28th June 2011, 18:57 | #13741 | Link |
Manifests are installed again in 3913. Embedded one doesn't work properly on XP. Will probably also fix the tooltips.
MPC-HC 2.1.7.2 |
30th June 2011, 12:19 | #13742 | Link | |
clsid Updated Russian translation: http://www.mediafire.com/?38zgb35hkur8f4g |
2nd July 2011, 20:05 | #13743 | Link |
More Fraps regressions (tested with r3914):
FPS1 -> RGB32 has inverted chroma planes. FPS1 -> YV12/NV12 has a 16 pixel-wide bright bar on the very right side of the video. FPS1 -> YUV2/UYVY is fine. Sample: http://stfcc.org/misc/ffplay_fraps_v...with_audio.avi Last edited by Snowknight26; 2nd July 2011 at 20:14. |
3rd July 2011, 00:23 | #13745 | Link | |
MPC-HC 2.1.7.2 |
3rd July 2011, 07:35 | #13746 | Link |
So, from my skimming the past 10 pages, audio un-sync problem with multithread is still a known problem, correct? In my case it only happen with avi. H264 in mkv works fine for me.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
3rd July 2011, 12:08 | #13747 | Link |
It was not known in case of H.264. But if it also happens, then that sucks. A good reason to avoid H.264 in AVI.
MPC-HC 2.1.7.2 |
3rd July 2011, 12:56 | #13748 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd July 2011 at 12:59. |
3rd July 2011, 13:38 | #13749 | Link |
Does anyone have a sample where the sync issue is really noticeable?
I can limit the number of threads in case of AVI to a number where the sync issue isn't noticeable anymore.
MPC-HC 2.1.7.2 |
3rd July 2011, 19:13 | #13750 | Link | ||
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. Last edited by Hypernova; 3rd July 2011 at 19:15. Reason: Add about threads |
3rd July 2011, 19:15 | #13751 | Link |
I cant seem to be able to compile the latest x64 build anymore
I get the below message when using MSYS_MinGW_GCC_461_x86-x64_Full.7z, Code:
../../obj/MinGW64/ffmpeg/libavcodec/x86/vp8dsp.o:libavcodec/x86/vp8dsp.asm:(.tex t+0xb00f): undefined reference to `_ff_pb_F8' ../../obj/MinGW64/ffmpeg/libavcodec/x86/vp8dsp.o:libavcodec/x86/vp8dsp.asm:(.tex t+0xb01c): undefined reference to `_ff_pb_3' ../../obj/MinGW64/ffmpeg/libavcodec/x86/vp8dsp.o:libavcodec/x86/vp8dsp.asm:(.tex t+0xb025): undefined reference to `_ff_pb_4' ../../obj/MinGW64/ffmpeg/libavcodec/x86/vp8dsp.o:libavcodec/x86/vp8dsp.asm:(.tex t+0xb090): undefined reference to `_ff_pb_1' collect2: ld returned 1 exit status C:\MSYS\mingw\bin\x86_64-w64-mingw32-dllwrap.exe: C:\MSYS\mingw\bin\x86_64-w64-m ingw32-gcc exited with status 1 make: *** [../../bin/ffmpeg.dll] Error 1
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
3rd July 2011, 19:31 | #13752 | Link |
Not sure if this is useful but I tried using MPC-HC (3283, MSVC 2010SP1, with ffmpeg by MinGW GCC 4.6.1), which as far as I can tell also use mutithread decoding. There is no lag.
Note: By lag I mean the video lag behind audio.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. Last edited by Hypernova; 3rd July 2011 at 19:36. Reason: add note |
3rd July 2011, 19:37 | #13753 | Link | ||
Does the sync difference grow with more threads? It should. Quote:
MPC-HC 2.1.7.2 |
3rd July 2011, 19:40 | #13754 | Link |
There is a working mingw64 package on the SourceForge page.
MPC-HC 2.1.7.2 |
3rd July 2011, 20:29 | #13755 | Link |
I don't know if I did any wrong but only the first part seem to playable after splited by DGSplit. Please use the second half where the karaoke appear to see the lag.
http://www.mediafire.com/?9jf19139i6e0uh2
3rd July 2011, 23:54 | #13756 | Link | |
MPC-BE DEV
Index: src/ffmpeg/config.h =================================================================== --- src/ffmpeg/config.h (revision 3919) +++ src/ffmpeg/config.h (working copy) @@ -43,8 +43,8 @@ #define ASMALIGN(ZEROBITS) ".p2align " #ZEROBITS "\n\t" #if ARCH_X86_64 - #define EXTERN_PREFIX "_" - #define EXTERN_ASM _ + #define EXTERN_PREFIX "" + #define EXTERN_ASM #else #define EXTERN_PREFIX "_" #define EXTERN_ASM _ Index: src/makefile_c.inc =================================================================== --- src/makefile_c.inc (revision 3919) +++ src/makefile_c.inc (working copy) @@ -12,7 +12,7 @@ TARGET_OS=x86_64-w64-mingw32 CFLAGS+=-DWIN64 -D_WIN64 -D__MINGW64__ OPTFLAGS+=-O2 -m64 - YASMFLAGS+=-f win64 -m amd64 -DWIN64 -DARCH_X86_64 -DPREFIX + YASMFLAGS+=-f win64 -m amd64 -DWIN64 -DARCH_X86_64 else TARGET_OS=i686-w32-mingw32 CFLAGS+=-DWIN32 -D_WIN32 -D__MINGW32__ @@ -21,7 +21,7 @@ endif CFLAGS+=-mdll -mthreads -pipe -OPTFLAGS+=-fno-common -fno-tree-vectorize +OPTFLAGS+=-fno-common CPPFLAGS+=-fno-rtti OUTPUTFLAG=-MMD -o\ @@ -30,7 +30,7 @@ YASMFLAGS+=-g cv8 else CFLAGS+=-DNDEBUG -UDEBUG - OPTFLAGS+=-fomit-frame-pointer +# OPTFLAGS+=-fomit-frame-pointer (with GCC4.6.x - 4.7.x it is not used.) LDFLAGS+=-s endif
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
4th July 2011, 12:33 | #13757 | Link | |
4th July 2011, 15:10 | #13759 | Link | |
Edit: can you test this file with x64 build: http://www.zshare.net/video/92250008bfd03cce/ It crashes for me with new pthreads, but not with old. But might also be GCC bug. Edit2: Build made with GCC 4.5.2 does not crash. So it looks like a bug in newer versions of GCC.
MPC-HC 2.1.7.2 Last edited by clsid; 4th July 2011 at 15:51. |
