Old 7th December 2004, 22:24   #201  |  Link
karl_lillevold
karl_lillevold's Avatar
Re: Re: Nero (Ateme) H.264 in Avisynth duration not found
Originally posted by Sagittaire
try with trim:
a = DirectShowSource("output.mp4", fps=23.976, audio=false)
a = trim(a, 0, 1500)
return a
perhabs bobololo or babagaya could post in PM beta parser and beta decoder for your test ... lol
Trim did not make any difference.
Actually, Ateme was kind enough to let me participate in the Beta test, so I have version beta-4a. With this, I can kind of get Avisynth to work without seek. However, normal DirectShow playback, which the Nero versions of the filters handle well, is not working well in Ateme's versions, with frozen video, failed seeks, player will not open etc. (on the Nero encoded content)
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 7th December 2004, 22:27   #202  |  Link
Andrey
Hi, guys !
>>Sharktooth: Finally recode works.
You are lucky. Still no chance for me.
But I'll try your method step by step when I have spare time, may be it will help...
>>Soulhunter: If I add "ConvertToRGB32" to the script, recode simply disappears !?!
My current installation (show mpeg4 enc) disappears EVERY time I tried to use avs source, regardless of what is inside
And
>>Noise can be safely filtered out and then added during playback.
>>Film grain cant...
Hm ? Is that bolobolo, who showed here an example of analysing film grain before encoding and adding it after ?
And said that it is one of the tools they gonna to implement in the future...
Or I'm wrong ? (It was in that beta test chain on this forum)
Andrey is offline   Reply With Quote
Old 7th December 2004, 22:41   #203  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Originally posted by Andrey
My current installation disappears EVERY time I tried to use avs source...
Have you tried to delete the WarpSharp.dll from AviSyths plugin folder ???
Maybe moving all plugins in a different folder works...
Nope, that was me...
But you need ffdshow to do this !!!
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 7th December 2004, 23:00   #204  |  Link
babayaga
Originally posted by Soulhunter
Well, for me the noise and film-grain is part of the image detail !!!
Btw, I think most ppl use denoising to raise the compressibility...
Thanks, the "Samples.zip" is on the way...
EDIT: Ok, its uploaded now !!!
Bye
I disagree about the film grain "removal" in the shot you sent
There is indeed a loss in grain for both encodes (Xvid and ND) but it appears to me that it's closely related to the B-frames sequence :
- ND B-frames are a little bit more blurry than XviD's but less noisy
- ND P-frames are a little bit more precise than Xvid's and less noisy
- The P-B sequences are not the same so the alternance of noisy/blurry frames is not the same
As a result, a part of the grain you think Xvid preserves is noise added (mostly in B-frames) and the overall impression is closely related to the P-B frame sequence.
As a matter of taste, in this very shot I prefer our way of handling the grain (it looks more "smooth" or less "rusty" to my eyes).
babayaga is offline   Reply With Quote
Old 7th December 2004, 23:15   #205  |  Link
bond
Originally posted by Selur
did anyone get it working in Graphedit?
gives me a
"The filter could not be created. Resource used by this filter may already be in use. Class nor registered (return code: 0x80040154)"
error,...
hm, any news on that? did anyone manage to encode using neros avc encoder directly in graphedit as it was possible with neros asp encoder?
Ogg Theora | Ogg Vorbis
Old 7th December 2004, 23:17   #206  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
Well, imo its not really a "matter of taste" thing...
I think a codec should be able to reproduce the source as exact as possible !?!
For me this means, if the source looks "rusty" the encode should look rusty as well...
If you prefer a clean "not rusty" look, you can use one of the numerous denoisers out there !!!
Bye
Old 7th December 2004, 23:22   #207  |  Link
Andrey
It works. Thanks a lot !!!
BTW, why the hell unused(loaded automatically?) plugins (and plugins at all) affects this ?
Old 7th December 2004, 23:26   #208  |  Link
Manao
Because they are loaded when avisynth dll is loaded ( in order to know which filters are available )
Manao is offline   Reply With Quote
Old 8th December 2004, 01:16   #209  |  Link
nicco
TeacH Me!! I'm so n00b!
nicco's Avatar
originally posted by Teegedeck
Perhaps that Gladiators don't really have such a smooth skin?
it depends, I think, on their make-up!
@soulhunter
Premised that quality is subjective (and personally I don't like source-noise), I think you are right with this:
But I really like avc denoising in your shot!
nicco is offline   Reply With Quote
Old 8th December 2004, 01:48   #210  |  Link
babayaga
Well that's exactly what it does
If you prefer a clean "not rusty" look, you can use one of the numerous denoisers !!!
I was refering at the look of the noise *not* the video itself.
The source noise is by far not as rusty as the Xvid result especially in B-frames : the added noise in B-frames compensates too much the compression loss.
So in my opinion, there is also a compression loss in ND. This one is smaller than with Xvid (since we have a higher coding efficiency) but is not compensated by an artificial encoder noise like in Xvid.
For those who want to make their own mind, the clips are in ftp://mood.ateme.com/Samples.zip
Old 8th December 2004, 04:38   #211  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
I prefer the xvid encode. It's sharper and noise/grain is more like the source. AVC encode b-frames are too much "denoised/smoothed".
BTW i spotted some "imperceptible blocks" in the background in both the encodes.
Old 8th December 2004, 13:06   #212  |  Link
nicco
nicco's Avatar
@soulhunter
If you look at my DV-movies you'll understand why I use denoising filters..
Personally, for my sources (almost only DV) I prefer avc "denoised picture", becouse details are preserved, and it's hard to me to notice lousy bloks
Old 8th December 2004, 13:54   #213  |  Link
temporance
For me, it's the opposite. We're not talking about denoising, we're talking about "de-texturing" too. I would rather have a few blocking artifacts if it means I can actually see some detail in my movie. AVC is as good at ASP at making sharp edges and strong details look sharp. It is not good though at preserving fine textures, and I don't just mean film grain. Things that make the movie look 'real' (e.g. rough paintwork, actor's crowsfeet or stubble, lichen growing on a wall, leaves on a tree and blades of grass) are better represented, IMHO, by ASP than AVC. Anyway, it's early days and I'm sure this argument will be fought, won and lost over the next year or so.
temporance is offline   Reply With Quote
Old 8th December 2004, 14:13   #214  |  Link
Tommy Carrot
Tommy Carrot's Avatar
Well, the smoothing away of the fine textures is an unfortunate side-effect of the loop-filter, similarly to the post-filter of mpeg4 asp, and this is the reason most of us don't use post-filtering at playback. The problem is, disabling the loop-filter won't solve the issue, but it creates other, because IMO the blocking effect of h.264 is much more annoying than in the case of mpeg4 asp. You can try to decrease the loop-filter strength, perhaps you can find a more optimal setting, where the smoothness is not so obvious, and the blockyness is still tolerable.
Tommy Carrot is offline   Reply With Quote
Old 8th December 2004, 14:18   #215  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
@ temporance
True, much ppl dislike WMV/RV9 for its "smooths out too much fine details" behavior...
Maybe lowering the high frequency cut-off in exchange for some ringing could prevent this !?!
Bye
Old 8th December 2004, 14:36   #216  |  Link
nicco
nicco's Avatar
True!
Is what I've done!, a deblocking value of 1 (no adaptive) is very good for me
I was talking to de-texturing too.
I agree, but these details should be more noticeable than blocking artifacts, If I can see these details only with a lens I prefer a bit smoother picture rather than a "party of blocks".
However these are only my own opinions, you have yours!
my shots (postprocessing disabled):
[EDIT]updated
Old 8th December 2004, 15:40   #217  |  Link
temporance
@ babayaga
I downloaded your samples, wow that's a high bitrate you use! I prefer the xvid version: the film grain / noise is more alive. The AVC encode has a slight 'dirty window' effect - there seems to be some artificial temporal correlation or "stickiness" of the noise (and the image appears very slightly softer).
@ Tommy
I don't have a problem with ASP deblocking. It doesn't hit texture in flattish areas of the image in the same way that AVC does. Perhaps it's partly helped by the larger block size in ASP. Also ASP deblocking is completely in the hands of the person and the codec doing the decoding - in-loop filtering is decided at encode time.
I have more experimentation to do. Trying AVC with no and minimum deblocking next....
Old 8th December 2004, 15:44   #218  |  Link
temporance
[EDIT] my shots (postprocessing disabled):
[/B]
Interesting. But is it fair to compare DivX and xvid without PP against a deblocked AVC image? Btw, how does the moving picture look - is the blockiness of ASP more/less apparent?
Old 8th December 2004, 16:54   #219  |  Link
skal
Also: how comes "AVC DEBL=1" invented the two sharp skin spots
on the bottom-right corner of the very last picture?
(is it what is refered to as "film grain generation" ? hehe )
More seriously: did you check all the pics are P-frames, e.g.?
(or b-frames, for that matter)
-Skal
skal is offline   Reply With Quote
Old 8th December 2004, 19:02   #220  |  Link
nicco
nicco's Avatar
In fact, there is also a non-deblocked avc image! Postprocessing is disabled both in asp and avc.
The blockiness is less apparent in avc-deblocked movie(the last one), even compared with postprocessed asp.
Don't ask me!
