Old 7th November 2019, 08:44   #28961  |  Link
MrVideo
MrVideo's Avatar
@Lathe: At this point in time, if you want to take UHD video and create a BD, you are going to have to create a MKV file by using AVISynth tools, x264 & MKVToolnix to recode to 1080p. Then take that MKV file and pass it on to BDRB to create a BD.
Old 7th November 2019, 09:11   #28962  |  Link
FilipeAmadeuO
Originally Posted by zamengo View Post
You don't need to do everything twice, replace track before muxing, i have no problem with this.
Does BdRebuilder have any option to demux everything and stop ?
By default is demux one m2ts and when finished remux immediately. So I have no chance to replace subtitle...
PS - Not doing video encoding...
FilipeAmadeuO is online now   Reply With Quote
Old 7th November 2019, 15:57   #28963  |  Link
jdobbs
Originally Posted by Michi View Post
I have no stuttering between m2ts of the 0800.mpls, but no FF/REW.
Can you try the new version and let me know if it fixes your FF/REW issues?
Website: www.jdobbs.net
Old 7th November 2019, 15:59   #28964  |  Link
jdobbs
Originally Posted by yamyam View Post
ive recently switched to the UHD format & ive done a backup of spiderman far from home, first I rip to the hard drive using dvdfab untouched with no compression, if I then run it through dvdfab to bd25 the burn plays on my Panasonic DPUB450 as dolby vision if I do a bd25 with rebuilder it plays as hdr10 (using imgburn for burning), some in this forum seem to have dolby vision working but it isn't working on all players yet
im doing movie only
would it be any help if I posted the clpi file from both
just thought I would throw this in, dolby vision in dvdfab also has the ff/rew issues that have been posted about
I suspect it might be an issue with doing movie-only backups of DolbyVision sources. I'll do some testing and see if I can find anything.
Old 7th November 2019, 18:22   #28965  |  Link
jdobbs
At some point I'll add a "Resize 3840x2160 to 1920x1080" to the SETUP/VIDEO dialog. I just haven't gotten around to it.
Old 7th November 2019, 18:49   #28966  |  Link
Michi
The new version fixes the FF/REW issues on Dolby Vision discs. My Sony plays the DV-disc " Lock up" without issues.
Today I rebuild "The Last Jedi". Later I will test the rebuild.
Michi is offline   Reply With Quote
Old 8th November 2019, 13:59   #28967  |  Link
jdobbs
Thanks!
Old 8th November 2019, 17:16   #28968  |  Link
Michi
"The Last Jedi" plays my Sony without Issues. FF/REW up to 3x.
Old 9th November 2019, 02:55   #28969  |  Link
MrVideo
MrVideo's Avatar
What happens after 3x?
Old 9th November 2019, 10:23   #28970  |  Link
Michi
Nothing. 3x is the max. FF/REW Speed on my Sony x800 MII.
Old 9th November 2019, 11:54   #28971  |  Link
sandrino3867
Can you make a little tutorial for encode UHD 4K BD66 to BD25 ? Please.
sandrino3867 is offline   Reply With Quote
Old 9th November 2019, 12:30   #28972  |  Link
FilipeAmadeuO
jdobbs:
I am comparing the metafile generated by tsmuxer and bdrebuilder for the same m2ts file and i see some diferences.
Can you please check if everything is correct ?
tsMuxer GUI 2.6.12:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500
V_MPEGH/ISO/HEVC, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", track=4113
V_MPEGH/ISO/HEVC, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", track=4117
A_AC3, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", track=4352, lang=eng
A_AC3, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", timeshift=1ms, track=4353, lang=eng
A_AC3, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", timeshift=1ms, track=4354
A_AC3, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", timeshift=1ms, track=4355
S_HDMV/PGS, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", fps=23.976, track=4768
S_HDMV/PGS, "C:\Users\Desktop\Star.Wars.The.Last.Jedi.2017\BDMV\STREAM\00007.m2ts", fps=23.976, track=4769
Bdrebuilder META file:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 --start-time=27000000
V_MPEGH/ISO/HEVC, "D:\THE LAST JEDI\WORKFILES\00007.track_4113.hevc", fps=23.976, contSPS
V_MPEGH/ISO/HEVC, "D:\THE LAST JEDI\WORKFILES\00007.track_4117.hevc", fps=23.976, secondary, contSPS
A_AC3, "D:\THE LAST JEDI\WORKFILES\00007.track_4352.AC3", timeshift=-1ms, lang=eng
A_AC3, "D:\THE LAST JEDI\WORKFILES\00007.track_4353.AC3", lang=eng
A_AC3, "D:\THE LAST JEDI\WORKFILES\00007.track_4354.AC3", lang=eng
A_AC3, "D:\THE LAST JEDI\WORKFILES\00007.track_4355.AC3", lang=spa
S_HDMV/PGS, "D:\THE LAST JEDI\WORKFILES\00007.track_4768.sup",lang=eng
S_HDMV/PGS, "D:\THE LAST JEDI\WORKFILES\00007.track_4769.sup",lang=spa
My question is regarding audio delay. Are they correct ?
Because they are different and maybe this can be a reason for a small shuttering...
Old 9th November 2019, 16:31   #28973  |  Link
SquallMX
Special SeeD
Sadly CFR mode is still not working:
"D:\Archivos de Programa\BD Rebuilder UHD\tools\x264.exe" "C:\TEMP\WORKFILES\TEMP.AVS" --preset faster --bluray-compat --b-pyramid none --weightp 1 --slow-firstpass --qpmin=0 --crf 18.11 --level 4.1 --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "C:\TEMP\WORKFILES\TEMP.264.stats" --pass 1 --output "C:\TEMP\WORKFILES\TEMP.264"
[11/09/19] BD Rebuilder v0.60.29
[09:16:34] Source:  WONDERFUL_LIFE
  - Input BD size: 61.85 GB
  - Approximate total content: [03:01:14.446]
  - Target BD size: 22.95 GB
  - Windows Version: 6.2 [9200]
  - Quality: Better (Faster), CRF
  - Decoding/Frame serving: FFMPEG
[09:16:34] PHASE ONE, Encoding
 - [09:16:34] Processing: VID_00005 (1 of 6)
 - [09:16:34] Extracting A/V streams [VID_00005]
 - [09:16:38] Reencoding video [VID_00005]
   - Source Video: HEVC, 3840x2160
   - Rate/Length: 23.976fps, 551 frames
 - [09:16:38] Performing CRF Prediction...
   - Analyzing 18.11   - Encode failed.  Aborting.
  - BD-Rebuilder v0.60.29
  - Working Path Free Space: 364.55GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - LAVFILTERS:  Ok
  - X264:  Ok
  - X265:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[09:16:39] - Failed video encode, aborted
CRF mode would be great for UHD on BD25, for us mortals with low specs PCs.
SquallMX is offline   Reply With Quote
Old 9th November 2019, 17:07   #28974  |  Link
gonca
Originally Posted by FilipeAmadeuO View Post
jdobbs:
tsMuxer GUI 2.6.12:
You do realize that TsMuxer does not work with hevc and jdobbs has to correct its output to make it work
By the way, audio delay does not cause juttery playback
gonca is offline   Reply With Quote
Old 9th November 2019, 21:07   #28975  |  Link
MrVideo
MrVideo's Avatar
@SquallMX: Please CODE wrap, don't QUOTE wrap pasted text.
Old 9th November 2019, 21:08   #28976  |  Link
MrVideo
MrVideo's Avatar
And which "you" are you talking to?
Old 9th November 2019, 23:45   #28977  |  Link
sandrino3867
Anyone
Old 10th November 2019, 01:30   #28978  |  Link
dreamk
Stand By Me UHD disc
I try to make backup from Stand By Me UHD disc, but BD Rebuilder 0.60.27 did not see any of the (large size) 2160p tracks there, only few 1080p extras it can see when i opened it.
Now this new 0.60.29 can see couple small 2160p tracks too, but still not (large) movie tracks as you can see from attached screenshot. That 346MB track in the picture is biggest video track and rest are smaller than that. (BD Rebuilder defaults in that 346MB track as it assumes that is movie track)
It is this disc: https://www.blu-ray.com/movies/Stand...lu-ray/243031/
My first bug report, so my apology if missing some info and need more to know? And yes "full backup" is selected. And yes computer is configured according to first post here, so far BD Rebuilder has worked fantastic for long time already. This is first time i notice any problems.
edit: Source folder is around 55GB so it should not be problem in that either.
dreamk is offline   Reply With Quote
Old 10th November 2019, 10:20   #28979  |  Link
tebasuna51
tebasuna51's Avatar
For what?
The first CODE can't be read without move the bottom slider.
I like more for the first the QUOTE.
The CODE is intended to preserve some TAB's and other short lines.
The second CODE is ok.
Old 10th November 2019, 15:05   #28980  |  Link
MrVideo
MrVideo's Avatar
You manually add line breaks to that kind of code listing, so that it breaks correctly. Otherwise, the line wrap is within the -- and other characters, etc.
