Old 17th November 2010, 20:59   #10221  |  Link
m.rup
Maybe I used the wrong words. Correctly said:
I don't know if the audio tracks are present after the encode.
I definitely know that I am not able to select them in the language menu of the disc on my Panasonic BD60, FW 2.5, when they where not selected in the setup menu.
m.rup is offline   Reply With Quote
Old 17th November 2010, 21:58   #10222  |  Link
jdobbs
Originally Posted by wooper View Post
Does the file "00001.track_4608.SUP" exist in the working folder?
Hi
well i dunno, i do the same thing i do when i rebuild a movie, just select the source, the output and after that i just press the button, nothing else
What I was asking was for you to look in the folder and see if it was there. That would at least clear up whether it was an issue with the command, or with the reencode itself.
Website: www.jdobbs.net
Old 17th November 2010, 22:05   #10223  |  Link
ironmike
@ironmike
That error (00075) is a "path access error". When gotten at 1605 (the program position) it appears that the work path has either been corrupted or the drive can't be accessed for some reason.
Deleted and recreated "working" folder, backup successful, thanks. For future reference, how do I create a test record?
ironmike is offline   Reply With Quote
Old 17th November 2010, 22:12   #10224  |  Link
Capsbackup
If you mean Inspect ?, just look inside the folder that has BD-RB, you will see a file named Inspect. Open that file and click Inspect, and it will tell you if all the associated programs for BD-RB are correctly installed.
Capsbackup is offline   Reply With Quote
Old 18th November 2010, 02:44   #10225  |  Link
setarip_old
setarip_old's Avatar
@omegaman7
Hi!
I am running 35.01. I'm a firm believer if it ain't broke don't fix it. But I have been considering moving on to the newest version.
If you keep in mind that the sole purpose of this thread is beta testing the program, you should understand that you should always be using the most recent version...
setarip_old is offline   Reply With Quote
Old 18th November 2010, 03:59   #10226  |  Link
jdobbs
BD Rebuilder v0.36.03 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.36.03). Changes for this version:
- Added a new hidden option for specifying the HC
  Encoder profile to use for movie-only DVD output.
  The quality of the encode (highest being slowest)
  can be set by adding "HC_PROFILE=s" to the config
  (INI) file with "s" being set to "FAST", "NORMAL",
  or "BEST".  The default setting is "NORMAL".
- Corrected a syntax error on command lines that
  could cause encoding failure for DVD output when
  an audio delay is required.
- Corrected an error in which an unmatched language
  setting (BD to DVD) could cause a build failure
  when outputting to ALTERNATE/DVD.
- Fixed a regression in which ALTERNATE/MKV audio
  output was always incorrectly being reencoded to
  DD 2.0 (rather than DD 5.1 when available).
- Corrected an error in which audio streams that
  contained delays, and were not in the initial
  (SETUP defined) list of selections, could (if
  later selected from the streams list) be muxed
  out-of-sync.
- Updated the included version of X264.EXE to the
  latest release (r1772).
- Updated the included version of X264-64.EXE to
  the latest release (r1772).
- Other minor corrections and cosmetic fixes.
Old 18th November 2010, 05:51   #10227  |  Link
wooper
  out-of-sync.
thank you i will test rebuild the movie with this new version and check if everything goes well thantks
wooper is offline   Reply With Quote
Old 18th November 2010, 08:00   #10228  |  Link
omegaman7
omegaman7's Avatar
Originally Posted by setarip_old View Post
@omegaman7
Hi! If you keep in mind that the sole purpose of this thread is beta testing the program, you should understand that you should always be using the most recent version...
LOL! That's why I said I'm considering moving on You're totally correct though. I love to beta. Windows 7 was probably the most exciting to me...
omegaman7 is offline   Reply With Quote
Old 18th November 2010, 20:58   #10229  |  Link
matisgrana
Hello everyone! i am using BD-rebuilder since a month, thank you to create thatīs wonderful program.
This week i was rebuilding spartacus disc 2 and i have 3 times this problem
- [20:24:10] Reencoding: VID_00001, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.36.02 (beta)
- Windows Version: 6.1 [7600]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW_RAW_AUDIO: Not recommended setting
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[16:47:58] - Failed video encode, aborted
And i donīt find the solution, the three times the same error in the same part of the rebuild, the interesting thing itīs that the log show "- FFDSHOW_RAW_AUDIO: Not recommended setting" but if i do the inspect show "- FFDSHOW: 3326, Ok
- FFDSHOW_RAW_AUDIO: Set to "All Supported", Ok"
could you know what itīs happening?
Thank very much for your work jdobbs!
matisgrana is offline   Reply With Quote
Old 18th November 2010, 23:37   #10230  |  Link
omegaman7
omegaman7's Avatar
Tried the batch mode last night(0.35.01 I've since updated). Unfortunately, a bug incurred in the first job(Toy Story 3), which apparently aborts all jobs. This is unfortunate eh? For a measly audio problem, which may not exist in following jobs. Error 75 which apparently suggests rebuilder was trying to reference audio that doesn't exist. Not sure how that happened. I did click on audio streams in the streams section. I'm rerunning the job on default settings to see what happens. I only ripped the disc using anydvd. No other processing other than Bd Rebuilder.
[02:10:17] BD Rebuilder v0.35.01 (beta)
[02:10:18] BEGIN - BATCH SEQUENCE
[02:10:18] PROCESSING BATCH FILE [1]
[02:10:19] BD Rebuilder v0.35.01 (beta)
  - Source:  TOY_STORY_3_DISC_1
  - Input BD size: 44.41 GB
  - Approximate total content: [03:03:18.611]
  - Target BD size: 22.90 GB
  - Quality: High Quality (Default), ABR
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[02:10:19] PHASE ONE, Encoding
 - [02:10:19] Extracting A/V streams [VID_00472]
 - [02:10:19] Reencoding: VID_00472 (1 of 113)
 - [02:10:19] Collecting video information
   - Rate/Length: 23.976fps, 167 frames
 - [02:10:19] Reencoding: VID_00472, Pass 1 of 1
 - [02:10:22] Video Encode complete
 - [02:10:22] Reencoding audio tracks (if req'd)
 - [02:10:22] Multiplexing M2TS
 - [02:10:23] Extracting A/V streams [VID_00469]
 - [02:10:23] Reencoding: VID_00469 (2 of 113)
 - [02:10:23] Collecting video information
   - Rate/Length: 23.976fps, 108 frames
 - [02:10:23] Reencoding: VID_00469, Pass 1 of 1
 - [02:10:25] Video Encode complete
 - [02:10:25] Reencoding audio tracks (if req'd)
 - [02:10:25] Multiplexing M2TS
 - [02:10:26] Extracting A/V streams [VID_00465]
 - [02:10:26] Reencoding: VID_00465 (3 of 113)
 - [02:10:26] Collecting video information
   - Rate/Length: 23.976fps, 168 frames
 - [02:10:26] Reencoding: VID_00465, Pass 1 of 1
 - [02:10:29] Video Encode complete
 - [02:10:29] Reencoding audio tracks (if req'd)
 - [02:10:29] Multiplexing M2TS
 - [02:10:30] Extracting A/V streams [VID_00466]
 - [02:10:30] Reencoding: VID_00466 (4 of 113)
 - [02:10:30] Collecting video information
 - [02:10:30] Reencoding: VID_00466, Pass 1 of 1
 - [02:10:33] Video Encode complete
 - [02:10:33] Reencoding audio tracks (if req'd)
 - [02:10:33] Multiplexing M2TS
 - [02:10:34] Extracting A/V streams [VID_00459]
 - [02:10:34] Reencoding: VID_00459 (5 of 113)
 - [02:10:34] Collecting video information
   - Rate/Length: 23.976fps, 191 frames
 - [02:10:34] Reencoding: VID_00459, Pass 1 of 1
 - [02:10:37] Video Encode complete
 - [02:10:37] Reencoding audio tracks (if req'd)
 - [02:10:37] Multiplexing M2TS
 - [02:10:38] Extracting A/V streams [VID_00401]
 - [02:10:39] Reencoding: VID_00401 (6 of 113)
 - [02:10:39] Collecting video information
   - Rate/Length: 23.976fps, 308 frames
 - [02:10:39] Reencoding: VID_00401, Pass 1 of 1
 - [02:10:49] Video Encode complete
 - [02:10:49] Reencoding audio tracks (if req'd)
 - [02:10:50] Multiplexing M2TS
 - [02:10:50] Extracting A/V streams [VID_00463]
 - [02:10:52] Reencoding: VID_00463 (7 of 113)
 - [02:10:52] Collecting video information
   - Rate/Length: 23.976fps, 840 frames
 - [02:10:52] Reencoding: VID_00463, Pass 1 of 1
 - [02:11:05] Video Encode complete
 - [02:11:05] Reencoding audio tracks (if req'd)
 - [02:11:06] Multiplexing M2TS
 - [02:11:08] Extracting A/V streams [VID_00322]
 - [02:11:10] Reencoding: VID_00322 (8 of 113)
 - [02:11:10] Collecting video information
   - Rate/Length: 23.976fps, 302 frames
   - Bitrate: 21,156 Kbs
 - [02:11:10] Reencoding: VID_00322, Pass 1 of 1
 - [02:11:42] Video Encode complete
 - [02:11:42] Reencoding audio tracks (if req'd)
 - [02:11:42] Multiplexing M2TS
 - [02:11:45] Extracting A/V streams [VID_00346]
 - [02:11:47] Reencoding: VID_00346 (9 of 113)
 - [02:11:47] Collecting video information
 - [02:11:47] Reencoding: VID_00346, Pass 1 of 1
 - [02:11:56] Video Encode complete
 - [02:11:56] Reencoding audio tracks (if req'd)
 - [02:11:57] Multiplexing M2TS
 - [02:11:58] Extracting A/V streams [VID_00359]
 - [02:12:00] Reencoding: VID_00359 (10 of 113)
 - [02:12:00] Collecting video information
 - [02:12:00] Reencoding: VID_00359, Pass 1 of 1
 - [02:12:10] Video Encode complete
 - [02:12:10] Reencoding audio tracks (if req'd)
 - [02:12:10] Multiplexing M2TS
 - [02:12:11] Extracting A/V streams [VID_00345]
 - [02:12:14] Reencoding: VID_00345 (11 of 113)
 - [02:12:14] Collecting video information
   - Rate/Length: 23.976fps, 447 frames
 - [02:12:14] Reencoding: VID_00345, Pass 1 of 1
 - [02:12:26] Video Encode complete
 - [02:12:26] Reencoding audio tracks (if req'd)
 - [02:12:27] Multiplexing M2TS
 - [02:12:28] Extracting A/V streams [VID_00358]
 - [02:12:31] Reencoding: VID_00358 (12 of 113)
 - [02:12:31] Collecting video information
 - [02:12:31] Reencoding: VID_00358, Pass 1 of 1
 - [02:12:43] Video Encode complete
 - [02:12:43] Reencoding audio tracks (if req'd)
 - [02:12:43] Multiplexing M2TS
 - [02:12:45] Extracting A/V streams [VID_00321]
 - [02:12:49] Reencoding: VID_00321 (13 of 113)
 - [02:12:49] Collecting video information
   - Bitrate: 18,425 Kbs
 - [02:12:49] Reencoding: VID_00321, Pass 1 of 1
 - [02:13:35] Video Encode complete
 - [02:13:35] Reencoding audio tracks (if req'd)
 - [02:13:36] Multiplexing M2TS
 - [02:13:37] Extracting A/V streams [VID_00382]
 - [02:13:40] Reencoding: VID_00382 (14 of 113)
 - [02:13:40] Collecting video information
   - Rate/Length: 23.976fps, 547 frames
 - [02:13:40] Reencoding: VID_00382, Pass 1 of 1
 - [02:13:54] Video Encode complete
 - [02:13:54] Reencoding audio tracks (if req'd)
 - [02:13:55] Multiplexing M2TS
 - [02:13:57] Extracting A/V streams [VID_00372]
 - [02:14:01] Reencoding: VID_00372 (15 of 113)
 - [02:14:01] Collecting video information
 - [02:14:01] Reencoding: VID_00372, Pass 1 of 1
 - [02:14:15] Video Encode complete
 - [02:14:15] Reencoding audio tracks (if req'd)
 - [02:14:16] Multiplexing M2TS
 - [02:14:17] Extracting A/V streams [VID_00349]
 - [02:14:21] Reencoding: VID_00349 (16 of 113)
 - [02:14:21] Collecting video information
   - Rate/Length: 23.976fps, 523 frames
 - [02:14:21] Reencoding: VID_00349, Pass 1 of 1
 - [02:14:35] Video Encode complete
 - [02:14:35] Reencoding audio tracks (if req'd)
 - [02:14:36] Multiplexing M2TS
 - [02:14:37] Extracting A/V streams [VID_00362]
 - [02:14:42] Reencoding: VID_00362 (17 of 113)
 - [02:14:42] Collecting video information
 - [02:14:42] Reencoding: VID_00362, Pass 1 of 1
 - [02:14:56] Video Encode complete
 - [02:14:56] Reencoding audio tracks (if req'd)
 - [02:14:57] Multiplexing M2TS
 - [02:14:58] Extracting A/V streams [VID_00378]
 - [02:15:04] Reencoding: VID_00378 (18 of 113)
 - [02:15:04] Collecting video information
   - Rate/Length: 23.976fps, 570 frames
 - [02:15:04] Reencoding: VID_00378, Pass 1 of 1
 - [02:15:17] Video Encode complete
 - [02:15:17] Reencoding audio tracks (if req'd)
 - [02:15:19] Multiplexing M2TS
 - [02:15:20] Extracting A/V streams [VID_00388]
 - [02:15:24] Reencoding: VID_00388 (19 of 113)
 - [02:15:24] Collecting video information
 - [02:15:24] Reencoding: VID_00388, Pass 1 of 1
 - [02:15:38] Video Encode complete
 - [02:15:38] Reencoding audio tracks (if req'd)
 - [02:15:39] Multiplexing M2TS
 - [06:31:39] Video Encode complete
 - [06:31:39] Reencoding audio tracks (if req'd)
 - [06:31:40] ReencodeAudio() 00075  1801
[09:43:56] - Failed to reencode audio, aborted
[09:43:56] BATCH ABORTED...
Had to shorten post to 16000 characters...
Old 19th November 2010, 01:03   #10231  |  Link
prOnorama
Possible undersize?
Re-encoded a Blu-ray to BD-25 keeping audio untouched (DTS-HDMA + AC3 2.0 commentary), 2 pass encode:
[13:33:05] BD Rebuilder v0.36.03 (beta)
  - Source:  THE_THIN_RED_LINE
  - Input BD size: 34,73 GB
  - Approximate total content: [02:50:47.070]
  - Target BD size: 22,95 GB
  - Windows Version: 5.1 [2600]
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), Two Pass
[13:33:05] PHASE ONE, Encoding
 - [13:33:05] Extracting A/V streams [VID_00274]
 - [13:51:44] Reencoding: VID_00274 (1 of 1)
 - [13:51:44] Collecting video information
   - Rate/Length: 23,976fps, 245.684 frames
   - Bitrate: 12.953 Kbs
 - [13:51:44] Reencoding: VID_00274, Pass 1 of 2
 - [15:58:51] Reencoding: VID_00274, Pass 2 of 2
 - [22:04:44] Video Encode complete
 - [22:04:45] Reencoding audio tracks (if req'd)
 - [22:04:45] Multiplexing M2TS
[22:11:50]PHASE ONE complete
[22:11:50]PHASE TWO - Rebuild Started
 - [22:11:50] Rebuilding BD file Structure
[22:25:16] - Encode and Rebuild complete
[22:25:16]JOB: THE_THIN_RED_LINE finished.
According to the log the output size should have been 22.95 GB but it came out as 22.1 GB so that's almost 4% smaller. As said I used 2 pass mode so I figured it should have to hit the specified target size almost spot on.
prOnorama is offline   Reply With Quote
Old 19th November 2010, 01:13   #10232  |  Link
drackula
I found problem. I want to reencode ac3 640kbs to ac3 448kbs.
I goto setting select reencode ac3 to 448kbs.
When rencode finnish i use bdinfo check but ac3 still 640kbs same before reencode.
i have to do. sorry i'm englise is not good. thank you.
drackula is offline   Reply With Quote
Old 19th November 2010, 01:17   #10233  |  Link
jdobbs
The overhead needed for muxing isn't very consistent, so there's always a possiblity of some undersizing. Most of my encodes come in at about 22.4GB. I have to leave a little room in case the muxing goes off in the other direction.
I'm still making adjustments to the sizing during beta testing. So I'd expect it to be more accurate by the time I get to v1.00.
You can always set a custom target size (see SETUP) that is closer to a full disc -- but right now I don't want to risk oversizing because that requires a complete redo.
There wouldn't be any likely visible difference in the output with that small amount of undersizing. I'm not one of the folks who subscribes to the "fill to the edge of the disc" philosophy. But over time it'll get closer.
Old 19th November 2010, 05:11   #10234  |  Link
Acerjen
I re-ripped Cars and ran it through the newest version of DVD-RB. I still get the same error. Here is the log:
[13:47:02] BD Rebuilder v0.36.03 (beta)
  - Source:  CARS
  - Input BD size: 38.53 GB
  - Approximate total content: [03:35:49.536]
  - Target BD size: 22.95 GB
  - Auto Quality: Good (Very Fast), ABR
[13:47:02] PHASE ONE, Encoding
 - [13:47:02] Extracting A/V streams [VID_00015]
 - [13:47:10] Reencoding: VID_00015 (1 of 34)
 - [13:47:10] Collecting video information
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23.976fps, 847 frames
   - Bitrate: 9,545 Kbs
 - [13:47:10] Reencoding: VID_00015, Pass 1 of 1
 - [13:47:20] Video Encode complete
 - [13:47:20] Reencoding audio tracks (if req'd)
 - [13:47:20] Multiplexing M2TS
 - [13:47:22] Extracting A/V streams [VID_00016]
 - [13:47:25] Reencoding: VID_00016 (2 of 34)
 - [13:47:25] Collecting video information
   - Rate/Length: 23.976fps, 239 frames
   - Bitrate: 10,398 Kbs
 - [13:47:25] Reencoding: VID_00016, Pass 1 of 1
 - [13:47:28] Video Encode complete
 - [13:47:28] Reencoding audio tracks (if req'd)
 - [13:47:28] Multiplexing M2TS
 - [13:47:29] Extracting A/V streams [VID_00023]
 - [13:47:36] Reencoding: VID_00023 (3 of 34)
 - [13:47:36] Collecting video information
   - Rate/Length: 23.976fps, 720 frames
   - Bitrate: 8,856 Kbs
 - [13:47:36] Reencoding: VID_00023, Pass 1 of 1
 - [13:47:44] Video Encode complete
 - [13:47:44] Reencoding audio tracks (if req'd)
 - [13:47:44] Multiplexing M2TS
 - [13:47:46] Extracting A/V streams [VID_00024]
 - [13:47:53] Reencoding: VID_00024 (4 of 34)
 - [13:47:53] Collecting video information
   - Bitrate: 9,076 Kbs
 - [13:47:53] Reencoding: VID_00024, Pass 1 of 1
 - [13:48:00] Video Encode complete
 - [13:48:00] Reencoding audio tracks (if req'd)
 - [13:48:00] Multiplexing M2TS
 - [13:48:02] Extracting A/V streams [VID_00025]
 - [13:48:08] Reencoding: VID_00025 (5 of 34)
 - [13:48:08] Collecting video information
   - Bitrate: 8,881 Kbs
 - [13:48:08] Reencoding: VID_00025, Pass 1 of 1
 - [13:48:16] Video Encode complete
 - [13:48:16] Reencoding audio tracks (if req'd)
 - [13:48:16] Multiplexing M2TS
 - [13:48:19] Extracting A/V streams [VID_00026]
 - [13:48:25] Reencoding: VID_00026 (6 of 34)
 - [13:48:25] Collecting video information
   - Bitrate: 8,981 Kbs
 - [13:48:25] Reencoding: VID_00026, Pass 1 of 1
 - [13:48:32] Video Encode complete
 - [13:48:32] Reencoding audio tracks (if req'd)
 - [13:48:32] Multiplexing M2TS
 - [13:48:35] Extracting A/V streams [VID_00027]
 - [13:48:42] Reencoding: VID_00027 (7 of 34)
 - [13:48:42] Collecting video information
   - Bitrate: 8,901 Kbs
 - [13:48:42] Reencoding: VID_00027, Pass 1 of 1
 - [13:48:49] Video Encode complete
 - [13:48:49] Reencoding audio tracks (if req'd)
 - [13:48:49] Multiplexing M2TS
 - [13:48:52] Extracting A/V streams [VID_00028]
 - [13:48:58] Reencoding: VID_00028 (8 of 34)
 - [13:48:58] Collecting video information
   - Bitrate: 8,907 Kbs
 - [13:48:58] Reencoding: VID_00028, Pass 1 of 1
 - [13:49:06] Video Encode complete
 - [13:49:06] Reencoding audio tracks (if req'd)
 - [13:49:06] Multiplexing M2TS
 - [13:49:08] Extracting A/V streams [VID_00029]
 - [13:49:14] Reencoding: VID_00029 (9 of 34)
 - [13:49:14] Collecting video information
   - Bitrate: 8,849 Kbs
 - [13:49:14] Reencoding: VID_00029, Pass 1 of 1
 - [13:49:22] Video Encode complete
 - [13:49:22] Reencoding audio tracks (if req'd)
 - [13:49:22] Multiplexing M2TS
 - [13:49:24] Extracting A/V streams [VID_00030]
 - [13:49:30] Reencoding: VID_00030 (10 of 34)
 - [13:49:30] Collecting video information
   - Bitrate: 8,973 Kbs
 - [13:49:30] Reencoding: VID_00030, Pass 1 of 1
 - [13:49:38] Video Encode complete
 - [13:49:38] Reencoding audio tracks (if req'd)
 - [13:49:38] Multiplexing M2TS
 - [13:49:40] Extracting A/V streams [VID_00036]
 - [13:51:04] Reencoding: VID_00036 (11 of 34)
 - [13:51:04] Collecting video information
   - Rate/Length: 23.976fps, 10,297 frames
   - Bitrate: 9,628 Kbs
 - [13:51:04] Reencoding: VID_00036, Pass 1 of 1
 - [13:54:01] Video Encode complete
 - [13:54:01] Reencoding audio tracks (if req'd)
 - [13:54:01] Multiplexing M2TS
 - [13:54:25] Extracting A/V streams [VID_00037]
 - [13:55:19] Reencoding: VID_00037 (12 of 34)
 - [13:55:19] Collecting video information
   - Rate/Length: 23.976fps, 6,557 frames
   - Bitrate: 9,502 Kbs
 - [13:55:19] Reencoding: VID_00037, Pass 1 of 1
 - [13:57:03] Video Encode complete
 - [13:57:03] Reencoding audio tracks (if req'd)
 - [13:57:03] Multiplexing M2TS
 - [13:57:19] Extracting A/V streams [VID_00038]
 - [13:58:10] Reencoding: VID_00038 (13 of 34)
 - [13:58:10] Collecting video information
   - Rate/Length: 23.976fps, 6,248 frames
   - Bitrate: 8,999 Kbs
 - [13:58:10] Reencoding: VID_00038, Pass 1 of 1
 - [13:59:56] Video Encode complete
 - [13:59:56] Reencoding audio tracks (if req'd)
 - [13:59:56] Multiplexing M2TS
 - [14:00:10] Extracting A/V streams [VID_00039]
 - [14:01:13] Reencoding: VID_00039 (14 of 34)
 - [14:01:13] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 28,860 frames
   - Bitrate: 3,131 Kbs
 - [14:01:13] Reencoding: VID_00039, Pass 1 of 1
 - [14:02:39] Video Encode complete
 - [14:02:39] Reencoding audio tracks (if req'd)
 - [14:02:39] Multiplexing M2TS
 - [14:02:57] Extracting A/V streams [VID_00040]
 - [14:03:20] Reencoding: VID_00040 (15 of 34)
 - [14:03:20] Collecting video information
   - Rate/Length: 29.970fps, 9,770 frames
   - Bitrate: 3,106 Kbs
 - [14:03:20] Reencoding: VID_00040, Pass 1 of 1
 - [14:03:48] Video Encode complete
 - [14:03:48] Reencoding audio tracks (if req'd)
 - [14:03:48] Multiplexing M2TS
 - [14:03:56] Extracting A/V streams [VID_00041]
 - [14:04:17] Reencoding: VID_00041 (16 of 34)
 - [14:04:17] Collecting video information
   - Rate/Length: 29.970fps, 9,900 frames
   - Bitrate: 3,122 Kbs
 - [14:04:17] Reencoding: VID_00041, Pass 1 of 1
 - [14:04:47] Video Encode complete
 - [14:04:47] Reencoding audio tracks (if req'd)
 - [14:04:47] Multiplexing M2TS
 - [14:04:54] Extracting A/V streams [VID_00042]
 - [14:05:15] Reencoding: VID_00042 (17 of 34)
 - [14:05:15] Collecting video information
   - Rate/Length: 29.970fps, 9,500 frames
   - Bitrate: 3,047 Kbs
 - [14:05:15] Reencoding: VID_00042, Pass 1 of 1
 - [14:05:42] Video Encode complete
 - [14:05:42] Reencoding audio tracks (if req'd)
 - [14:05:42] Multiplexing M2TS
 - [14:05:49] Extracting A/V streams [VID_00043]
 - [14:06:12] Reencoding: VID_00043 (18 of 34)
 - [14:06:12] Collecting video information
   - Rate/Length: 29.970fps, 10,980 frames
   - Bitrate: 3,064 Kbs
 - [14:06:12] Reencoding: VID_00043, Pass 1 of 1
 - [14:06:40] Video Encode complete
 - [14:06:40] Reencoding audio tracks (if req'd)
 - [14:06:40] Multiplexing M2TS
 - [14:06:48] Extracting A/V streams [VID_00044]
 - [14:06:59] Reencoding: VID_00044 (19 of 34)
 - [14:06:59] Collecting video information
   - Rate/Length: 29.970fps, 4,930 frames
   - Bitrate: 3,135 Kbs
 - [14:06:59] Reencoding: VID_00044, Pass 1 of 1
 - [14:07:14] Video Encode complete
 - [14:07:14] Reencoding audio tracks (if req'd)
 - [14:07:14] Multiplexing M2TS
 - [14:07:17] Extracting A/V streams [VID_00045]
 - [14:07:33] Reencoding: VID_00045 (20 of 34)
 - [14:07:33] Collecting video information
   - Rate/Length: 29.970fps, 6,420 frames
   - Bitrate: 3,057 Kbs
 - [14:07:33] Reencoding: VID_00045, Pass 1 of 1
 - [14:07:49] Video Encode complete
 - [14:07:49] Reencoding audio tracks (if req'd)
 - [14:07:49] Multiplexing M2TS
 - [14:07:54] Extracting A/V streams [VID_00046]
 - [14:08:24] Reencoding: VID_00046 (21 of 34)
 - [14:08:24] Collecting video information
   - Rate/Length: 29.970fps, 13,003 frames
   - Bitrate: 3,147 Kbs
 - [14:08:24] Reencoding: VID_00046, Pass 1 of 1
 - [14:09:02] Video Encode complete
 - [14:09:02] Reencoding audio tracks (if req'd)
 - [14:09:02] Multiplexing M2TS
 - [14:09:11] Extracting A/V streams [VID_00047]
 - [14:09:25] Reencoding: VID_00047 (22 of 34)
 - [14:09:25] Collecting video information
   - Rate/Length: 29.970fps, 6,930 frames
   - Bitrate: 2,860 Kbs
 - [14:09:25] Reencoding: VID_00047, Pass 1 of 1
 - [14:09:39] Video Encode complete
 - [14:09:39] Reencoding audio tracks (if req'd)
 - [14:09:39] Multiplexing M2TS
 - [14:09:44] Extracting A/V streams [VID_00048]
 - [14:09:51] Reencoding: VID_00048 (23 of 34)
 - [14:09:51] Collecting video information
   - Rate/Length: 29.970fps, 3,120 frames
   - Bitrate: 2,870 Kbs
 - [14:09:51] Reencoding: VID_00048, Pass 1 of 1
 - [14:09:58] Video Encode complete
 - [14:09:58] Reencoding audio tracks (if req'd)
 - [14:09:58] Multiplexing M2TS
 - [14:10:00] Extracting A/V streams [VID_00049]
 - [14:10:12] Reencoding: VID_00049 (24 of 34)
 - [14:10:12] Collecting video information
   - Rate/Length: 29.970fps, 5,850 frames
   - Bitrate: 2,840 Kbs
 - [14:10:12] Reencoding: VID_00049, Pass 1 of 1
 - [14:10:23] Video Encode complete
 - [14:10:23] Reencoding audio tracks (if req'd)
 - [14:10:23] Multiplexing M2TS
 - [14:10:28] Extracting A/V streams [VID_00050]
 - [14:10:35] Reencoding: VID_00050 (25 of 34)
 - [14:10:35] Collecting video information
   - Rate/Length: 29.970fps, 3,090 frames
   - Bitrate: 2,848 Kbs
 - [14:10:35] Reencoding: VID_00050, Pass 1 of 1
 - [14:10:42] Video Encode complete
 - [14:10:42] Reencoding audio tracks (if req'd)
 - [14:10:42] Multiplexing M2TS
 - [14:10:44] Extracting A/V streams [VID_00051]
 - [14:10:57] Reencoding: VID_00051 (26 of 34)
 - [14:10:57] Collecting video information
   - Rate/Length: 29.970fps, 6,210 frames
   - Bitrate: 2,834 Kbs
 - [14:10:57] Reencoding: VID_00051, Pass 1 of 1
 - [14:11:09] Video Encode complete
 - [14:11:09] Reencoding audio tracks (if req'd)
 - [14:11:09] Multiplexing M2TS
 - [14:11:14] Extracting A/V streams [VID_00053]
 - [14:12:02] Reencoding: VID_00053 (27 of 34)
 - [14:12:02] Collecting video information
   - Rate/Length: 23.976fps, 3,608 frames
   - Bitrate: 16,245 Kbs
 - [14:12:02] Reencoding: VID_00053, Pass 1 of 1
 - [14:12:58] Video Encode complete
 - [14:12:58] Reencoding audio tracks (if req'd)
 - [14:12:58] Multiplexing M2TS
 - [14:13:11] Extracting A/V streams [VID_00054]
 - [14:13:32] Reencoding: VID_00054 (28 of 34)
 - [14:13:32] Collecting video information
   - Rate/Length: 23.976fps, 2,307 frames
   - Bitrate: 9,857 Kbs
 - [14:13:32] Reencoding: VID_00054, Pass 1 of 1
 - [14:14:00] Video Encode complete
 - [14:14:00] Reencoding audio tracks (if req'd)
 - [14:14:00] Multiplexing M2TS
 - [14:14:07] Extracting A/V streams [VID_00055]
 - [14:14:39] Reencoding: VID_00055 (29 of 34)
 - [14:14:39] Collecting video information
   - Rate/Length: 23.976fps, 3,563 frames
   - Bitrate: 10,078 Kbs
 - [14:14:39] Reencoding: VID_00055, Pass 1 of 1
 - [14:15:29] Video Encode complete
 - [14:15:29] Reencoding audio tracks (if req'd)
 - [14:15:29] Multiplexing M2TS
 - [14:15:38] Extracting A/V streams [VID_00060]
 - [14:54:49] Reencoding: VID_00060 (30 of 34)
 - [14:54:49] Collecting video information
   - Rate/Length: 23.976fps, 167,736 frames
   - Bitrate: 8,049 Kbs
 - [14:54:49] Reencoding: VID_00060, Pass 1 of 1
 - [15:52:35] Video Encode complete
 - [15:52:35] Reencoding audio tracks (if req'd)
 - [15:52:35] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00060.meta
 - Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed.
[16:00:48] - Failed to build structure, aborted
Thanks. Later.
acerjen
Acerjen is offline   Reply With Quote
Old 19th November 2010, 06:59   #10235  |  Link
omegaman7
omegaman7's Avatar
Second attempt of Toy Story 3 went well. This time I didn't fiddle with the audio streams. Sure wish I had a freak processor to eat up this processing job. I'd run a lot more tests Can't wait to see how Sandy bridge and Bulldozer handle this process
Old 19th November 2010, 07:06   #10236  |  Link
Capsbackup
A rare but potential bug surfaced regarding mixed audio bitrates within a "Play All" bonus feature for the movie Predators. The bonus feature is 40:12, Evolution of the Species. It is broken up into 8 seperate .m2ts files, with 7 of the files having 448kbps, 6 channel AC3 audio, but one has 224kbps, 2 channel AC3 audio.
The full movie backup completes correctly, as BD-RB keeps the original structure intact and preserves the 8 individual files.
However, if movie only is selected, and this .mpls is selected from the other Movie-Only playlist choices, the problem occurs. Since BD-RB attempts to join the 8 seperate m2ts files into one m2ts, and the lone 224kbps 2 channel AC3 is different from the rest, there is a problem.
I have never experienced this before, probably very uncommon, but does provide another consideration for joining multi-part m2ts files into one.
Old 19th November 2010, 14:48   #10237  |  Link
jdobbs
The problem is in the source -- it violates spec. By spec, when there are multiple components they all must have the same stream characteristics. They have to -- because the stream characteristics are specified in the MPLS for the entire set.
Old 19th November 2010, 17:08   #10238  |  Link
Capsbackup
I do understand this, but technically the source is not in violation since it works fine ( Not good authoring though! ), and because it has a seperate .mpls for each .m2ts. There is a "Play All" button that just tells the player to play consecutively each .m2ts.
As I said, BD-RB reencodes this Blu-ray correctly if I choose full backup. It maintains the same structure.
Only when I select movie only in BD-RB, and choose the associated .mpls, which BD-RB has as an available option to select from does the problem arise.
Perhaps if BD-RB read the contents of this mpls, it would detect that the audio streams of each m2ts are not the same and refuse to continue to attempt to join them?
I know this is extremely rare, and I really don't have an issue with it.
I just wanted to share an experience that could allow BD-RB to make a movie only option that has audio sync or missing audio for a multi-part movie clip.
Old 19th November 2010, 19:12   #10239  |  Link
jdobbs
No that's incorrect. It is in violation. The test isn't whether it will play back -- lots of illegal things might work just by coincidence. It's true that you may have a different MPLS that points to it as well -- but if it is included in any MPLS and violates the rules, it is not to spec.
BD-RB already reads the MPLS and each of the CLPI files... but all the audio encoding has to be done together. I could reject is sure... but then I'd get even more bug reports because of the missing segment.
What I worry about is that if I start looking for ways to fix things that are out-of-spec, there would be no end to it.
Old 20th November 2010, 00:10   #10240  |  Link
Priapismic
Rewording Suggestion To Avoid Confusion
@jdobbs
Maybe in the next program version, and on post #1, you could do some re-phrasing that would avoid confusing newbies, et al:
The Matroska splitter is not mentioned in the actual program - instead being referred to as Haali splitter.
So if BDRB reports an incorrect Haali splitter during a failed encode, users will go looking for it in post #1 and not find it....
...maybe reword post #1 to include ..."Matroska", formerly known as...
anyway, thought it might help.
Priapismic is offline   Reply With Quote
