Old 22nd July 2019, 19:19   #6941  |  Link
benwaggoner
Originally Posted by froggy1 View Post
the former. it's for better quality/accuracy. Here's an article that explains it. It is also low computational but highly efficient
http://homepages.inf.ed.ac.uk/rbf/CV...stimation.html
So, it can make things faster at the same quality, higher quality at the same speed, or a mix of the two.
Ben Waggoner
My Compression Book
Old 24th July 2019, 12:46   #6942  |  Link
aegisofrime
Could you share your settings? By simply setting --hme, I'm seeing a reduction of around 40% in speed on my encodes. Thanks!
aegisofrime is offline   Reply With Quote
Old 24th July 2019, 13:12   #6943  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
I don't see such a high penalty on my i7 7700K processor. I use hme=1 and hme-search=umh,umh,umh
Old 24th July 2019, 15:16   #6944  |  Link
DJATOM
DJATOM's Avatar
My friend tried star,star,umh and caught a crash on frame 50, but umh,star,umh works fine (but slower).
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 24th July 2019, 15:20   #6945  |  Link
microchip8
microchip8's Avatar
yes, I experienced the same crash when using star for all levels (L0,1,2) hme-search=star
I use umh because I find it preserves details better but is a bit slower than star
Old 24th July 2019, 18:20   #6946  |  Link
benwaggoner
Originally Posted by mandarinka View Post
From the description, it looks both aqmode 3 and aqmode 4 are modifications of aqmode 2. Based on the descriptions, the first adds bias for darker scenes/parts and the second (#4) adds bias for detected(?) edges (to improve them?).
Speculation: aq-mode 4 is the non-experimental implementation of --hevc-aq.
Ben Waggoner
My Compression Book
Old 24th July 2019, 21:00   #6947  |  Link
jlpsvk
@benwaggoner
i don't think so, as hevc-aq and aq-mode 4 coexists...
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
Old 24th July 2019, 22:41   #6948  |  Link
mandarinka
mandarinka's Avatar
I can confirm it doesn't like star on the first instance, I got crash right at start with merange 92 and 1440x1080 source.
To get higher speed, lower your merange. The value given is used as the distance of the first-stage search, so it is effectively quadrupled.
mandarinka is offline   Reply With Quote
Old 25th July 2019, 06:28   #6949  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm currently using merange 32 for my 720p encodes (max CTU and TU is 32 for better CPU utilization). Would it make sense to lower the value for example to 16-20 and enable HME (with umh,umh,umh), or is the first stage range so important that it will start to affect the final result too much?
Old 25th July 2019, 06:55   #6950  |  Link
microchip8
microchip8's Avatar
I use as ME range a value of 26 for 1080p encodes (ctu is 32 too). ME range is calculated as follows:
ctu size - 4(luma) - 2(chroma) (- 1 if me=hex is used)
You can lower it to 26 and enable HME like I do. Here the performance penalty is very minor, also considering that HME, as explained in the article I linked to a few posts earlier, has computationally low complexity
I wonder what options the poster above uses to hit a 40% reduction in speed when HME is enabled
Old 25th July 2019, 10:17   #6951  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, I need to test that change. I also noticed a severe slowdown when testing HME at its default values and with merange 32. This is with basically settings from preset 'slower' with only a few minor changes.
Old 25th July 2019, 11:55   #6952  |  Link
microchip8
microchip8's Avatar
I don't use presets but my own settings which I'm satisfied with. Here are my libx265 ffmpeg settings
X265PARAMS="ref=4:me=umh:hme=1:hme-search=umh,umh,umh:bframes=6:rd=4:subme=4:merange=26:strong-intra-smoothing=0:ctu=32:sao=0:cu-lossless=0:cutree=1:fades=1:tu-inter-depth=3:tu-intra-depth=3:rskip=1:max-merge=1:rc-lookahead=60:aq-mode=1:aq-strength=1.0:rdoq-level=1:psy-rdoq=1.5:psy-rd=2.3:limit-modes=1:limit-refs=3:limit-tu=1:rd-refine=0:deblock=-3,-3:weightb=1:weightp=1:rect=1:amp=0:wpp=1:pmode=0:pme=0:b-intra=1:b-adapt=2:b-pyramid=1:tskip-fast=0:fast-intra=0:early-skip=0:min-keyint=24:keyint=240"
Old 25th July 2019, 13:45   #6953  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Biggest differences seem to be ref=5, me star, rd=6, rd-refine, strong-intra-smoothing, max-merge=4 and amp in my settings. I don't think those should affect the search for motion though. I really need to test to get some rough values.
Old 25th July 2019, 13:53   #6954  |  Link
aegisofrime
I was using the default ME range of 57. I guess it needs to be dropped once HME is enabled.
I can't wait to get a 3900X or a 16 core Threadripper!
Old 25th July 2019, 13:59   #6955  |  Link
microchip8
microchip8's Avatar
you're maxing out a few things. rd=6 (combined with rd-refine) is IMHO overkill if you want to compromize between speed and quality
Motion Estimation is where the encoder spends most of its time and takes the biggest penalty the higher you get. rd=6 is very expensive. I'm fine with rd=4 (which is really rd=3 as 4 maps to it)
This is the best I can do on my i7 7700K when turning on HME. I don't want to wait days for an encode to finish and I won't see the difference when watching from afar on the TV
With my settings above and HME turned on, I can shave ~100 MiB of an encode. Encoded Blade Runner once with and once without HME. The result was 100 MiB in size reduction with better subjective quality when HME is on
Old 25th July 2019, 17:15   #6956  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Here are my results with my Black Sails testclip, 2748 frames @ CRF 18:
rd 6, no hme - 4333,39 kbps - 2.91 fps
rd 6, hme umh - 4323,63 kbps - 2.16 fps
rd 4, no hme - 4149,59 kbps - 3.95 fps
rd 4, hme umh - 4154,60 kbps - 2.66 fps
So the difference with rd=4 is even bigger than with rd=6 + rd-refine. I'm using a Ryzen 1800X @ 3.8 GHz.
Old 25th July 2019, 17:22   #6957  |  Link
microchip8
microchip8's Avatar
I have the opposite experience. rd=6 is too costly here. But, the tests I did were a long time ago so I'll retest again soon
Old 25th July 2019, 18:18   #6958  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Of course, it could be AVX2 which is making the difference here. On a first generation Zen CPU, it's more useful to disable it (as I've done). I'd expect an Intel CPU to benefit from AVX2.
Old 26th July 2019, 14:21   #6959  |  Link
microchip8
microchip8's Avatar
I've reported the segfault when using star for hme-search Level 0 to the x265 devs. One of them came with a patch which I tested and seems to work. Patch is not committed yet but you can find it at https://mailman.videolan.org/piperma...ly/012601.html
Old 26th July 2019, 14:35   #6960  |  Link
DJATOM
DJATOM's Avatar
Sweet, thanks.
Me on GitHub
