Old 2nd March 2020, 01:49   #2081  |  Link
benwaggoner
Originally Posted by Beelzebubu View Post
I think Youtube is known to do significantly higher bitrates for AV1 than for VP9, so that could be part of why...
Really? Do you have any documentation?
This would be odd since a key point of AV1 is to be able to use lower bitrates than VP9. And as a performance-heavy SW decoder, lower bitrates help performance as well.
Ben Waggoner
My Compression Book
Old 2nd March 2020, 11:31   #2082  |  Link
Toggleton
https://www.reddit.com/r/AV1/comment...be_use_higher/
But i think that is not true anymore. Have seen more mixed results and av1 was most of the time smaller.
Will look, if we can collect data about it once new AV1 encoded videos are available(no new AV1 encoded video since 2020-02-23 in the "Popular Right Now" playlist)
Tracker how many AV1 encoded videos are in the "Popular Right Now" playlist per day
https://htmlpreview.github.io/?https...er/yt-av1.html
Toggleton is offline   Reply With Quote
Old 2nd March 2020, 21:11   #2083  |  Link
utack
AOMedia Member Spotlight with Netflix’s Manager, Android Player Infrastructure, Jeff Watts
utack is offline   Reply With Quote
Old 2nd March 2020, 23:51   #2084  |  Link
marcomsousa
I am most excited to see AV1 appear in the mobile chipsets. With hardware support, we can start pushing our AV1 support into higher resolutions. Because we have an AV1 pipeline ready, we are in a good position to help evaluate this hardware as it becomes available. I look forward to sharing our learnings with the first AV1 hardware when it comes out.
Marco Sousa
AV1 win64 VS2019 builds
Last build here
Last edited by foxyshadis; 6th March 2020 at 02:32. Reason: change code to quote to fix forum formatting
marcomsousa is offline   Reply With Quote
Old 3rd March 2020, 00:48   #2085  |  Link
benwaggoner
I can see that making sense. Given how YouTube distributes encoding, it would be hard to run AV1 at higher quality/efficiency levels with libaom. So at the same MIPS/pixel, they may have needed to use a higher bitrate than with vp9 to deliver the higher quality they wanted to with AV1. Which makes sense as their goal was to push AV1, not to use it to deliver lower bitrate or higher quality content overall (then they would have just raised vp9 bitrates).
As we're getting faster and better encoding, I would expect the AV1 bitrates to drop while maintaining quality.
Ben Waggoner
My Compression Book
Old 6th March 2020, 02:02   #2086  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Excellent! Good to see more comprehensive 10+ bit optimization being done. This is mandatory for HDR
Old 10th March 2020, 22:45   #2087  |  Link
benwaggoner
Yeah, fast ARM 10-bit will make HDR feasible on 2020 mobile devices. For user generated content at least; premium studio content will still require HW DRM.
It's be nice to have some benchmarks with details beyond "Up to 2.5x faster" - is that only in some edge cases, or is ~2x speedup a practical expectation?
Ben Waggoner
My Compression Book
Old 10th March 2020, 23:21   #2088  |  Link
nevcairiel
The optimizations covered quite a lot of very commonly used functions (MC, Loopfilter, CDEF), so I would expect quite decent improvements for the majority of clips. I believe a proper announcement with example benchmarks is still being worked on.
Old 11th March 2020, 17:27   #2089  |  Link
NikosD
It also brings new AVX-512, AVX2 and SSSE3 optimizations and improves the existing optimizations on all platforms.
Insignificant gains for 8 bit video according to Phoronix for modern CPU architectures.
Probably that's why they didn't announce performance differences from previous versions as they always do.
But huge gains for 10 bit video, as they actually begin optimizations for this colour depth for the first time, starting with this version.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 14th March 2020, 00:32   #2090  |  Link
motbob
I discovered a quirk of aom that might be of interest to some people.
Sometimes keyframes in aom look really bad even in constant quantizer mode and a cq level of 20. Examples: https://slow.pics/c/GaddIUgb
I believe this happens when the encoder looks ahead and sees that the keyframe (or parts of the keyframe) is pretty useless because not a lot depends on it.
You can fix these low quality keyframes, if you want, with --enable-keyframe-filtering=0. Obviously, this will use more bitrate.
motbob is offline   Reply With Quote
Old 14th March 2020, 17:59   #2091  |  Link
IgorC
Netflix - SVT-AV1: an open-source AV1 encoder and decoder
IgorC is offline   Reply With Quote
Old 16th March 2020, 22:19   #2092  |  Link
hajj_3
AMD's new 7nm zen2 based ryzen 4000 'renoir' laptop chips were announced today, they don't support AV1
image: https://images.anandtech.com/doci/15...e-page-009.jpg
hajj_3 is online now   Reply With Quote
Old 16th March 2020, 22:53   #2093  |  Link
marcomsousa
Zen2 based...
Also AMD is always slow on HW codec, or instructions.
Is much more important on the next mobile SoC.
Marco Sousa
Last build here
Old 17th March 2020, 00:01   #2094  |  Link
hajj_3
Originally Posted by marcomsousa View Post
Zen2 based...
Marco Sousa
Zen 2 based doesn't require them to use any specific video decode block. They can release zen 2 chips with a newer video decode block that can decode av1.
Old 17th March 2020, 05:07   #2095  |  Link
soresu
Unlikely, the 'Renoir' 4000 series APU with Zen2 cores is likely to be the last major design with Zen2, with following low cost and embedded designs likely to be derivative.
It seems likely that the Zen3 based Cezanne APU (like 5000 series) will have AV1 decoding blocks, perhaps maybe the new discrete GPU's expected later this year too.
soresu is offline   Reply With Quote
Old 17th March 2020, 09:30   #2096  |  Link
nevcairiel
Media features are typically part of the GPU, not the CPU, as such Zen2 or Zen3 wouldn't make the key difference, but the Vega graphics on them would - which isn't even RDNA yet, so its rather old.
Old 17th March 2020, 12:31   #2097  |  Link
NikosD
Renoir SoC has a special version of Vega at 7nm that has borrowed multimedia engine from Navi aka RDNA.
We have to actually run DXVAChecker to see real features and decoding speed.
Old 17th March 2020, 18:39   #2098  |  Link
marcomsousa
OnePlus 8 Lite will support AV1 HW decode.
The normal or the PRO version doesn't because Qualcomm do not support it.
Marco Sousa
Last build here
Old 18th March 2020, 10:51   #2099  |  Link
utack
What is Qualcomms deal at this point?
Are they silently preparing another Patent Pool for AV1 like Sisvel, or are they just lazy and indecisive
Old 18th March 2020, 18:31   #2100  |  Link
hajj_3
new macbook air has been released, it uses a 10th gen intel processor, no info about AV1 decoding or not: https://www.apple.com/uk/macbook-air/specs/
