Old 31st March 2012, 11:32   #41  |  Link
nibus
Telewhining
Originally Posted by FuPP View Post
I had fixed overlaping (don't know how I could miss that !) and some other little things in HybridFuPP 0.992b but never posted it. If you are interested, I will.
FuPP
Any news on the updated version Mr. FuPP?
nibus is offline   Reply With Quote
Old 2nd April 2012, 10:19   #42  |  Link
FuPP
TotalEclipseOfTheBrain
FuPP's Avatar
actually, 0.992b exists for a long time. But there is something I want to fix about 'show' function and did not have time for that. I will try next weekend and will post if ok. Sorry for the delay...
FuPP
FuPP is offline   Reply With Quote
Old 23rd September 2012, 11:29   #43  |  Link
Jynrion
Hi FuPP,
I'm a big fan of your work on this script and i'm wondering if you have the possibility to release in the open v.0.992B :]
Thanks a lot, hoping to see it soon.
ps: link is broken in first post
Jynrion is offline   Reply With Quote
Old 23rd September 2012, 18:46   #44  |  Link
FuPP
FuPP's Avatar
Link fixed on first page (HybridFuPP 0.991b)
I will take the time to update to 0.993b this week.
Thanks for your interest !
FuPP
Old 6th October 2012, 13:10   #45  |  Link
nibus
Telewhining
How about that update mr FuPP? Starting some encodes and would like to have the latest version.
Old 8th October 2012, 09:48   #46  |  Link
FuPP
FuPP's Avatar
Sorry... I can't find time to work on 0.993b (need to fix a few things in command 'show'). I will post today 0.992b instead. You will have to wait more for 0.993b...
Sorry again,
FuPP
Old 8th October 2012, 09:54   #47  |  Link
nibus
Telewhining
Thanks for your hard work
As a side note, I can't ever see a difference when adjusting the "M_Str" option in mode 2. It doesn't appear to raise or lower the denoising strength at all.
Old 8th October 2012, 20:13   #48  |  Link
FuPP
FuPP's Avatar
0.992 posted in a new thread.
Tested M_Str with MP_Mode = 2, could not reproduce your problem (I can see a difference between 0 and 255, for instance... Of course only in motion areas)
Hybridfupp(608, 320, show="", MP_Mode=2, M_Str=255)
Please test with 0.992b. If still the same post your entire HybridFuPP line in the new thread.
A few thoughts : could be related to the preset used. Use show="P" to check what is said about M_Str. Did you check if some motion was detected, using show="M" where you checked ? This parameter is only useful in motion areas...
FuPP
