Old 6th February 2014, 19:17   #81  |  Link
BeNooL
BeNooL's Avatar
Results running version 2013.12.08-beta on a GTX 660 (1137MHz core clock, PCIe 3.0 @ x8) with an i7 3770 @ 4.0 GHz
FPS with MTMode(2,4):
Frames processed:               1000 (0 - 999)
FPS (min | max | average):      3.689 | 474957 | 14.96
CPU usage (average):            12%
Thread count:                   16
Physical Memory usage (peak):   563 MB
Virtual Memory usage (peak):    550 MB
Time (elapsed):                 000:01:06.858
FPS with no MTMode:
FPS (min | max | average):      10.59 | 14.93 | 14.68
Thread count:                   12
Physical Memory usage (peak):   276 MB
Virtual Memory usage (peak):    272 MB
Time (elapsed):                 000:01:08.134
BeNooL is offline   Reply With Quote
Old 1st July 2014, 16:12   #82  |  Link
dajaja
Hi everybody. I am am using nnedi3 with the ffdshow Avisynth plugin to deinterlace live TV (SD). The setup works pretty well, but performance is limiting nns to 0 or 1 and I would like to speed it up by switching to nnedi3ocl. My regular script is the following:
temp=nnedi3(field=3,nsize=6,nns=1,qual=1,etype=0,threads=16)
yadifmod(order=1, mode=1, field=0, edeint=temp)
I modified this to use nnedi3ocl as follows:
temp=nnedi3ocl(field=3,nsize=0,nns=1,qual=1,etype=0)
Now, all I get is an interlaced image with strong ghosting. Screenshots are attached. I played with many settings, but nothing eliminates the ghosting. Avisynth is version 2.6 MT, video card is a Radeon 7790 on Catalyst 14.4.
What could be the problem?
dajaja is offline   Reply With Quote
Old 2nd July 2014, 09:58   #83  |  Link
BeNooL
BeNooL's Avatar
At the risk of being off topic, have you given QTGMC a try ? see http://forum.doom9.org/showthread.php?t=156028
Given it is SD content, running it live might work with moderate quality preset.
Old 2nd July 2014, 21:51   #84  |  Link
dajaja
Yes, thanks. I have tried it before and it works with the "Very Fast" preset - but only until it crashes Seems to be an MT problem and I was not able to find a stable setting, yet. If I did, nnedi3ocl could be used in QTGMC, too to speed it up.
Old 14th July 2014, 17:20   #85  |  Link
i see about 5 times blended?? frame in the one frame you showed can you post a 5 sec sample?
Old 20th July 2014, 20:24   #86  |  Link
dajaja
I think I'd have to install extra software to capture it. But I don't see the advantage of looking at the video. The still shows the problem perfectly. The only thing missing is the info that if there is no movement in the video, there are of course no artifacts visible
Old 23rd August 2014, 04:57   #87  |  Link
Seedmanc
Is there any chance of this plugin going x64 bit? I'm using it in a chain of graphedit-ffdshow-avisynth as a custom upscaler for ps2 emulator and having both graphedit and ffdshow available in x64, this is the only thing keeping me in 32bit.
Also noticed a weird thing, there is no nnedi3ocl_rpow2, so I have to use that nnedi3x_rpow2 from .avsi, but at the same time AVSPmod suggests that there exist a "nnedi3ocl_nnedi3ocl" function and avisynth accepts it, so it indeed exist (does the same as nnedi3ocl).
I tried all 3 custom .cl files for NVidia posted here earlier, first two made no difference in speed for me, while 3rd (posted by madshi) gave error "Unable to allocate OpenCL resources". Is there no hope for GTX 560?
Seedmanc is offline   Reply With Quote
Old 23rd August 2014, 16:03   #88  |  Link
SEt
As there is no usable x64 Avisynth – no x64 version for now. This plugin wouldn't benefit from it anyway.
nnedi3ocl is basic functionality implemented as plugin. nnedi3x and nnedi3x_rpow2 – scripts that extended beyond that. Basically, what is reasonable to do in script – should be done in script.
GTX 560 should work just fine. Slower than similar Radeons or CC2.0 cards, but still ok.
SEt is offline   Reply With Quote
Old 23rd August 2014, 23:21   #89  |  Link
Originally Posted by SEt View Post
As there is no usable x64 Avisynth no x64 version for now. This plugin wouldn't benefit from it anyway.
so this doesn't work with avisynth+ ?
Old 24th August 2014, 00:37   #90  |  Link
SEt
It should work without problems, but Avisynth+ has no stable multithreading yet. Speed-wise now I would recommend AviSynth 2.6 with MTMode (in general, not for this plugin in particular).
Old 24th August 2014, 05:26   #91  |  Link
my question was more about 64 bit avisynth+.
or is it still not usable and I'm just lucky the hole time?
Old 24th August 2014, 10:38   #92  |  Link
Groucho2004
32 Bit plugins don't work with 64 Bit Avisynth and vice versa.
Old 24th August 2014, 18:23   #93  |  Link
i know that's why I ask.
or in short. avisynth+ 64 works fine for me but there is no 64 bit nnedi3 openCL.
and the reason is this:
Old 25th August 2014, 09:58   #94  |  Link
SEt
For me Avisynth is not usable without threading.
Old 25th August 2014, 17:05   #95  |  Link
SamKook
There is a version of avisynth+ with MT that apparently works(haven't tried it myself), there's just no official release for it.
Originally Posted by qyot27 View Post
I haven't really seen any more big reports of MT failing in the months since it appeared (in terms of its actual stability), save for the bounds checking issue with the audio cache that I reported in here and on Github. If I'm correct about that assessment, perhaps it's time to just bite the bullet and merge it to master and bump the version number to 0.2. The psychological effect of just going ahead and releasing it might help too.
P.S. It was a subtitle filter(SupTitle) that was failing in this case.
AMD Ryzen 9 5950X and EVGA RTX 3080 with G.skill 64Gb 3600 (2 16x2 kit) on Asrock X570 Taichi with Samsung 980 Pro 500Gb NVMe SSD running Win10 x64 on LG 34GN850-B 34.0" 3440 x 1440 160 Hz
SamKook is offline   Reply With Quote
Old 27th August 2014, 20:06   #96  |  Link
SEt
Last version of Avisynth+ I've tried had speed issues with threading rather than stability. My usual post-processing script run on it significantly slower (realtime -> not realtime). Maybe it's not hard to tweak the existing implementation for similar or better speeds, but regrettably I have absolutely no time now to dedicate there.
Old 10th December 2014, 14:06   #97  |  Link
yup
Hi All!
how I can use nnedi3ocl for conversion 25 Hz interlaced source to 50 Hz progressive. When using nnedi3 it is simple
nnedi3(field=-2)
When I use
nneedi3ocl(field=-2)
I see doubling framerate and frame quantity, frame from 1 to N see fine, but from N+1 to 2*N it is not changed, freeze frame N.
N number frame in interlaced source.
yup.
yup is offline   Reply With Quote
Old 10th December 2014, 17:56   #98  |  Link
SEt
yup, see pm.
Note: it looks like new AMD driver 14.12 broke some part of used OpenCL on HD6xxx hardware, so check other driver versions if you get corrupted results.
Old 12th January 2015, 23:14   #99  |  Link
TheProfileth
Leader of Dual-Duality
TheProfileth's Avatar
After updating my driver on my 7970 it also no longer works and instead produces weird results where only a fraction of the screen is actually intelligible.
I'm Mr.Fixit and I feel good, fixin all the sources in the neighborhood
My New filter is in the works, and will be out soon
TheProfileth is offline   Reply With Quote
Old 16th January 2015, 00:54   #100  |  Link
Asmodian
Sounds like they broke it on the 7970 as well.
