Old 17th April 2016, 11:25   #121  |  Link
Groucho2004
For science!
Ah, OK. I can relate to that.
Old 17th April 2016, 15:31   #122  |  Link
asarian
Is this still in development? I could see myself 'hack' a copy of the QTGMC script to use this OpenCL-nnedi3, instead of the original one. Seems it's 3 years old, though.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 19th June 2016, 15:33   #123  |  Link
luigizaninoni
and still no 64-bit version ? Avisynth+ 64-bit is very stable now
luigizaninoni is offline   Reply With Quote
Old 16th August 2016, 18:24   #124  |  Link
yup
Originally Posted by yup View Post
High all!
Lucky life continue until Geforce driver updated to 362.00.
See error during load simle script in VirtyualDub
https://www.dropbox.com/s/k4gsunhr29...diocl.png?dl=0
Language my windows is Russian.
Translation Video driver do not respond and was recovered,
Video driver Nvidia Windows Kernel Mode Driver , Version 362.00 do not respond and was recovered.
Any suggesrtions, please.
yup.
After upgrade to Avisynth+, I am try this plugin one more and find in old plugin directory file nnedi3ocl.clb. I am copy all files excluding one, and now all work fine.
yup.
yup is offline   Reply With Quote
Old 30th September 2016, 02:33   #125  |  Link
edcrfv94
anti-aliasing need nsize=6, qual=2, pscrn=4, nns=4, nnedi3ocl will any plan completely relaced nnedi3?
edcrfv94 is offline   Reply With Quote
Old 5th November 2016, 09:49   #126  |  Link
TheProfosist
TheProfosist's Avatar
I cant seem to get this to do anything it just crashes AvsPmod everytime I add it.
TheProfosist is offline   Reply With Quote
Old 11th January 2021, 12:49   #127  |  Link
misakitchi
I modded Santiag script (Anti-Aliasing) to use NNEDI3ocl and its very good! Thanks!
Is there a new version of NNEDI3ocl since 2013...??
I find this page:
https://github.com/zachsaw/MPDN_Exte...pts/OCL_NNEDI3
Are thoses 2 files updated/better?
Edit:
I tested the "new" version of MPDN from zachsaw
And i have Error!
"nnedi3ocl: can't allocate OpenCL Resources"
So i keep the original version
PS: My Computer: AMD FX-8350 + Radeon HD 7800 Series
If someone is interested in my modded Santiag script, i can give the code here
# santiag v1.6
# Simple antialiasing
# OpenCL MOD
# santiagocl(strh=0, strv=0, type="nnedi3", nns=1,  nsize=0, halfres=false, scaler_post="Spline36Resize")
# Note: variable "threads" was removed
# This program is free software. It comes without any warranty, to
# the extent permitted by applicable law. You can redistribute it
# and/or modify it under the terms of the Do What The Fuck You Want
# To Public License, Version 2, as published by Sam Hocevar. See
# http://sam.zoy.org/wtfpl/COPYING for more details.
# type = "nnedi3", "eedi2", "eedi3" or "sangnom"
# "eedi3" requires v0.9.2 or later
# "sangnom" requires sangnom2
Function santiagocl (clip c, int "strh", int "strv", string "type", int "nns", int "aa", int "aac", int "nsize", int "vcheck", int "fw", int "fh", bool "halfres", string "scaler_post", int "maskt", string "typeh", string "typev")
	strh        = Default (strh,                       1)
	strv        = Default (strv,                       1)
	type        = Default (type,                "nnedi3")
	typeh       = Default (typeh,                   type)
	typev       = Default (typev,                   type)
	halfres     = Default (halfres,                false)
	scaler_post = Default (scaler_post, "Spline36Resize")
	c
	w   = Width ()
	h   = Height ()
	fwh = (strv < 0) ? fw : w
	fhh = (strv < 0) ? fh : h
	(strh >= 0) ?             santiag_dir (strh, typeh, halfres, scaler_post, nns=nns, aa=aa, aac=aac, nsize=nsize, vcheck=vcheck, maskt=maskt, fw=fwh, fh=fhh)              : last
	(strv >= 0) ? TurnLeft ().santiag_dir (strv, typev, halfres, scaler_post, nns=nns, aa=aa, aac=aac, nsize=nsize, vcheck=vcheck, maskt=maskt, fw=fh,  fh=fw ).TurnRight () : last
	fwx = Default (fw, w)
	fhx = Default (fh, h)
	(strh < 0 && strv < 0) ? Eval (scaler_post + " (fwx, fhx)") : last
Function santiag_dir (clip c, int strength, string type, bool halfres, string scaler_post, int "nns", int "aa", int "aac", int "nsize", int "vcheck", int "maskt", int "fw", int "fh")
	c
	w = Width ()
	h = Height ()
	fw = Default (fw, w)
	fh = Default (fh, h)
	multi = (IsYUV () && ! IsYV12 ())
	c_y = (multi             ) ?         ConvertToYV12 () : last
	c_u = (multi && ! IsY8 ()) ? UToY ().ConvertToYV12 () : last
	c_v = (multi && ! IsY8 ()) ? VToY ().ConvertToYV12 () : last
	c_y =                        c_y.santiag_stronger (strength, type, halfres, multi, nns=nns, aa=aa, aac=aac, nsize=nsize, vcheck=vcheck, maskt=maskt)
	c_u = (multi && ! IsY8 ()) ? c_u.santiag_stronger (strength, type, halfres, true , nns=nns, aa=aa, aac=aac, nsize=nsize, vcheck=vcheck, maskt=maskt) : c_u
	c_v = (multi && ! IsY8 ()) ? c_v.santiag_stronger (strength, type, halfres, true , nns=nns, aa=aa, aac=aac, nsize=nsize, vcheck=vcheck, maskt=maskt) : c_v
	  (multi && ! IsY8 ()) ? YToUV (c_u, c_v, c_y)
\	: IsY8 ()              ? c_y.ConvertToY8 ()
\	:                        c_y
	Eval (scaler_post + " (fw, fh, src_left=0, src_top=(halfres)?0:0.5, src_width=Width (), src_height=Height ())")
Function santiag_stronger (clip c, int strength, string type, bool halfres, bool lumaonly, int "nns", int "aa", int "aac", int "nsize", int "vcheck", int "maskt")
	strength = (strength < 0) ? 0 : strength
	field = strength % 2
	dh = (strength <= 0 && ! halfres)
	(strength > 0) ? c.santiag_stronger (strength - 1, type, halfres, lumaonly, nns=nns, aa=aa, aac=aac, nsize=nsize, vcheck=vcheck, maskt=maskt) : c
	  (type == "nnedi3" ) ? santiag_nnedi3  (dh, field, lumaonly, nns=nns, nsize=nsize)
\	: (type == "eedi2"  ) ? santiag_eedi2   (dh, field)
\	: (type == "eedi3"  ) ? santiag_eedi3   (dh, field, lumaonly, nns=nns, nsize=nsize, vcheck=vcheck, maskt=maskt)
\	: (type == "sangnom") ? santiag_sangnom (dh, field, aa=aa, aac=aac)
\	: Assert (false, "Santiag: unexpected value for type.")
# NNEDI3 OpenCL
Function santiag_nnedi3 (clip c, bool dh, int field, bool lumaonly, int "nns", int "nsize")
	c.nnedi3ocl (dh=dh, field=field, nns=nns, nsize=nsize, u=!lumaonly, v=!lumaonly)
Function santiag_eedi2 (clip c, bool dh, int field)
	c
	w = Width ()
	h = Height ()
	(dh) ? last : PointResize (w, h / 2, 0, 1-field, w, h)
	eedi2 (field=field)
# maskt = 24
Function santiag_eedi3 (clip c, bool dh, int field, bool lumaonly, int "nns", int "nsize", int "vcheck", int "maskt")
	chroma = (lumaonly) ? 1 : 3
	sclip = c.santiag_nnedi3 (dh, field, lumaonly, nns=nns, nsize=nsize)
	mclip_flag = (Defined (maskt) && maskt > 0)
	mclip = (mclip_flag && dh) ? sclip.BicubicResize (c.Width (), c.Height (), src_top=0.5-field) : sclip
	mclip = (mclip_flag)
\	?	mclip.mt_edge (mode="1 2 1 0 0 0 -1 -2 -1 1", thY1=0, thY2=255, u=chroma, v=chroma)
\			.mt_binarize (threshold=maskt, y=3, u=chroma, v=chroma)
\			.mt_expand (y=3, u=chroma, v=chroma)
\	:	santiag_undef ()
	c.eedi3 (dh=dh, field=field, vcheck=vcheck, sclip=sclip, mclip=mclip, u=!lumaonly, v=!lumaonly)
Function santiag_sangnom (clip c, bool dh, int field, int "aa", int "aac")
	c
	w = Width ()
	h = Height ()
	(dh) ? Spline36Resize (w, h * 2, 0, -0.25, w, h) : last
	SangNom2 (order=field, aa=aa, aac=aac)
Function santiag_undef () { }
misakitchi is offline   Reply With Quote
Old 12th January 2021, 17:44   #128  |  Link
Kisa_AG
Yes, please!
Kisa_AG is offline   Reply With Quote
Old 13th January 2021, 01:28   #129  |  Link
kedautinh12
Originally Posted by Kisa_AG View Post
Yes, please!
Code he was posted above
Old 20th June 2022, 16:00   #130  |  Link
mogobime
x64 / 64 bit version of nnedi3ocl
Originally Posted by SEt View Post
As there is no usable x64 Avisynth no x64 version for now. This plugin wouldn't benefit from it anyway.
nnedi3ocl is basic functionality implemented as plugin. nnedi3x and nnedi3x_rpow2 scripts that extended beyond that. Basically, what is reasonable to do in script should be done in script.
GTX 560 should work just fine. Slower than similar Radeons or CC2.0 cards, but still ok.
First a few words to myself and why I try to contact you. I'm currently writing a script, which tries to calculate prefetches for every single filter (which is worth to be "extra" prefetched) in an avisynth+ script with the help of a constantly growing database which contains how many threads a filter normally creates per prefetch to not overload the cpu in complex scripts.
Such AviSynth+ scripts with prefetches set after every filter sometimes seem to be even faster than VapourSynth scripts using the same filters.
So I think AviSynth+ is still noteworthy nowadays, especially for non high end systems.
Since times have changed and AviSynth+ 64 bit works great and is really fast if filter prefetching is used correctly, I wanted to ask you if you see any chance to port nnedi3ocl to 64 bit, so it can be used in an 64 bit environment which can address more than 3 GB of memory, which is necessary in times of 4K.
With current basic GPU hardware this might speed up many nnedi3 based filters in 64 bit AviSynth+ and also improve quality of filtering by abandoning the prescreener.
So it would be nice to hear from you.
cu, mogobime
X-QuaSaT - x264 Quality and Speed analyse Tool (multiple file analysation/average values/csv-output)
Benchmark-thread for x264 encoding with GPU-based OpenCL lookahead and DGDecNV GPU-based decoding
mogobime is offline   Reply With Quote
Old 19th November 2022, 06:41   #131  |  Link
kedautinh12
NNEDI3CL 1.0.5
https://github.com/Asd-g/AviSynthPlus-NNEDI3CL/releases
Old 28th November 2022, 04:21   #132  |  Link
kedautinh12
NNEDI3CL 1.0.6
