Old 3rd April 2008, 13:26   #61  |  Link
blutach
Country Member
blutach's Avatar
Demux with PgcDemux. Remux with muxman putting in the appropriate audio delay.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 3rd April 2008, 14:01   #62  |  Link
MSlv
ok, thanks very much. gonna try it as soon as i have the time.
AMD Athlon 64 3000+ 2.0 GHz
Nvidia GeForce FX5200, 256 MB
Gigabyte nForce3 250, 512 MB RAM
Maxtor 80 GB 7200rpm
XP PRO 5.1 (Build 2600) SP2
TDK DVDRW882N|TEAC CD-W540E|ASUS E616
MSlv is offline   Reply With Quote
Old 25th May 2008, 07:35   #63  |  Link
DHRACER7
could you get Blutach to put his "Your folders should look like this after installin pgc edit with plug ins" He had at the other forum It never downloads for me any other way
DHRACER7 is offline   Reply With Quote
Old 13th February 2011, 21:28   #64  |  Link
tannenba
Using IFO Edit
Hi, I have an older DVDR that won't record in widescreen.
I can fix the disk by setting the tv's screen., but the old tv in another room sees a squished picture.
I read about IFOEdit and tried it. Works great on the computer- goes widescreen nicely, but the DVDR doesn't
play it. I must be doing something wrong, but don't know what.
Thanks,
Joe
tannenba is offline   Reply With Quote
Old 28th November 2011, 17:39   #65  |  Link
tannenba
Duh
Thanks,
Joe
OK, figured it out: Rip DVD done by DVDR; IFOedit the ifo files;Use DVD rip softwae to put it back on the DVD.
I use DVDFab for ripping/copying.
Joe
Old 18th July 2015, 20:35   #66  |  Link
kirous
help in my post
Hello friend 2cool's, is that you know a lot about the PgcEdit program.
I'm rather new to the program, you help me in this problem I am in my post:
http://forum.doom9.org/showthread.ph...09#post1730609
We appreciate it.... Sorry my bad English XD!!
kirous is offline   Reply With Quote
Old 19th July 2015, 19:59   #67  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
This tread has not been updated since 2011, and 2cool is not active here any more.
I have already tried to help you at DVF, and I will not retry here. Hopefully, you'll find someone that can understand what you want.
r0lZ
