Old 12th January 2010, 17:34   #961  |  Link
Originally Posted by tormento View Post
I have found that it can't correctly find the Video PID. It puts 2 instead of 1011. If I manually put 1011, it works.
If you give me the stream sample I can fix that.
Old 12th January 2010, 17:41   #962  |  Link
tormento
Acid fr0g
tormento's Avatar
PM sent.
@turment on Telegram
Old 13th January 2010, 11:06   #963  |  Link
Audionut
Hi neuron2, A little bug (feature request).
Load a MKV and select audio demux. Select the stream. Replace the automatically generated filename with whatever (no extension) and dgnv doesn't automatically add the extension back when saving.
So if i'm demuxing audio from myrip.mkv, dgindex will open the filesave box with myrip.ac3. If I decide to change then name to a-better-rip, dgindex doesn't add the extension for me cause i'm lazy and I end up with a-better-rip file instead of a-better-rip.ac3.
http://www.7-zip.org/
Old 14th January 2010, 11:46   #964  |  Link
Desaster Dan
Desaster Dan's Avatar
Hi Neuron2,
First thank's for the great NV Tools.
Blue - Ray encoding time is still a pain in the ass, but less....
I have one big wish, and one problem:
At first, please stick your head together with all the other bosses
and make it possible to run your tools inside Staxrip.
The other thing is, since I canged to win7 64bit, i have problems with the licence file.
After every reboot it seems to be invalid.
up to now I generated 5 licence numbers, so the end is near.;o)
Any solution?
Is this an UAC Problem?
Thank for help,
Daniel
Desaster Dan is offline   Reply With Quote
Old 14th January 2010, 15:48   #965  |  Link
It already works fine for me. Did you try with and without the CUVID Server?
I will have access to a Win7 machine in a while, at which point I can investigate.
I have no idea about that. I can reset your license count when you run out.
Old 14th January 2010, 19:36   #966  |  Link
tormento
Acid fr0g
tormento's Avatar
Hi Neuron2, got a look at my video problem? Any hope to get the multiple file chapter feature too?
Old 14th January 2010, 21:40   #967  |  Link
Desaster Dan
Hi Neuron2,
Thank's for reply.
About this staxrip thing:
Normaly i use dgmultidecodenv.dll, so there is no need for the server.
I don't know mutch about the new staxrip build, cause i paused for the last 2 weeks.....
But I know Multitask was very close to the problem. Is there any
breakthrouth?
Anyway, i know, the staxrip treat would be the better place for that, but is there any howto for the changes I have to make in Staxrip to make it working? actually i'm working with version 1.1.4.1.
If it's workin for you, plz tell me the secret screws i have to turn. ;o)
regards,
Daniel
PS: have mercy with my lousy english
Old 14th January 2010, 22:39   #968  |  Link
stax76
staxrip & mpv.net
@Desaster Dan
I'll get a Nvidia card tomorrow so yes, we are working on it.
I have a dream by Martin Luther King
one hundred years later...
We can never be satisfied...
With this faith...
Let freedom ring...
Old 14th January 2010, 23:00   #969  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@neuron2
i got good news to report DGIndexNV IS WORKING WITH StaxRip 1.1.4.1
settings
MuLTiTaSK is offline   Reply With Quote
Old 14th January 2010, 23:46   #970  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@neuron2
once you running on Win7 @ stax76 installs his new nvidia gpu maybe together you guys could come up with a solution with unloading AviSynth scripts from the gpu's memory
cause to me it seems that script calls fill gpu memory eventually causing further calls to crash the gpu but progress sure is being made
Old 15th January 2010, 00:47   #971  |  Link
stax76
staxrip & mpv.net
Somebody recently posted in a MeGUI thread using only 3 instead of 4 memory slots helped making NV tools work.
I'll have a card shortly, it will be:
G512P Sparkle (R) 9400GT 512MB DVI/TV
I'll test it on Win 7 Ultimate 32bit, I might also be able to test it on XP since I should still have my old XP partition. If it's related to the memory on the card, how about then testing source files with smaller resolution?
With this faith...
Let freedom ring...
Old 15th January 2010, 01:02   #972  |  Link
A single instance should not run into any memory issues. You're not opening multiple instances, are you?
Old 15th January 2010, 01:10   #973  |  Link
stax76
staxrip & mpv.net
Single instance, yes. I'll be running it with a debugger tomorrow.
With this faith...
Let freedom ring...
Old 15th January 2010, 03:40   #974  |  Link
I have it fixed and will release a build tomorrow.
When something has only one user asking for it and it is a nontrivial thing and I don't need it, it's hard for said thing to rise high on the priority list.
Old 15th January 2010, 12:15   #975  |  Link
tormento
Acid fr0g
tormento's Avatar
Great.
Any idea on how to sum timecodes?
Old 15th January 2010, 16:17   #976  |  Link
cweb
cweb's Avatar
Hi Neuron2,
Any solution?
Thank for help,
Daniel
I'm working without problems under win7, but it's 32bit win7...
PC specs for bug reports: Athlon 64-bit Phenom II X6 2.8Ghz Win7/Linux PCI express NVIDIA GTX 285 graphics card
http://twitter.com/cwebdesign
cweb is offline   Reply With Quote
Old 15th January 2010, 17:55   #977  |  Link
nurbs
Windows 7 64bit works fine here.
Old 15th January 2010, 18:27   #978  |  Link
Desaster Dan
Hm,
once again I'm the only dummy with such a problem ;o))
Old 15th January 2010, 22:27   #979  |  Link
cweb
cweb's Avatar
Hm,
You're no such thing. It's a question of tracking down what may be affecting your installation.
Old 16th January 2010, 13:17   #980  |  Link
Abnormal1
I have got a mpg source (Pirates of the Caribbean Dead Man's Chest) that is causing DGToolsNV to crash at save but DGIndex seems to process just fine.
It was created by extracting the mpg from the mkv that I created using MakeMkv. (Done this way as Anydvd -> Dvd Decrypter Ifo Mode would cause audio sync issues)
I can PM you a link to the first 50mb of the file if you wish (used Cuttermaran)
Thanks
Neil
Abnormal1 is offline   Reply With Quote
