Old 10th January 2019, 19:23   #1  |  Link
moutezz
How to fix DTS HD-Master to DTS conversion ?
Hi everybody, I hope you doing well
I just extracted a 4.2 go DTS HD Master sound from a movie and I tried to convert that sound to DTS with EAC3toGui and with eac3to but the two softwares gave me an offset sound (-2.5 seconds).
The movie has a duration of 2h24m19s, but after convertion I found that the sound has 2h22m34s, same result with both EAC3to.
What I have to do to fix this & to obtain the same duration as result ?
Thank you.
moutezz is offline   Reply With Quote
Old 10th January 2019, 19:38   #2  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Are you attempting to extract the DTS core from the DTS-HD MA stream?
Old 11th January 2019, 19:25   #3  |  Link
moutezz
That's what I wanted to do, the problem is : the DTS Core obtained does not have the same duration.
Old 11th January 2019, 23:24   #4  |  Link
tebasuna51
tebasuna51's Avatar
Then the DTS-MA is corrupt.
Is not possible different duration for DTS-MA and the core.
Please show how do you obtain the core with eac3to (forget the obsolete EAC3toGui)
Old 17th January 2019, 19:35   #5  |  Link
moutezz
Ok,
With eac3to I proceed like that-------- Source---Add source file-----eac3t audio-----Input file(s) or Folder (choose my file)-----Save As Type (DTS or AC3)-----File Name (without forgetting the DTS bitrate or AC3 bitrate, choose the Hz (for me 48000 Hz)
After that I go to Downmixing & choose "Downmix 7-8 Channels to 6 Channels.
Misc with "Extract the Core of DTS HD or 7.1 Track"
Run Command Line.
I almost forgot Paths for ( Eac3to-MKVMerge-TsMuxer-NeroAACEnc )
About EAC3to Conversion Utility ------Source File-------Destination File (without forgetting the extension at the end)--------Conversion Options 1------------DTS just below Check Extract DTS Core----------Downmix options--------Downmix to 6 ch-------Convert
I wait until the end of the conversion, if there is a problem just tell me.
Thank you.
Old 18th January 2019, 01:23   #6  |  Link
tebasuna51
tebasuna51's Avatar
Run Command Line.
Seems yr_eac3to_more_gui
I don't know how use that GUI to extract the core from a DTS-HD
I can't help you with that old GUI.
Seems EAC3toGUI
Work fine for me extracting the core from a dts-hd.
The core is already 5.1, you don't need the Downmix part.
Old 18th January 2019, 12:46   #7  |  Link
SeeMoreDigital
It might be possible to use good 'ol fashioned TSmuxerGUI to extract the 'core' from media files that contain lossless HD audio...
Old 5th February 2019, 15:35   #8  |  Link
moutezz
Hi again and sorry for the the delay,
I only want a solution, and it does not matter which software to use.
Old 5th February 2019, 15:37   #9  |  Link
moutezz
So help me with other software.
Old 5th February 2019, 22:11   #10  |  Link
tebasuna51
tebasuna51's Avatar
Whit EAC3toGUI all work fine for me.
The core have the same duration than the full DTS-HD.
Old 6th February 2019, 15:36   #11  |  Link
moutezz
I will, I will try another attempt.
ac3, dts, dts-hd ma, eac3to
