6th November 2013, 18:32 | #241 | Link | |
AVS+ Dev
6th November 2013, 19:31 | #242 | Link | |
AVS+ Dev
2) That is not possible with current Avisynth. To make this work, all existing plugins would need to be modified (though rather trivially). Anyway, if you do that, you can throw out all exisitng plugins until they are changed, or you can use a wrapper layer which throws away the advantages of your system. Btw, VapourSynth does exactly lthis. It lets plugins specify precisely which frames they need for the current job without the thread having to wait for their availability. This is what allows VapourSynth to implement pipelining, which has its advantages, but also drawbacks IMHO. 3) This is not really a new thing. MT-mode is allowed to be provided by filter itself in both VapourSynth and Aisynth+ (I'll write about that soon in another post), and the modes are already established in all projects. 4) This is similar to what Avisynth+ will allow: to have several frames being processed in parallel, all potentially from different stages of the filterchain. And I think this is possible in VapourSynth too, though I don't know enough of it in this respect to be sure. 5) No cache and strict refcounting: The first is bad for performance, the second is not possible without breaking plugins. I'm in the middle of adapting the cache and memory management of Avisynth+ for multithreading right now actually. Out of curiosity I have made various tests and measurements along the way here, like seeing how the filter chain performs without caching. Absolutely miserably. Caching is so important, that without it performance drops to only a fraction of what it was. Strict refcounting (throwing out frames the moment their refcount drops to zero) is not posisble without breaking all 2.5 plugins, because they have the relevant piece of code baked in. So you can modify the refcounting code to drop frames when the count reaches zero, but that part will not execute in 2.5 plugins. The result is that you will leak every single video frame (possibly multiple times, once for each stage), unless you only use 2.6 plugins, otherwise you'll run out of memory in 100-200 frames using a 720p video. I have found that out the hard way, trying to debug said memory leak for more than a day. FYI, this is exactly why I need to rethink my concept of the new caches in Avs+, which leads to MT being delayed somewhat. A possible "solution" to this refcount problem is to recompile all plugins for the 2.6 interface. But there are a lot of plugins out there, and just because you publish recompiles does not mean the users will not keep using old 2.5 plugins. And we don't even have the source for all plugins (even though we do for the most). All in all, I'm not gonna pursue this, and will instead just implement a different architecture that will work with existing plugins. Last edited by ultim; 6th November 2013 at 19:41. |
6th November 2013, 21:44 | #243 | Link |
1) Scheduler is "advanced" threadpool. Instead of throwing many threads with random caching on hardware and hoping it would work faster, scheduler do exactly the needed work.
2) Like I said, "wrapper" plugin can provide the required additional information, no problem for most filters. In worst case it'll do fail-rerequest route. 5) Cache is absolutely meaningless waste of space if you already can provide all required source frames for the filter call. General refcounting is done by scheduler based on 2, wrapper can do additional refs in response to 2.5 frame refs, but I guess it won't be used much. |
6th November 2013, 22:21 | #245 | Link | |
Professional Code Monkey
VapourSynth works kinda 80% like what you describe. 1. There's scheduling, all frame requests are basically put in a queue and processed in order using a thread pool. If a request can't be processed at the moment (the filter instance is already busy) then it simply looks at the next request in line. 2. VapourSynth filters basically work like this. On the first call they request all (or at least most) frames necessary. Then the filter gets called again when they are ready. The procedure can be repeated if necessary. 3. Exactly 4. You get kinda an implicit, cheap version of this in VapourSynth. It combines requests for the same frame (even before looking in caches) so in many cases it ends up working very well. Even temporal filters normally have a very low number of requests to the actual caches. 5. If filters can do unexpected things you need some kind of cache. Of course 80% of the ones automatically inserted will just be wasting their time doing nothing much at all. And remember that users can also do unexpected things such as seek around in vdub. I do however think avisynth wastes obscene amounts of ram for its caching. Frames have strict reference counting. Avisynth compatibility works like you say, only difference is that the magic "prefetch list" is compiled in. The method of threading for avisynth filters is a single instance running in its own avisynth environment wrapper. So there are always as many "avisynth environments" as there are filters. In combination with the prefetching each filter instance can at most fully use one cpu core (which usually turns out to be enough since stuff like mvtools is a gazillion medium complexity filters stuck together).
6th November 2013, 23:46 | #246 | Link |
ultim
No, superscalar is scheduler. Its execution pipelines are hardware threads, executed "instructions" are filter instances (according to their threading capability) that work on "registers" – frames. The key points are breaking the call chain and refcounting instead of cache. Myrsloik I'm not interested in VapourSynth. |
7th November 2013, 02:07 | #247 | Link |
So in the end it all comes to the "we need to modify all existing plugins" problem. "Nice".
I guess we'll have to set up a huge repo for all the (useful) plugins ever created and start making them less bad some time soon. I just really want to hope I won't be the only one working on this. |
7th November 2013, 12:44 | #248 | Link | |
AVS+ Dev
So there's a real bunch of reasons for setting up a repo for plugins, but there are some basic questions to be answered:
IMHO these are important questions that we should try to answer appropriately before doing anything rash. On the other hand, if we do can handle these question correctly, I'm all for it. Last edited by ultim; 7th November 2013 at 12:48. |
7th November 2013, 13:07 | #249 | Link | |||||
Wow, stop ruining my dreams so fast...
Are there many useful of those? I never actually bothered to check what's closed and what's not. But well, reverse-engineering is pretty much the only thing we could do about these. Not that you don't have to do the same with some open "source" plugins... Of course anything large and complicated is out of questions. Quote:
What we can and should do is making the most popular plugins used in literally 100% of scrips better, so most users get the most benefit from our work. But we cannot save the whole avisynth ecosystem. Last edited by TurboPascal7; 7th November 2013 at 13:10. |
7th November 2013, 14:52 | #250 | Link | |
Binary compatibility with old 2.5 plugins would still be maintained – wrapper is exactly the thing for that. It would cost some efficiency and will require handwriting threading information, but nothing like recompilation required. Even with other design plans I still suggest the "wrapper" idea: separate from the core plugin that provides compatibility layer. No need to integrate legacy into the new core. |
7th November 2013, 19:37 | #251 | Link | |
AVS+ Dev
So basically, I can't count on any of the interface improvements made in 2.6. "Great." I can always use wrappers for any kind of 3rd, 4th, 5th interface, but that would still mean keeping around old code, except maybe in its own module. Not to mention now I'd even have to make sure the "glue" logic also works. So thanks, but no. In this case I'll rather continue what I was doing sticking to 2.5-style, and devise *one* new interface for Avisynth+ in the future, when the more important stuff are out of the way, and I can make sure that it will finally be alright. I am not in the mood of maintaining 4+ (redundant!) interfaces, and I don't think I ever will be. But to avoid misunderstandings, plugins should of course still use the 2.6 header. There is currently nothing better than that, as it is most feature complete, and does not suffer from the "baked code syndrome".
You say that we can do refcounting our own way however we want, and provide a wrapper for 2.5 plugins. That means we still have to duplicate the extremely complex old-style Avisynth caching, except in a wrapper, but in addition we must also develop and maintain a second caching system, the primary one?! This is just not worth it, because the old cache basically works. Yes it is way too complex for what it does. Yes it eats memory. But it works and it is not a performance bottleneck. So what reason is there to develop a completely new one if we still have to continue living with all the drawbacks of the current cache, except in a wrapper? Last edited by ultim; 7th November 2013 at 19:40. |
8th November 2013, 17:41 | #252 | Link |
2.6 interfaces are useless – they solved nothing while breaking binary compatibility, usage is very low. I'd say implement only 2.5 compatibility.
New interface obviously needs to be the only one and extensible. Btw, this implies that it must be C style and not the C++ hell like now. For exact design I'd say COM-like: great scalability and linking compatibility. As for wrapper complexity – it greatly depends on which and how efficient you want it to support quirks of 2.5. Sure, maybe 2.5 plugin that formatted your hard drive would require total emulation to work correctly, but do we care? I suspect that quite simple wrapper + some special cases would be ok for most interesting plugins. And FTY, caching is the main problem of Avisynth MT. Not threading hacks, not 32-bitness how quite a few people think. And it is performance bottleneck. |
8th November 2013, 19:07 | #253 | Link | |
AVS+ Dev
I also agree that new interface needs to be C-style. My plans are to make it object oriented (as far as C allows), but keep objects totally opaque. An extremely thin C++ wrapper shipped as public include files will provide C++ binding, but it will only provide syntax sugar and some help in memory management thanks to destructors. |
11th November 2013, 14:32 | #255 | Link |
AVS+ Dev
Status update
You have probably noticed that this release of Avisynth+ is taking longer than previous ones. The good news is that not because we are stalling, but because the features we are working on are a lot larger, and also a lot more complex.
Other good news is that people have started joining in on the project. TurboPascal7 and innocenat have been working on bringing you full-fledged 64-bit functionality, qyot27 has already sent a pull request to give you a nice automated installer, and I myself am introducing multi-threaded processing. So, look forward to the next release! Last edited by ultim; 11th November 2013 at 14:46. |
12th November 2013, 06:37 | #256 | Link |
Looking forward to 64 bit and multithreading. A few questions:
1. Will the installer be able to extract the dll's with 7zip? 2. Will the dll package still be available? 3. At some point in the future, would JincResize (from madvr) be considered?
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
12th November 2013, 07:16 | #258 | Link |
There was a lot of talk about it in the madvr thread last year. I believe it's based on: http://www.imagemagick.org/discourse...p?f=22&t=21415 there's some code on page 2 and maybe more in later pages. This might be part of it: http://forum.doom9.org/showthread.ph...id#post1595043
But only madshi and maybe NicolasRobidoux would really know.
12th November 2013, 08:36 | #259 | Link |
契約者
For Jinc, you also need madshi's anti-ringing, it sux without it.
Also if someone is going to implement it, it will be cool if needed calculations can be done in GPU. Unless it'll be comparable to spline36 by speed. Cause if it'll be slow, one could just go with nnedi/eedi+subpixel shift(if desired) and get better results. And Jinc is also not something you're going to use for downscale. It could be way simpler if madshi could just turn that part of his renderer into a plugin (even if closed-source). |
12th November 2013, 08:40 | #260 | Link |
Moving stuff to GPU and back is not worth it if resizing is the only thing you're going to do. So no, this is not going to work.
Also, fmtconv might get ported to avisynth some time in the future. We might as well wait for it before spending our time on something that might end up replaced by fmtconv. |
