Old 19th January 2017, 01:44   #1  |  Link
Katie Boundary
Katie Boundary's Avatar
XviD overshooting target file size
Is there anything, other than user error, that could cause a 2-pass XviD encode to exceed its intended file size? In particular, will it overshoot if the target file size is "too low" for the video's resolution, frame rate, and amount of motion? I just had to set the target amount of video data to 280 mb in order to get the actual amount of data down to ~310 mb (with audio adding another ~40 mb for a total file size of 350 mb).
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 19th January 2017, 10:38   #2  |  Link
Dont know, but TmpGenc mpeg used to have a minimum bitrate that it would not go below (and would not tell you that it was going to ignore your settings).
(about 200kb/s I think, for mpeg)
Old 20th January 2017, 20:35   #3  |  Link
Selur
Selur's Avatar
@Katie Boundary: try setting overflow treatment settings all to 10% instead of the default 5%.
Old 14th February 2017, 14:16   #4  |  Link
Katie Boundary
That helped somewhat.
Old 15th February 2017, 07:05   #5  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Any particular reason you're still encoding MPEG-4 ASP in 2017?
Mainly I'm just curious
Old 15th February 2017, 22:08   #6  |  Link
fantasmanegro
Old DVD player compatibility as I do?
fantasmanegro is offline   Reply With Quote
Old 17th February 2017, 08:03   #7  |  Link
Katie Boundary
What is ASP?
Old 17th February 2017, 15:08   #8  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Originally Posted by Katie Boundary View Post
What is ASP?
Advanced Simple Profile, of course.
https://en.wikipedia.org/wiki/MPEG-4...file_.28ASP.29
Midzuki is offline   Reply With Quote
Old 18th February 2017, 13:16   #9  |  Link
Selur
Selur's Avatar
@Katie Boundary: also make sure qmin=1 and qmax = 51
Old 18th February 2017, 17:35   #10  |  Link
Midzuki
Unavailable
Midzuki's Avatar
I think you meant qmin=2 and qmax=31
Old 19th February 2017, 22:49   #11  |  Link
Katie Boundary
Oh. No, I don't bother with profiles. I always set the profile to unrestricted.
Old 19th February 2017, 23:13   #12  |  Link
Groucho2004
So why are you using such an inefficient encoder?
Groucho's Avisynth Stuff
Old 20th February 2017, 09:33   #13  |  Link
Katie Boundary
If I tell you, would that make it easier for you to figure out why XviD is misbehaving?
Old 20th February 2017, 10:00   #14  |  Link
Groucho2004
What makes you think it's misbehaving? When you set all parameters the xvid library exposes correctly it will hit the desired bitrate unless you're trying something silly like encoding a series of black images into a 10Mbps video.
Besides, this question has been asked hundreds of times in the last ~15 years. A simple google search ("xvid undersized site:forum.doom9.org") would have provided the same answers you got in this thread and a lot more suggestions to solve the problem.
Old 21st February 2017, 17:37   #15  |  Link
fantasmanegro
What gui or software are you using for xvid encoding?...
Old 28th February 2017, 19:04   #16  |  Link
hello_hello
Yeah, but don't you knock up a quick copy for DVD player viewing with Xvid single pass encoding, or 2 pass encoding if you're really keen, using the x264 encode you ran for archiving as the source?
Old 28th February 2017, 22:24   #17  |  Link
fantasmanegro
i guess not... if you have an old 26" crt tv at home
Old 6th March 2017, 09:24   #18  |  Link
Selur
Selur's Avatar
No, I meant qmin=1 and qmax=31.
Old 13th April 2017, 01:59   #19  |  Link
Katie Boundary
The part where I tell it to aim for one bitrate and it gives me a completely different bitrate even though I'm not feeding it pathological content.
Virtualdub.
Old 13th April 2017, 09:30   #20  |  Link
Groucho2004
Read the second paragraph of my post and try the various suggestions. This can't be solved by guessing what might be wrong with your setup, there are too many variables.
You could of course upload your source so one of us could try but that seems rather excessive for such a trivial problem.
p.s. What version of xvid are you using?
