5th January 2010, 01:34 | #921 | Link | |
5th January 2010, 01:40 | #922 | Link | |
Wait... you said 4670. Still interesting. Yep, tested with another DVD, this time disabling manually HW accel and dropouts still there. DD stereo track. Last edited by Andy o; 5th January 2010 at 01:47. |
5th January 2010, 01:42 | #923 | Link |
So I can't really test my 4850. With software decoding, that machine really isn't fast enough to handle it. It pegs my CPU at like 95% and skips/drops/etc all over the place. I can't trust those results. With DXVA, flawless. How I wish we had a DTS-HD MA decoder cause the sound rocks, too. If I get the Onkyo 606 fixed and hooked up in there, I'm gonna have to figure out how to get the Xonar in that case and not fry the machine in the process. Either that or get a cheap 5xxx card for it.
5th January 2010, 01:52 | #926 | Link | |
5th January 2010, 02:05 | #927 | Link | |
5th January 2010, 03:18 | #929 | Link | |
Old fart
Mark
Oh no Mr. Bill! |
5th January 2010, 14:22 | #931 | Link |
Ok, a little bird told me what I was missing on my setup for the Xonar to bitstream. Now that I fixed that, I'm "finally" getting the exact same issue as the 5xxx card with my Pio. The DTS-HD MA flashes and no audio. TrueHD works. So, we know it's not the bitstream type that's causing it, at least. albain, I'll get some logs up here shortly.
5th January 2010, 14:35 | #932 | Link |
http://pastebin.com/pastebin.php?dl=m3794f3d0
This is the same DTS-HD MA 7.1 track I've been trying with.
5th January 2010, 14:43 | #933 | Link |
To go along with this, here are the properties the ArcSoft renderer is getting from ffdshow:
wFormatTag: 577 nChannels: 8 nSamplesPerSec: 192000 nAvgBytesPerSec: 3072000 nBlockAlign: 16 cbSize: 0 Code:
wFormatTag: 577 nChannels: 8 nSamplesPerSec: 192000 nAvgBytesPerSec: 3072000 nBlockAlign: 16 wBitsPerSample: 16 cbSize: 0
5th January 2010, 16:43 | #934 | Link |
Media Control author
Okay, the media structures are not in cause.
So the bitstream is @Sebastii : could you make dumper logs with the same DTS-HD MA sample in the 2 following configs : 1/ TMT3 + xonar 2/ FFDShow in xonar mode + Arcsoft renderer We should get the exact same timestamps and media structures and bitstreams but I guess this is not the reality. Thank you |
5th January 2010, 16:47 | #935 | Link |
Yea, Xonar + TMT3 works perfectly, just as with the ATI and PDVD9. Yet either card with ffdshow gives me the exact same flashing DTS-HD MA result. TrueHD works with both, so, it appears to be something in the DTS-HD MA bitstream from ffdshow that's causing it. I hope Seb is able to get you the info you need. At least we're narrowing it down a little.
5th January 2010, 20:12 | #938 | Link |
yes i hope too
So the log : 1/ TMT3 + xonar : DTS-MA-Xonar-TMT3 2/ FFDShow in xonar mode + Arcsoft renderer : DTSMA_MPC_FFDSHOW_ARCSOFT I hope that the log are good Thx, Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
5th January 2010, 20:16 | #939 | Link |
Thanks. I'm going to take a peak at them now. Not sure if albain's around or not. I doubt there's much I can do with these logs but it doesn't hurt to look.
5th January 2010, 20:22 | #940 | Link |
Ah, Seb, you da man! The bitstream data is identical between the two. *HOWEVER*....
TMT3: Code:
19:54:14-330 DumpWFEX WAVEFORMATEX wFormatTag : WAVE_FORMAT_PCM Channels : 2 Bits per sample : 16 Samples per second :48000 nBlockAlign : 4 Code:
WAVEFORMATEX wFormatTag : 577 Channels : 8 Bits per sample : 16 Samples per second :192000 nBlockAlign : 16
