Old 13th July 2020, 16:21   #3621  |  Link
Selur
Selur's Avatar
regarding the x265 options, see: https://forum.doom9.org/showthread.p...40#post1918240
-> I'll remove the whole 'Save analysis'-option and the option related to it, since they don't make sense for Hybrid.
regarding aomenc: I'll look into it.
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 17th July 2020, 03:44   #3622  |  Link
Selur
Selur's Avatar
Hybrid rev 2020.07.11.1:
*fixed*
  • Avisynth: limit LSFMod to YV12
  • Startup/Shutdown crashes
*added*
  • Vapoursynth: LGhost
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 25th July 2020, 21:56   #3623  |  Link
Richard1485
AviSynth monkey
Richard1485's Avatar
The default parameters for NVenc in Hybrid include:
-spatial-aq 0 -temporal_aq 0
But if I copy the command into the terminal and run it, ffmpeg outputs a warning that the temporal_aq option is unused -- unless I change it to:
-spatial-aq 0 -temporal-aq 0
Is this just a typo in the GUI or would it affect the output?
I was using the parameters set by Hybrid as the starting point for some tests with ffmpeg on Ubuntu 20.04 when I noticed the message.
Richard1485 is offline   Reply With Quote
Old 25th July 2020, 22:48   #3624  |  Link
Sharc
NVEnc(ffmpeg) has been abandoned in Hybrid. Only NVEncC is supported in newer releases.
Edit: .... abandoned for Windows only; sorry.
Old 30th July 2020, 16:01   #3625  |  Link
Selur
Selur's Avatar
@richard1485: typo -> fixed for the next release, should not change the output. Since it's the default.
Cu Selur
Old 30th July 2020, 18:56   #3626  |  Link
Sharc
According to recent update of ffmpeg 4.3.1, ffmpeg -h encoder=h264_nvenc indicates that both syntax are accepted, i.e.
'-spatial-aq' or '-spatial_aq'
'-temporal-aq' or '-temporal_aq'
I didn't test it though.
Old 2nd August 2020, 12:14   #3627  |  Link
Selur
Selur's Avatar
*fixed*
  • Vapoursynth: saving profiles
  • Vapoursynth QTGMC bob
  • General: restting Defaults caused two instances to open
  • Jobs: tsMuxeR temp and input file handling
*changed*
  • Filtering: Removed the "force deinterlace" option, instead 'Overwrite input scan type to' should be used.
  • Tools: adjusted to latest NVEncC 'check-features' changes
  • Audio: remove unneeded '-ac' in ffmpeg call
*added*
  • Avisynth: 64bit Support, support 32bit and 64bit Avisynth jobs at the same time in the jobqueue (Windows only)
Cu Selur
Old 7th August 2020, 20:07   #3628  |  Link
Selur
Selur's Avatar
Since the https://github.com/Selur/hybrid-vapoursynth-addon is clearly broken (building Vapoursynth seems to work, building plugins seems to work, but vscript and vspipe fails) and I lack the time/knowledge/motivation to spend tons of time to look into fixing this I'm thinking about dropping Linux support as a whole and turn Hybrid into a Windows only tool.
Spending most of my free time trying to get shell scripts working is way to frustrating to keep this going.
Cu Selur
Old 28th August 2020, 16:44   #3629  |  Link
god_md5
why i have this bug?
god_md5 is offline   Reply With Quote
Old 1st September 2020, 04:44   #3630  |  Link
Selur
Selur's Avatar
image is still waiting for approval nothing I can do,...
Old 15th September 2020, 07:41   #3631  |  Link
ReinerSchweinlin
Originally Posted by Selur View Post
....dropping Linux support as a whole and turn Hybrid into a Windows only tool.
Totally understandable. Let me take the opportunity to thank you for the wonderfull programm you are building here all this time. This has some eral nice gems - I often use the AI-Upscaling Capabilities - which makes hybrid really unique in the way it is incorporating them into a simple GUI. Thanx !
Old 10th October 2020, 12:25   #3632  |  Link
Selur
Selur's Avatar
Hybrid rev 2020.10.10.1:
*fixed*
  • Avisynth: handling QTGMC field order
  • Video: nvencc version check
  • Vapoursynth: Cnr2, typo sceneChroma -> scenechroma
  • Video: NVEncC bluray input with 'encoder only' not starting encoding
  • Avisynth+: no preRo for Text subittle
  • Vapoursynth: sRestore output frame count calculation fixex: Preview not working with crop
  • Vapoursynth: handle TimeCude filename changes
  • Synth: some colorMatrix fixes
  • Avisynth: DFMDeRainbow load mvtools for motion compensation
  • Vapoursynth: Fix Combed to IVTC
  • Analysis: aspect ratio detection
  • Avisynth: 64bit preview
  • Vapoursynth: restrict VFM Mi to blockx*blocky
  • Video: problem with aoemenc and svthevc
  • Vapoursynth: fixed Santiang typevh typo to typev, "AntiAliasing" - Nedi3aa vs "AnitAliasing - Nedi3aa"
  • Vapoursynth: deleting profiles
  • Vapoursynth: MAA missing dependecies
  • Analysis: prefer stream aspect ratio
  • Video: scanorder handling especially for DNxHD
  • Tools: tsMuxeR version check
*changed*
  • Cosmetics: Bunch of cosmetic changes
  • Video: Using xvid_encraw instead of mencoder for XviD encoding.
  • Vapoursynth: using D2VSource instead of MPEG2DecPlus
  • Tools: use 64bit of vStripFree, Telxcc and MP4FPSmod (Windows only)
  • Synth: added QTGMC custom addition
  • Synth: splitting QTGMC into "QTGMC - Deinterlacer" (InputType = 0) and "QTGMC - Filter" (InputType > 0)
  • Vapoursynth: Anime4KCPP support for HDNLevel Option
  • Vapoursynth/Avisynth: in custom section you can now overwrite width, height, scantype and colorformat using: Note that these values are only respected inside the Vapoursynth/ Avisynth script.
    Frame rate and frame count need to be globally overwrite using "Filtering->Misc->Overwrite output". All other values also need to be overwritten globally if you set them.
  • Vapoursynth: Levels handling
  • Avisynth: added QTGMC MatchPreset, MatchPreset2, MatchEnhance
  • Crop: lowered min Crop-Width-Mult from 0.75 to 0.7
  • Avisynth: TDecimate added additional parameters
  • Vapoursynth: VIVTC added Deinterlacer option
  • Avisynth: Flash3KDeband adjust output bit depth
  • Avisynth: TemporalDegrain requires 8bit input
  • Vapoursynth: KNLMeans adjust RGBX
  • Vapoursynth: TimeCube RGB handling
  • Vapoursynth: restrict filters based on Hqdn3d to 8bit
  • Tools: look also for '3D controller" in lspci output for video card
  • Analysis: added option to prefer stream luma range
  • Video: changed ProRes models to proxy, lt, standard, hq, 4444, 4444x
  • Avisynth: added RemoveDirt
  • Output: added 'Config->Output->MKV Contains->Matroska advanced video signaling->Import HDR data from source'
*added*
  • Video: Cineform HD support
  • Filtering: option to flip video horizontally
*removed*
  • Tools: nvhsp not used on Windows, hardly working on Linux&Mac, sadly ffmpeg does still not support signaling max cll/fall etc
  • Tools: not using ffmbc any more
  • Avisynth support on MacOS
Cu Selur
Ps.: Added Mac OS back to the release OSs.
Old 10th October 2020, 13:19   #3633  |  Link
Sharc
Can't try it.
It starts to initialize then closes ....
Old 10th October 2020, 14:54   #3634  |  Link
Selur
Selur's Avatar
Hmm,.. works fine here. :/
Can you try if it works if you move the content of your settings folder?
Old 10th October 2020, 16:54   #3635  |  Link
Sharc
Yes, this helped. I just lost my configurations, however.
Edit:
Copying the former settings back piece by piece and see where it crashes .........
Old 10th October 2020, 17:23   #3636  |  Link
Selur
Selur's Avatar
If you figure out what it is let me know and I can probably fix it.
Cu Selur
Old 10th October 2020, 17:29   #3637  |  Link
Sharc
I could so far recover most of it, but disableIcons=true in the misc.ini has no effect .... (I prefer the test buttons).
Old 10th October 2020, 18:21   #3638  |  Link
Selur
Selur's Avatar
Yeah, that option is removed due to complains that it breaks the layout, not sure whether it will return.
Cu Selur
Old 11th October 2020, 13:47   #3639  |  Link
Selur
Selur's Avatar
Hybrid rev 2020.10.11.1:
*fixed*
  • Vapoursynth: TDeintMod in VIVTC and FixCombed
  • Muxing: always used ffmpeg for mkv muxing
*changed*
  • Vapoursynth: add 'Use RGB' for Limiter and Levels and use it as default.
  • Vapoursynth: extend compatible TimeCube color spaces by RGBS
*added*
  • Filtering: "fieldmatch + yadif + deint + decimate2" as IVTC through FFmpeg method.
*removed*
  • Vapoursynth: support for mClean due to missing TemporalMedian library. (MacOS only)
Cu Selur
Old 15th October 2020, 10:23   #3640  |  Link
Gravitator
Hybrid v2020.10.11.1
x265
Enabled hevc-aq and disabled psy-rd results no-hevc-aq (In the MInfo output file).
Win10x64, Xeon E5450, GTX 750 2GB, DDR3 8GB.
Gravitator is offline   Reply With Quote
