Old 6th February 2012, 17:29   #1  |  Link
EpheMeroN
EphMan
DVDSubEdit and subtitle delays
Can DVDSubEdit adjust the delays for subtitles?
I use this app to adjust the positioning of my subs and / or the colors after I mux together my dvd files. However, I have subs right now that need to be adjusted by appx. 1 sec. If DVDSubEdit can do this, please advise?
Thanks guys!
EpheMeroN is offline   Reply With Quote
Old 6th February 2012, 17:30   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
Yes, read the manual, it's actually simple to do it.
Born in the USB (not USA)
Old 6th February 2012, 18:19   #3  |  Link
EpheMeroN
EphMan
Well, I found how to edit ALL subs by X delay. However, I keep receiving an error randomly which says "Couldn't locate an empty slot". What does this mean?
Old 6th October 2012, 07:12   #4  |  Link
jeanl
jeanl's Avatar
This is an error that should not happen (hence the cryptic message) ... It means, though, that DVDSubEdit had a hard time finding an LBA to put the subpic in. As I said, it's probably a bug.
Jeanl
A few PgcEdit guides.
DVDSubEdit a free tool to edit subtitles directly inside the vob.
jeanl is offline   Reply With Quote
Old 8th October 2012, 10:39   #5  |  Link
Ghitulescu
Ghitulescu's Avatar
I don't think it's a bug. It seems that in this case, DSE simply skips the affected subtitle.
Old 16th April 2013, 13:03   #6  |  Link
Ghitulescu
Ghitulescu's Avatar
It appears that the new version, 1.52, does a horrible thing on this matter - the already aligned subtitles remains in synch, but those coming after the message (which doesn't even mention the subtitle number, to find the "offender" easier) are wrongly delayed.
If I may ask, does the program starts "intelligently" (AKA from the end for + delays, and from the beginning for - ones)? This assures a quick check, in case of overlapping (say over cell/PGC boundaries) ... useful since the program has no UNDO .
If not, maybe in a future version?
adjust, delay, positioning, subtitles
