18th November 2007, 21:26 | #1501 | Link | |
http://www.mh-nexus.de/ Also you might want to contact the xport author and ask for a fix. Should be really easy for him to fix. |
18th November 2007, 21:28 | #1502 | Link | |
You could try Haali Media Splitter -> Dump. Don't know if that's more reliable or not. |
18th November 2007, 22:12 | #1508 | Link | |
i'll report the bug to the xport author asap |
19th November 2007, 03:16 | #1511 | Link | |
Version 0.99 http://www.w6rz.net/xport.zip I wasn't able to fully test it, since I don't have any full movie .m2ts files. However, I did regress it with the samples I do have, so it shouldn't be any worse. The error message "LPCM sample resync, adding x samples" will occur when xport detects a mismatch (it looks for a match at the beginning of every PES packet). It just adds enough samples to pad out to the expected number of channels. A/V sync should not be affected too much, since it's only 1/48000 of a second (20 microseconds). The error message should only occur at concatenation points. xport will not pad the end of a demuxed LPCM file. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
19th November 2007, 08:45 | #1513 | Link |
When combining Ratatouille files you need to run the resultant large m2ts file through tsremux again - rewriting the timestamps. This is NEEDED to fix playback in Haali and many other players, and will probably fix demux issues when using xport on the big file.
19th November 2007, 09:02 | #1514 | Link | |
eac3to |
