Old 24th January 2009, 19:45   #21  |  Link
Glorioso
Originally Posted by deank View Post
Have anyone of you seen THUMBNAIL preview of an AVCHD folder on their PS3 or other AVCHD player?
There is a folder and files:
<root>\AVCHD\AVCHDTN\THUMB.TDT (which is a simple JPG)
and
<root>\AVCHD\AVCHDTN\THUMB.TID
Dean
deank, how can i manualy create the thumbnail?
Glorioso is offline   Reply With Quote
Old 24th January 2009, 19:51   #22  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
It was my question if anyone has ever seen such thumbnail.
The thumbnail is a small JPG file. PS3 doesn't show thumbnails from USB as we all know... I don't know how this could be used or it is just generated by AVCHD camcoders and Panasonic HD writer.
Old 26th January 2009, 18:52   #23  |  Link
deank
deank's Avatar
Here's a small thought on the 'custom menu' issue...
Using avisynth and x264 for showing 10-40 lines of text is like using a bulldozer to dig a hole to plant a single flower.
Using Java TV and BD-J should make things far-far easier.
But before I start working on it - does anyone know if BD-J works if authored in AVCHD format written on a DVD or USB?
I've seen a lot of BD-J games in the past, but I can't make them work now.
Old 5th February 2009, 15:48   #24  |  Link
deank
deank's Avatar
Help with Palette Segment in BDMV
Is there an easy way to find the Palette Segment in a m2ts file?
I can change the color of the Interactive Graphics Stream, but I don't know what is in the color look-up table and the colors are randomly selected.
I see three values for color index + one for alpha (opacity).
For example I have these:
11101011 10000000 10000000 (EB 80 80 - WHITE)
00010000 10000000 10000000 (10 80 80 - BLACK)
10101101 00011010 00101010 (AD 1A 2A - GREEN)
00111111 11110000 01100110 (3F F0 66 - RED)
These represent the color and another byte for alpha.
I struggle to find how to use this 8 bit Index lookup table.
The first byte seems to be the luminosity strenght, the second and third define the color...
I'm not sure if it is in YCrCb format..
edit again..
It is YCrCb...
Old 5th February 2009, 17:05   #25  |  Link
deank
deank's Avatar
I will implement custom color for IGS in multiAVCHD using RGB->YCrCb with the following settings
Y = CA*R + (1–CA–CB)*G + CB*B
R–Y = (1–CA)*R + (CA+CB–1)*G – CB*B
B–Y = –CA*R + (CA+CB–1)*G + (1–CB)*B
NTSC CA = 0.2568
NTSC CB = 0.0979
PAL CA = 0.1819
PAL CB = 0.0618
I decided to use NTSC and PAL CA/CB values as set by ITU 709 for full color range (0-255).
I will report after I test how it works.
Old 6th February 2009, 12:47   #26  |  Link
deank
deank's Avatar
RGB to YCrCb conversion for IGS in multiAVCHD was taken from this page
Credits to the authors at www.fourcc.org.
Old 8th July 2010, 08:53   #27  |  Link
wangzongjun
Can anybody help me?
I read a PES Packet from *****.m2ts file(TS packet's PID = 0x1400[Interactive Graphics Stream])and parse the PES header ,but i do not know the remain data.I think it hold the blu-ray menu information,such as palete,navigation command and so on.Can anyone give me some suggestion ?
wangzongjun is offline   Reply With Quote
avisynth, multiavchd, x264
