26th April 2016, 23:00 | #3621 | Link | |
27th April 2016, 00:17 | #3622 | Link |
I have a single Xeon 2695v3 CPU. May I ask which among the x265 build is best for my CPU? Is it the ICC build? GCC 5.3 / 6? AVX2?
Thanks
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
27th April 2016, 05:26 | #3623 | Link |
Posts: n/a
x265 has over a thousand kernels that have been hand-optimized with the latest SIMD instruction sets (SSE2, SSE3, SSE4, AVX, AVX2). Your compiler won't change these kernels one bit. For the rest of the code, there are very minor differences in performance due to different compilers (ICC vs GCC).
27th April 2016, 18:28 | #3624 | Link |
I've made extended version of Unicode patch for Windows -- now output file works and stat file(s). Console info is also fixed including error messages, example:
i:\vs\x265\ma\XP>x265 --pass 1 --bitrate 4500 --stat Łojezu_Łotr-jeden?.stat /speed/720p50_parkrun_ter.y4m -o W_żółtych_płomieni ach_liści.hevc y4m [info]: 1280x720 fps 50/1 i420p8 sar 1:1 frames 0 - 503 of 504 raw [info]: output file: W_żółtych_płomieniach_liści.hevc x265 [info]: HEVC encoder version 1.9+147-19cced21060f x265 [info]: build info [Windows][GCC 6.1.0][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main profile, Level-4 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: frame threads / pool features : 2 / wpp(12 rows) x265 [error]: can't open stats file Łojezu_Łotr-jeden?.stat.temp x265 [error]: failed to open encoder www.msystem.waw.pl/x265/utf16_output-stat.7z If there will be no errors, tomorrow I will send this patch to devel-list. |
27th April 2016, 19:13 | #3625 | Link |
@MA
The first was perfect, this one encodes but the console output looks wrong: My code works for all other tools: Code:
Overloads Sub Encode(passName As String, batchCode As String) batchCode = "@echo off" + BR + "CHCP 65001" + BR + batchCode Dim batchPath = p.TempDir + p.TargetFile.Base + "_encode.bat" File.WriteAllText(batchPath, batchCode, New UTF8Encoding(False)) 'UTF8 without BOM Using proc As New Proc proc.Init(passName) proc.Encoding = Encoding.UTF8 proc.File = "cmd.exe" proc.Arguments = "/C call """ + batchPath + """" proc.Start() End Using End Sub
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 27th April 2016 at 19:17. |
27th April 2016, 20:02 | #3626 | Link |
@stax76
Thanks for info! I've changed output mode for stderr from _O_U16TEXT to _O_U8TEXT. New test build (only 64-bit + patch): www.msystem.waw.pl/x265/utf16_output-stat2.7z |
27th April 2016, 20:45 | #3627 | Link |
@Ma
Thanks for the test build, I tested various things without noticing any problem!
28th April 2016, 09:20 | #3630 | Link |
Patch which allows Unicode filenames in Windows (for now output file and stat files) has been sent
https://patches.videolan.org/patch/13109/ Next we can fix input files. ------------------------ GCC on old mingw-w64 not works with this code. First workaround is: Code:
diff -r 00ea3784bd36 source/common/common.cpp --- a/source/common/common.cpp Thu Apr 28 09:59:30 2016 +0200 +++ b/source/common/common.cpp Fri Apr 29 03:12:31 2016 +0200 @@ -185,7 +185,7 @@ MultiByteToWideChar(CP_UTF8, 0, buffer, -1, buf_utf16, sizeof(buf_utf16)/sizeof(wchar_t)); fflush(stderr); int oldmode = _setmode(_fileno(stderr), _O_U8TEXT); - fwprintf(stderr, L"%ls", buf_utf16); // WARNING: due to bug in msvcrt.dll fputws doesn't work in mingw/gcc + fwprintf_s(stderr, L"%ls", buf_utf16); // WARNING: due to bug in msvcrt.dll fputws doesn't work in mingw/gcc fflush(stderr); _setmode(_fileno(stderr), oldmode); } Last edited by Ma; 29th April 2016 at 02:14. |
29th April 2016, 03:52 | #3631 | Link |
Could someone with WinXP test this 32-bit version of x265:
www.msystem.waw.pl/x265/32bit-xp.zip I've tested on Win7 64bit and Vista 32bit -- works. I don't have WinXP. It should work and should be line "raw [info]:" Code:
y4m [info]: 1280x720 fps 50/1 i420p8 sar 1:1 frames 0 - 503 of 504 raw [info]: output file: Żółć.hevc x265 [info]: HEVC encoder version 1.9+150-00ea3784bd36 x265 [info]: build info [Windows][GCC 5.3.0][32 bit] 8bit ------------------- Finally I give up with mingw-w64 (for ver. 3 I can't write working code), so it is easier switch to Windows API. If someone wants to try new code: hg import --no-commit https://patches.videolan.org/patch/13138/raw/ Last edited by Ma; 29th April 2016 at 09:31. |
29th April 2016, 14:16 | #3632 | Link | |
Doesn't work: http://i.imgur.com/v4bLZpq.png |
29th April 2016, 14:57 | #3633 | Link | |
I've prepared new samples compiled with patch https://patches.videolan.org/patch/13138/ Could you test this on WinXP (on 99% should work, both compiled by GCC 4.8.3 and GCC 5.3): www.msystem.waw.pl/x265/32bit-xp2.zip |
29th April 2016, 15:12 | #3634 | Link | |
Both versions seem to work. raw [info]: output file: Zólc.hevc |
29th April 2016, 15:23 | #3635 | Link |
Thanks! So we should make a fix to mingw-w64 code (but this may take a long while). For now it is better to apply 13138 patch.
--------------- After investigation -- mingw-w64 code looks OK, x265 v1.9+150 code looks OK, the bug is in msvcrt.dll. Almost all mingw-w64 stdio code is written with use of fputwc/fputc functions from msvcrt.dll. fputwc function from msvcrt.dll doesn't work with _O_U8TEXT mode (works only with _O_U16TEXT mode). If you build x265 v1.9+150 by mingw-w64/gcc linked to msvcrt.dll, there will be no "raw [info]" line in console. If you link to msvcr110.dll instead of msvcrt.dll, all is working (without any changes in x265 code nor mingw-w64 code). Example www.msystem.waw.pl/x265/gcc483-xp.7z -- x265n.exe is linked to msvcr110.dll and works OK without any patches. Last edited by Ma; 29th April 2016 at 20:22. |
1st May 2016, 13:07 | #3636 | Link | |
Any idea how I can push a EXR sequence (individual file fer frame) to x265? I tried everything in after effects but can't generate a 10bit 4:2:0 4K MOV or AVI file for x265 Main10. Any suggestion to go from After Effects workflow to 10bit 4:2:0 4K is much appreciated.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 1st May 2016 at 13:15. |
1st May 2016, 16:27 | #3637 | Link | |||
Okay, Ihave managed to maintain a 10bit 4K workflow from start to finish.
First I export to PNG image sequence in 16bit (smallest file format compared to TIFF, DPX, EXR). Next I use ffmpeg PNG image sequence to Y4M raw in yuv420p10, 16bit RGB full range PNG converted and dithered down to 10bit YUV 4:2:0 Limited range by ffmpeg with 1:1 color accuracy. 8 seconds Y4M (192 frames) = 4GB !! Anyone knows a better way to keep a 4:2:0 10bit 4K workflow in a smaller footprint? For test patterns it is pointless to use more than 1 fps, so the Y4M is proportionally smaller since it is uncompressed. For anyone interested, here are my steps: Quote:
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 1st May 2016 at 20:15. |
1st May 2016, 17:37 | #3640 | Link |
I cannot guarantee that ffmpeg can handle 16 bit per component PNG.
If it can, I don't know which command line options are required to convert to 10 bit per component YUV 4:2:0. But it should be worth discovering if it works, and how. |
