Old 7th June 2007, 19:10   #341  |  Link
Originally Posted by klinika View Post
Installed the vcredist, nada, didn't do anything. No duplicate libavcodecs except the one in ffdshow dir, and that's nowhere near any PATH variables. And test.264 crashes dgavcindex on open too.
Please rename that one, reboot, and try again.
Guest is offline
Old 7th June 2007, 19:11   #342  |  Link
Originally Posted by xc3ll View Post
Hi neuron2, I tried your program, but get an this error:
[h264 @ 0100700C]Internal error, IDCT permutation not set
when I try encoding w/meGUI, source is a bd disc.
Are you sure it is H.264 and not VC1? If so, please post a source stream fragment that I can use to duplicate the issue.
Guest is offline
Old 7th June 2007, 20:02   #343  |  Link
Inventive Software
Turkey Machine
Also be well aware that you have to demux the video stream from the BD files. DGAVCIndex only accepts raw .264 files.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 8th June 2007, 00:27   #344  |  Link
klinika
I'm sorry to say it didn't change a thing... Tried even moving the whole thing to c partition's root, just in case, but that didn't change anything either. Can't think of anything else really, except if there'd be an easy way to debug it.
klinika is offline
Old 8th June 2007, 01:02   #345  |  Link
Inventive Software
Turkey Machine
The link to the VC redist neuron posted earlier, try the SP1 update on top of it and see if that helps or not.
Old 8th June 2007, 05:05   #346  |  Link
Is anyone else having this issue with Alpha 6?
Guest is offline
Old 8th June 2007, 07:47   #347  |  Link
Revgen
^ I'll try it tomorrow after I'm done encoding.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline
Old 8th June 2007, 08:24   #348  |  Link
G_M_C
I havent been able to get to testing out this new version. I'll do some testing tonight on a new project.
But my first thought is this (i'm at work right now,so forgive me if i make some mistake in my reasoning );
When i remember correctly the previous versions came with 2(3) separate DLL's. It was advised that you put those DLL's in your
"windows/system" directory. Cant i be that you have forgotten to remove the old DLL's from your "windows/system" directory xc3ll ?
G_M_C is offline
Old 8th June 2007, 08:29   #349  |  Link
ToS_Maverick
x264 Tester
I havent been able to test it either, but i've some PAFF streams on my disk, who i'd love to test for you, with a new version
ToS_Maverick is offline
Old 8th June 2007, 09:20   #350  |  Link
canTsTop
canTsTop's Avatar
hello, i get same error like klinika. here is my error log
http://rapidshare.com/files/35905893/error.txt.html
canTsTop is offline
Old 8th June 2007, 09:23   #351  |  Link
klinika
Good catch, but it didn't work either..
klinika is offline
Old 8th June 2007, 09:32   #352  |  Link
klinika
Ah, of course! Dr. Watson to the rescue I have it disabled by default and forgot all about it.
klinika is offline
Old 8th June 2007, 20:49   #353  |  Link
Revgen
I've had no problems with this new version.
Then again I don't have any AVC source from Blu-Ray or HD-DVD.
Moe: Why?
Revgen is offline
Old 8th June 2007, 21:40   #354  |  Link
Can you get me a Dr. Watson dump as well then, please?
Guest is offline
Old 8th June 2007, 23:22   #355  |  Link
canTsTop
canTsTop's Avatar
here is my Dr Watson dump
http://rapidshare.com/files/36034597/Dr_Watson.7z.html
canTsTop is offline
Old 9th June 2007, 00:43   #356  |  Link
Thank you.
Can you please try this debug DLL and give me a Dr Watson dump using that? Thanks.
http://neuron2.net/guest/libavcodec.zip
Guest is offline
Old 9th June 2007, 01:23   #357  |  Link
klinika
Uh oh, well I quite suddenly decided to upgrade mobo & cpu, and no more crashing. But the FAULT text (or whatever it read) in the debug log was at the same spot. Sorry for not being able to be of further help in the issue I do hope it gets solved for everyone's benefit though, and more importantly, thank you for the immensely useful program!
klinika is offline
Old 9th June 2007, 05:11   #358  |  Link
What was your processor before and after, please?
Guest is offline
Old 9th June 2007, 05:14   #359  |  Link
Kurth
Kurth's Avatar
Any .264 file that I try to open on DGAVCIndex Alpha 6 crashes I found that the problem is the libavcodec.dll that come inside the dgavcdec100a6.zip
I copied my libavcodec.dll from the FFDshow directory and pasted it on the DGAVCIndex.exe directory and now the Alpha 6 version works fine.
The libavcodec.dll that you made have problems you should check it.
Kurth is offline
Old 9th June 2007, 05:34   #360  |  Link
I guess you missed the last several posts, where I am attempting to debug libavcodec.dll.
Guest is offline
