15th December 2004, 23:40 | #63 | Link | |
Swallowed in the Sea
Hi RobuX4,
It's good to see you here... Quote:
26th December 2004, 12:24 | #68 | Link |
Satsuki'S Softs Maker
any chance to get the autoloading of subtitle works ?
i also have some seeking lags (not cpu problem) and strange sound bug when seek with AAC+. i've none of these bugs with gabest splitter. also your splitter doesn't seems to realy work on 98/me, do you plan to devel that ? otherwise it's a good work, thanks for doing it. ++ |
26th December 2004, 22:44 | #69 | Link |
To display subs correctly, just use the vsfilter.dll you'll find here
http://haali.cs.msu.ru/mkv/ |
26th December 2004, 22:49 | #70 | Link |
MKVToolNix author
Guys, it's really great that you test Haali's new splitter. But Haali doesn't read this forum very often Therefore we'd like to ask you to post problems with his splitter to our mailing list: matroska-devel@lists.matroska.org (No need to subscribe first, just sent an email)
Thanks
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
10th January 2005, 19:22 | #71 | Link | |
new version
mkv with nero avc don't seek on my computer, it stop the video and i need to reload it. ++ |
10th January 2005, 20:19 | #72 | Link |
You have to specify the framerate during the muxing, if you want to play it correctly
And in the future, you'll always need the alternative vsfilter, which, i have to say, i find better thant gabest one (it displays sub's name of mkv files, not only their language |
10th January 2005, 22:12 | #73 | Link |
I think I just found some bugs in the 10.01.2005 build:
1)If I tried to open the "Matroska Splitter seetings" the first time, a pop up message came and asked for "rundll.exe". I manually linked it to its' location. 2)Although "Autoload VSFilter" is set to Yes, VSFilter doesn't autoload. (yes,the patcheed modified VSFilter is installed) 3)If I stop the playback in the Zoomplayer and then load the MKV file again, I get an error message: "Error:can't open file:80070020" Zoomplayer tells me: "Error 80070020 - Unable to create the "Matroska File" Filter- Der Prozess kann nicht auf die Datei zugreifen, da sie von einem anderen Prozess verwendet wird" (translated: the process can't grab the file because it is used by another process) After this message ZP hangs up! (never happened before, now for 2 years) In Graphedit: If I open a MKV file, Graphedit tells me: "The format of some files in the video aren't supported." (VSFilter?) After pressing ok, the graph is build up, but VSFilter isn't loaded. System: WinXP edit: (also mailed to the matroska mailinglist) Cu filewalker
I 'm ripping waves!...nothing else! \m/ Last edited by filewalker; 10th January 2005 at 22:35. |
10th January 2005, 22:17 | #74 | Link | |
10th January 2005, 22:23 | #75 | Link |
Believe me, only the patched version installed and registered in my system. I really take care what is registered in my system.
And the patched VSFilter has worked in all versions( ...,08.12.2004/15.12.2004/03.01.2005) of Mike's Matroska parser till I used the latest build. Cu
I 'm ripping waves!...nothing else! \m/ |
11th January 2005, 16:00 | #76 | Link | |
11/01/2005 Fix rundll32 path. 11/01/2005 Add another mediatype for A_REAL, it should play in MPC now. |
11th January 2005, 21:14 | #78 | Link | ||
So you see, we don't need the patched version in the future...although Toff's version has some adavantages, as you already wrote ... Cu
I 'm ripping waves!...nothing else! \m/ Last edited by filewalker; 11th January 2005 at 21:19. |
11th January 2005, 22:32 | #79 | Link | |
李姗倩 Lǐ Shān Qiàn
12th January 2005, 15:53 | #80 | Link |
李姗倩 Lǐ Shān Qiàn
typo
Autoloading VSFilter works fine for me on my Win2k.
Btw I found a small/trivial typo in the Dialogbox from splitter.ax (2005-01-11): [Start] - Programs - Haali Matroska Splitter - Matroska Splitter Propertie, compatibility - Autload VSFilter Should be Autoload Keep up a good job! Thank you =) |
