18th December 2009, 02:47 | #281 | Link | |
I have did the 1th test with 704x304 Win 7 64-bit.
18th December 2009, 22:06 | #282 | Link |
Software Developer
Updated x264 to r1376, using Komisar's builds.
Also piping source into x264 as YUV4MPEG from now on, so we don't need to specify the video resolution and framerate in the command-line. However we still need to detect the number of frames and pass it to x264 via command-line parameter explicitly...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th December 2009 at 22:17. |
19th December 2009, 08:09 | #283 | Link | |
HDConvertToX author
from my short test the encoding has always ended at right frame.. BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
19th December 2009, 13:27 | #284 | Link | |
Software Developer
With the YUV4MPEG format the width/height as well as the framerate are included in the stream (as opposed to "raw" YUV), so we don't need to pass those params explicitly. However the total number of frames are not included in the YUV4MPEG stream, so we need to pass it manually via "--frames" parameter. Otherwise x264 doesn't display the progress properly - and the GUI fails to parse the output. Well, how should x264 display progress, if the total number of frames isn't known? But don't worry, the GUI will detect the number of frames for you and pass the "--frames" parameter to x264 (It's just that we cannot get rid of the "Analyze" step before the encoding starts. Anyway, the analyze isn't required to detect width/height/framerate anymore)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th December 2009 at 13:37. |
21st December 2009, 17:35 | #286 | Link |
Person
http://img695.imageshack.us/img695/4153/errorwh.png
Been getting a bunch of these recently, at the end of encodes. Launcher keeps running and even working (during benchmark) until you press ok, then it crashes out. |
21st December 2009, 17:42 | #287 | Link |
Software Developer
Unless you give me detailed information on how to reproduce this problem, I cannot help. I finished dozens of encodes and it never crashed for me...
23rd December 2009, 08:13 | #288 | Link |
I am actually using this tool as my main x264 GUI front-end!
I am still having the crop issue when cropping from my .avs file, but since I am now cropping directly in my .dga file (now .dgi it seems), this works like a charm. Thanks for keeping up the good work on this one LoRd_MuldeR *EDIT* Only thing that is missing from this tool IMO is a good bitrate calculator like in MeGUI. That would be awesome! Last edited by djesteban; 23rd December 2009 at 08:16. |
23rd December 2009, 11:41 | #289 | Link | |
Software Developer
It's caused by x264, Avisynth or DGSource. Or more likely, a combination of those... What's wrong with %WINDIR%\System32\calc.exe ???
24th December 2009, 00:42 | #290 | Link |
My test results with 1920x816p, Win7 RC1 64bit, E2160@2.7GHz:
Source: D:\Temp\test_jumper_x264.avs Preset: Slow Tuning: Grain Profile: High Params: CRF 18 [Type: 32-Bit, Pipe Buffer Size: 0 MByte] encoded 202 frames, 1.86 fps, 14666.12 kb/s encoded 202 frames, 1.92 fps, 14666.12 kb/s encoded 202 frames, 1.93 fps, 14666.12 kb/s [Type: 64-Bit, Pipe Buffer Size: 0 MByte] encoded 202 frames, 1.92 fps, 14666.12 kb/s encoded 202 frames, 1.96 fps, 14666.12 kb/s encoded 202 frames, 1.96 fps, 14666.12 kb/s [Type: 64-Bit, Pipe Buffer Size: 1 MByte] encoded 202 frames, 1.98 fps, 14666.12 kb/s encoded 202 frames, 1.94 fps, 14666.12 kb/s encoded 202 frames, 1.98 fps, 14666.12 kb/s [Type: 64-Bit, Pipe Buffer Size: 2 MByte] encoded 202 frames, 1.98 fps, 14666.12 kb/s encoded 202 frames, 1.98 fps, 14666.12 kb/s encoded 202 frames, 1.96 fps, 14666.12 kb/s [Type: 64-Bit, Pipe Buffer Size: 4 MByte] encoded 202 frames, 1.98 fps, 14666.12 kb/s encoded 202 frames, 1.98 fps, 14666.12 kb/s encoded 202 frames, 1.98 fps, 14666.12 kb/s [Type: 64-Bit, Pipe Buffer Size: 8 MByte] encoded 202 frames, 1.98 fps, 14666.12 kb/s encoded 202 frames, 1.94 fps, 14666.12 kb/s encoded 202 frames, 1.98 fps, 14666.12 kb/s |
1st January 2010, 17:55 | #292 | Link |
Person
Fairly certain that has been asked ~10 times in this topic and it's been more or less said that he doesn't want to. So unless you have a specific reason for doing sequential encodes, I'd just say open a bunch of launcher applications and run them if you'll be afk for a while and wish to do so.
6th January 2010, 19:30 | #293 | Link | |
Ran a benchmark on my i7 920 Rig, 6 GB DDR3 RAM, the procesor chip is overclocked to 3.5 GHZ.
Here's the results: Encode resolution : 640x272, simply resized a sample of one of my 720p encodes Quote:
6th January 2010, 20:22 | #294 | Link |
HDConvertToX author
MicroX264 (inspired by this great gui) has a queue system
BHH
10th January 2010, 22:34 | #295 | Link |
* The tuning option is set to none by default, can you please tell me in details what other 6 options means and when I can use it?
* I understand the two pass mod, but I'm unaware of other 3 mods, CRF, QP and ABR * What is the relation between CRF > Quantizer and QP > Quantizer? * The slower preset means " better quality" ? * Is it like higher profile means "high quality" ? Could you explain the profiles * What are the recommended lower value for quantizer for high quality? Thank you. Last edited by kool; 10th January 2010 at 22:45. |
10th January 2010, 22:41 | #296 | Link | |
Software Developer
Please and, if any questions remain, ask in the Newbies forum. Also there is the "Show Help Screen" button in my GUI for a complete list of all options
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th January 2010 at 22:54. |
10th January 2010, 22:49 | #297 | Link |
@kool
a little searching and reading can help take you a long ways here are some links to help x264 settings x264-encoding-options x264_options_page1 x264Options h264-profiles-and-levels x264 explained - LoRd_MuldeR's Sig can help
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 10th January 2010 at 22:51. |
14th January 2010, 08:52 | #299 | Link |
User of free A/V tools
Small feature request
Hi LoRd_MuldeR,
could you possibly enhance the information displayed in minimized state in taskbar? I mean, currently it looks like this: When using 2-pass mode I have to maximize window occasionally just to check which pass is really running at the moment. It would be nice if that info was included in minimized window title and tooltip dialog as well. Thank you very much for your superb tool and for hearing me out! |
16th January 2010, 23:04 | #300 | Link | |
Totally different problem here:
how do I properly transcode a video-file that has this speciality: Quote:
