Old 1st June 2010, 17:44   #181  |  Link
Selur
Selur's Avatar
No need to thank me I'm happy that you are testing it at all.
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 2nd June 2010, 02:22   #182  |  Link
ckmox
i got an error
Analysing finished.
Added new job with id: 09_16_33_500
09_16_33_500_01_audio: mp4Box started...
09_16_33_500_02_audio: NeroAACEnc started...
09_16_33_500_03_cleanUp: "C:\DOCUME~1\ios\LOCALS~1\Temp\a_und_aid_0__09_16_33_500_01.aac"
09_16_33_500_04_video: x264 (1 pass) encoding started...
x264 [info]: using cpu capabilities: MMX2 SSE2Slow
x264 [info]: profile High, level 4.1
C:\DOCUME~1\ios\LOCALS~1\Temp\a_09_16_33_500_04.264 too small
09_16_33_500_04_video: Processing aborted,...ERROR: C:\DOCUME~1\ios\LOCALS~1\Temp\a_09_16_33_500_04.264 is too small!
ckmox is offline   Reply With Quote
Old 2nd June 2010, 08:06   #183  |  Link
Selur
Selur's Avatar
@ckmox: sadly, the error report you posted doesn't help me at all. No version info nothing about the configuration you used,...
from the first post of this thread:
Important info needed to fix&reproduce bugs:
1. What Hybrid version did you use?(Windows/Linux 32/64bit + versions number)
2. What did happen? If an error message came up what did it exactly say?
3. What did you do to get to the bug? (best thing is a detailed step-by-step guide so that I can reproduce the problem)
4. Debug output would be helpful. (misc->misc settings->create debug file)
5. If possible a small sample file would be great. (upload it somewhere and send me a link via pm)
All these infos might be needed to reproduce the problem and reproduction is needed to find a fix.
If you find a bug, I'll try to fix it and send you a hopefully fixed version for testing via pm.
Problem is probably related to the decoding or encoding call used, but without at least knowing how these look like I can't really fix it.
One general thing:
I forgot to post the windows 32bit package update in the first post on th 29th of may.
-> Hybrid32bitPackage_100529 this might already fix the problem.
Old 5th June 2010, 16:37   #184  |  Link
Selur
Selur's Avatar
Hybrid ver.100605
*fixed*
- autocrop not using absolute path during to mplayer
- 'cropToDar' - option
- 'noMuxAndSplit' - option
- setting chapter start time on sources without chapters
- mixup when minimizing x264 command line
- subtitle extraction from a dvd which has an unknown language
- audio preview not working for raw audio only input
- accidently changed quality when changing audio gain manually
- Hybrid not reacting when loading non-media input
*added*
- some additional resolution checks before job creation
- experimental 'Blu-ray input' (PLALIST folder) and .mpls input support (experimental since I can't test it properly due to lacking hardware&material)
*cosmetics*
- added some additional tooltips
*updated*
- windows package
(you need to enable Misc in the Main-Tab to enable the Misc-Tab)
'Reset Defaults' in Misc-Tab on first start
-> updated links in 1st post
Old 5th June 2010, 16:43   #185  |  Link
CpT
The download links are broken for the below files:
Hybrid - only:
Hybrid Win32: http://www.selur.info/hybrid/Hybrid_100605.zip
Hybrid Win64: http://www.selur.info/hybrid/Hybrid_100605_64bit.zip
CpT is offline   Reply With Quote
Old 5th June 2010, 16:44   #186  |  Link
Selur
Selur's Avatar
doh,... forgot to update the files on my webspace -> should all be wokring in about 2min (links should work now)
Old 5th June 2010, 16:53   #187  |  Link
CpT
The link is working now,
Testing now
Edit:
Working great thus far!
Old 5th June 2010, 17:32   #188  |  Link
Selur
Selur's Avatar
fixed the missing ']' in the windows package link
Old 5th June 2010, 17:51   #189  |  Link
CpT
The only thing I noticed "not a bug" is when encoding up multiple files at once the progress bar on the jobs tab jumps quickly between the 2 encoding job's progress.
Its no big deal and its rather funny to watch... Guess I'm a bit bored atm...
This may have also been the case with previous versions I just never noticed it before.
Here's a screenshot showing the location.
Old 5th June 2010, 17:54   #190  |  Link
Selur
Selur's Avatar
yup, ment to fix that for quiet some time, but always forgot to put it on my todo list -> wrote it down now (probably will look at it tomorrow, since it's nice weather here and bbq is calling )
Old 5th June 2010, 22:32   #191  |  Link
SilverL
I dont get any audio streams/audio information. Been using the last few latest versions(currently 100605). I have all applications installed and up to date. Using Linux(Ubuntu) 64bit.
This is the log. Dont know if it will be helpful.
Log Messages
analysing: /home/lomarb/Videos/RvBEdit.mp4
grabbing audio ids ...
found audio ids:
analysing audio streams...
analysing audio streams with mplayer
grabbing video ids for: /home/lomarb/Videos/RvBEdit.mp4
video ids found:
analysing video streams...
Audio changed to:
Video delay: 0
Audio changed to:
Video delay: 0
Video changed to:
Format: AVC
Bit rate: 896
Frame rate: 29.97
Resolution: 640x360
Interlacing: progressive
Aspect ratio: 1
Frame count: 2818
Audio changed to:
Video delay: 0
Video changed to:
Frame count: 2898
Audio changed to:
Video delay: 0
Analysing finished.
Also tried with an Mkv and hybrid would freeze.
SilverL is offline   Reply With Quote
Old 5th June 2010, 22:39   #192  |  Link
Selur
Selur's Avatar
Most of the audio analysis is done through mplayer, so it's probably a problem with mplayer or mplayers output.
Please activate debug output (Config->Misc settings->General->Create debug file) before loading the source and send me the debug file.
Also make sure you reset the default settings before using the latest version. (Config->'Reset Defaults'button)
Cu Selur
Ps.: just did a test on my Ubuntu 64bit build system -> worked fine there,...
Old 7th June 2010, 05:27   #193  |  Link
SilverL
It was in fact mplayer. I put in a new ppa that uses the latest version. Its working again now. Thanks.
Old 7th June 2010, 07:54   #194  |  Link
Selur
Selur's Avatar
Happy to help.
Old 7th June 2010, 22:06   #195  |  Link
Selur
Selur's Avatar
Hybrid ver.100607
*fixed*
- crash on close&autocrop
- parallel job: progress bar flickering
*changed*
- enable mplayer osb during preview
Old 14th June 2010, 07:56   #196  |  Link
flebber
Practising Schemer
I was trying to encode a multi episode dvd with your latest version of Hybrid today but it was crashing before it started. I have uploaded the log file as it would be too big to display properly on the forum.
http://www.mediafire.com/file/1dj1wi...ebugOutput.txt
flebber is offline   Reply With Quote
Old 14th June 2010, 08:30   #197  |  Link
Selur
Selur's Avatar
On what OS are you using Hybrid? Fixed some bugs that might be related to your crash a few days ago and would send you my current development version.
Old 14th June 2010, 08:58   #198  |  Link
flebber
Practising Schemer
Windows Xp Sp3, says its 100607. On startup i get this log.
Version 5.1.2600 Service Pack 3 Build 2600
Log Messages
avcLevel value "3.2" is not present in current list
bFramePyramid value "normal" is not present in current list
X264 settings
x264 --crf 21 --level 3.2 --ref 5 --b-bias 2 --qpmin 1 --partitions i4x4,p8x8,b8x8 --me umh --subme 8 --psy-rd 0.8:0.2 --no-fast-pskip --aq-mode 2 --vbv-maxrate 0 --vbv-bufsize 0 --pic-struct --deblock 0:-1 --fps 25 --output OUTPUTFILE - 48x48
Old 14th June 2010, 23:24   #199  |  Link
Selur
Selur's Avatar
Hybrid ver.100614
*changed*
- icon with a higher resolution
*added*
- option to 'set default' audio/subtitle track in mkv
- video speed up option (this will change the duration of the clip)
*fixed*
- sox down-/upMix calls
- scale framerate changed speed and didn't drop/add frames when used with mencoder as decoder
- crash related to "import chapters on source change"
Old 15th June 2010, 00:35   #200  |  Link
ckmox
just a question when i set "Tune" to "Animation" and click Apply button repeatedly is the frames and b-frames for example needed to be incremented? or its some sort of a bug? i have limited knowledge on x264 btw so im wondering about this
thanks
