22nd January 2013, 22:32 | #1001 | Link |
I have a "problem" with BD3D2MK3D (with the Tangled 3D BluRay).
Opening the resulting avs file created by BD3D2MK3D in any other program than avs2yuv results in "Can't create the graph". Is there any way to preview the avs file? EDIT: On Win7 64 Bit |
22nd January 2013, 22:41 | #1002 | Link |
PgcEdit daemon
The problem is that the program MUST be in the "magic folder" (containing the third-party tools used by BD3D2MK3D). That folder must have the stereoscopic player exe in its path. You can try to move or copy your program in that folder, and launch it from that location. That works well with AvspMod.
Note also that you cannot seek to any position with your program. The AVS script prohibits it, so if you try to do it, it will take a very long time. That means also that if the program tries to skip some frames to respect the frame rate, it may fail.
22nd January 2013, 22:56 | #1003 | Link |
Ah, thanks for the fast answer, I'll give that a try.
I just wanted to try to benchmark the different resize filters for this purpose and try Didee's suggestion to use bicubic resize with b+2c=0 for downsizing, e.g. b=-0.5, c=0.25 . |
22nd January 2013, 23:09 | #1004 | Link |
PgcEdit daemon
Good idea. Please let us know your benchmark results.
24th January 2013, 12:55 | #1005 | Link |
Well, I guess my CPU works hard for the decoding so the speed does not differ that much, but here are my quick results:
Untouched = 51.694904 fps BilinearResize(1920, 1080) = 48.070914 fps BicubicResize(1920, 1080) = 47.461295 fps BicubicResize(b=-0.5, c=0.25, 1920, 1080) = 47.623734 fps BicubicResize(b=-1.0, c=0.5, 1920, 1080) = 47.331453 fps BlackmanResize(1920, 1080) = 44.079143 fps GaussResize(1920, 1080) = 43.927917 fps LanczosResize(1920, 1080) = 45.933014 fps Lanczos4Resize(1920, 1080) = 44.493882 fps PointResize(1920, 1080) = 48.224223 fps Spline16Resize(1920, 1080) = 46.986299 fps Spline36Resize(1920, 1080) = 45.716445 fps Spline64Resize(1920, 1080) = 44.302872 fps SincResize(1920, 1080) = 44.246743 fps Code:
SetMemoryMax(128) LoadPlugin("E:\Treiber\BD3D2MK3D\toolset\stereoplayer.exe\ssifSource2.dll") part1 = ssifSource2("L:\BDMV\STREAM\SSIF\00012.ssif", 85384, left_view = true, right_view = true, horizontal_stack = false) part2 = ssifSource2("L:\BDMV\STREAM\SSIF\00013.ssif", 58864, left_view = true, right_view = true, horizontal_stack = false) last = part1 + part2 AssumeFPS("ntsc_film") RESIZE Trim(0,-30000) Last edited by Rumbah; 26th January 2013 at 17:23. |
24th January 2013, 14:20 | #1006 | Link |
PgcEdit daemon
Thanks!
What are the units of the results?
24th January 2013, 14:26 | #1007 | Link |
PgcEdit daemon
Someone has used the 2-pass encoding mode of BD3D2MK3D? I don't use it, but I did some tests, and apparently, x264 crashes at the very end of the first pass, because the output file is "NUL". I have decided to redirect the output to NUL to avoid writing an useless big h264 file on HDD, but perhaps it is required to have a real file as output. Strangely, x264 doesn't crash when I do a quick test with a short clip.
Someone can confirm that bug, or it it just me?
28th January 2013, 17:51 | #1009 | Link |
Do you have a new version of DirectShowMVCSource ? Or ssif2source is always up to date with news movies ?
I would like to create 1 AVS to left eye and 1 AVS to right eye, DirectShowMVCSource seems to be perfect for that but I have random crash... Last edited by Nico8583; 28th January 2013 at 18:10. |
29th January 2013, 23:52 | #1010 | Link | ||
I always receive this error on various Blu-ray
can't create the graph error line 81 my AVS Quote:
thanks Last edited by pippus; 29th January 2013 at 23:54. |
30th January 2013, 02:57 | #1011 | Link |
French Love
Would it be possible to add support for mkv in combination with CombineMVC.exe by DirectShowMVCSource ?
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
30th January 2013, 12:02 | #1013 | Link | |
PgcEdit daemon
Also, are you sure the BD is unprotected? Usually, you cannot rip directly a protected BD. You have to either decrypt it to an ISO and mount the ISO, or use AnyDVD HD to decrypt the BD on the fly. eac3to is not a decrypter, and therefore, BD3D2MK3D requires an unprotected DVD or a mounted ISO as source.
30th January 2013, 16:01 | #1014 | Link |
French Love
Oui, pour la prise en charge des pistes audio et sous titres forcés et aussi les châpitres.
Yes, for support audio tracks and subtitles as forced and chapters.
30th January 2013, 16:03 | #1015 | Link | |||
I tried to aprtire GraphEdit but AVC / MVC decoder (by CoreCodec) do not find |
31st January 2013, 02:51 | #1017 | Link |
French Love
Make MKV is already doing.
The goal would be to read .MKV AVC/MVC directly with MVC Player Free
4th February 2013, 20:56 | #1018 | Link | |
Is there a specific reason to flag the encode as interlaced (--fake-interlaced)? |
5th February 2013, 12:52 | #1019 | Link |
PgcEdit daemon
Honestly, I don't know. Perhaps it's a blu-ray requirement. But I'm not a specialist in x264 encoding, especially for blu-ray. Lord Mulder is certainly much more able to reply than me. See the last sentence in this post, and my reply...
6th February 2013, 00:25 | #1020 | Link | |
French Love
