossless. You need to zoom 5x to see single pixel changes. PSNR 55dB+.
It's like other intermediate codecs, but more scalable and performance is amazing. You can do 4K color grading in RT on modern machine.
UtVideo is also very fast (and lossless), but 8bit only.
Andrew
Old 13th July 2011, 20:51   #109  |  Link
mp3dom
kolak, since HQX is a 10bit codec, do you know if the conversion to 8bit (for final encoding for example) is forced to be done inside Edius or is there a way to convert it to 8bit outsite the NLE? With proper codec installed I think VDub or AviSynth see it as a 8bit codec (truncating the 2 bits) or am I wrong?
Old 13th July 2011, 21:19   #110  |  Link
kolak
Yes- no access to 10bit in HQX outside Edius at this point. It has been passed to GV and they confirmed it. It may change soon. HQX decoder (outside Edius) has no higher than 8bit output pin for now.
Andrew
Old 28th July 2011, 00:19   #111  |  Link
kolak
Here is some white paper:
http://www.grassvalley.com/docs/Whit...Whitepaper.pdf
It looks "real"- no cheating- some text is marketing crap, but graphs seams to be fine.
Advantage of HQX is that you have huge range of quality- from 25:1 to nearly lossless. Other codecs are more strict, but efficiency is basically the same.
Andrew
codec, hdtv, intermediate
