Old 7th February 2009, 22:24   #1081  |  Link
DarWun
I need to see the META files from each of the two builds.
I deleted the Working Files directory last night to free up some space. I will do another reencode and provide the META files when they are done.
DarWun is offline   Reply With Quote
Old 7th February 2009, 23:47   #1082  |  Link
treeboy
treeboy's Avatar
Thanks for the great apps DVD Rebuilder is great and has been for some time and I'm sure BD-RB will too. As a matter of fact I think it is now! I have done a BD-5 backup of 40 Year Old Virgin Movie only and all seems to go well meaning that the process completes successfully and plays on the puter just fine. I don't have a PS3 as yet but I do have a Philips BD7200/F7. Here in lies my problem. The 7200 doesn't play the TDK BD-5's I make and I don't have any other media at present. When the BD-5 is put into the 7200 the disc seems to load but nothing happens. The 7200 shows that it’s playing the disc but there is no time on the counter --:--. I have tried various settings with in ffdshow and BD-RB. If I check "Stricter AVCHD Compliance…" the player rejects it as not compatible, which the documentation confirms. Again I don't think it's the software but rather the player. Having said that, I tried v. 0.17.13 on a different movie, Eastern Promises and it works fine in the BD7200/F7 with the same media. The only obvious differences I see are that Eastern Promises has one track (MT2S) and the BDMV directory contains AUXDATA, BDJO, JAR, and META folders as do the backups of 40YOV with the exception of the "Stricter AVCHD Compliance…" attempt but 40YOVhas 21 tracks (MT2S). So, in summary I have successfully backed up a movie that plays on my Philips BD7200/f7 standalone with v. 0.17.13 but not with v. 0.18.07. Let me know if the logs would be useful and I will provide them. Thanks again, and we’ll keep at it.
CT
treeboy is offline   Reply With Quote
Old 7th February 2009, 23:59   #1083  |  Link
jdobbs
Originally Posted by drmih View Post
The audio has to be converted as I think that it accounts for several Gb and hence not viable for a bd-9. Below is the information for two titles from universal with the problem, and a random other which is fine - all done with the same settings (the info from the original discs is also shown).
The Mummy
1011 avc 1080p 23.976 16.9
**Original vc1 1080p 23.976 16.9
1100 dd multi-ch 48 khz eng
**Original DTS-HD XLL multi-ch 48 khz eng
1200 pg eng
1201 pg spa
1202 pg fra
Bourne Identity
1101 dd stereo 48khz eng
1200 pg eng
1201 pg spa
1202 pg fra
1203 pg spa
1204 pg fra
Tomb Raider
**original mpeg2 1080p 23.976 16.9
**original dd multi-ch 48 khz eng
1200 pg eng
1201 pg spa
1202 pg fra
So the last one works?
If you attempt to playback the .AC3 file alone (from the working directory) -- does it play the sound (sorry if I'm repeating anything -- I'm working a lot of separate issues simultaneously).
Website: www.jdobbs.net
Old 8th February 2009, 01:24   #1084  |  Link
drmih
Both The Mummy, and Bourne bd-9 work fine in a pc or when the main movie stream is selected on a ps3.
Powerdvd reports the video as MPEG-4 AVC and the audio as DD 5.1 448kbps
and just for clarification TombRaider is fine and was included to show that the same settings work fine on different (non-Universal) source material.
drmih is offline   Reply With Quote
Old 8th February 2009, 01:25   #1085  |  Link
jwjohnson
ExtractAudioSubs error with 0.18.7
I tried another movie only to BD-25 for Eagle Eye and again got the extract audio error. I have tried the same with movie only and after going through the extras ok get the same Extract Audio Subs error when it gets to the subtitles. I'm not trying to eliminate any subtitles. I've even enabled the languages for each subtitle to see if that makes a difference and it does not.
Here is a screen shot of the stream selection:
Log:
[11:34:35] BD Rebuilder v0.18.7 (beta)
- Source: EAGLE_EYE_AC
- Input BD size: 31.41 GB
- Approximate total content: [01:57:35.089]
- Target BD size: 22.46 GB
- MOVIE-ONLY mode enabled
[11:34:35] PHASE ONE, Encoding
- [11:44:25] ExtractAudioSubs() 00058 5
[16:38:49] - Failed to retrieve audio, aborted
INI
[Options]
MODE=1
QUICK_EXTRAS=0
PRIORITY_CLASS=1
RESIZE=0
TARGET_SIZE=23000
VERBOSE_STATUS=1
AUDIO_TO_KEEP=eng;fra;fre;por;spa;
SUBS_TO_KEEP=all
TRELLIS=1
COLOR_BOOST=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=0
AVCHD=-
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
[Paths]
SOURCE_PATH=X:\CLONEDVD TEMP\EAGLE_EYE_AC\
WORKING_PATH=X:\BD_REBUILDER\
INF
[Status]
LABEL=EAGLE_EYE_AC
VERSION=v0.18.7 (beta)
SOURCE_SIZE=33729798144
SOURCE_VIDEO_SIZE=33729798144
TARGET_SIZE=24117248000
REDUCTION=.715013113835965
SUBS_TO_KEEP=all
BACKUP_MODE=1
QUICK=0
And the resulting AUD_00000.meta file
MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500
A_AC3, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", down-to-ac3, track=4352, lang=eng, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4608, lang=eng, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4609, lang=eng, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4610, lang=fra, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4611, lang=spa, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4612, lang=por, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4613, lang=fra, mplsFile=00000
S_HDMV/PGS, "X:\CLONEDVD TEMP\EAGLE_EYE_AC\BDMV\STREAM\00000.M2TS", fps=23.976, track=4614, lang=spa, mplsFile=00000
Thanks for your help.
JeffJ
jwjohnson is offline   Reply With Quote
Old 8th February 2009, 01:36   #1086  |  Link
jdobbs
That appears to be a "file already exists" error. It's trying to rename the audio file to the proper output name, and it already is there...
Old 8th February 2009, 02:46   #1087  |  Link
jwjohnson
So how can I avoid that? I've made sure the "Workfiles" folder is deleted before starting the backup.
Old 8th February 2009, 04:34   #1088  |  Link
Catalystoz
The Descent strange problem
I did a movie only conversion on region A The Descent and ended up with a picture in picture with the directors comentary I gather this is a selection problem, I am using .18.0.7.
Thanks
Catalystoz
Catalystoz is offline   Reply With Quote
Old 8th February 2009, 06:03   #1089  |  Link
MikeyBK
MikeyBK's Avatar
Thanks
Catalystoz
That is probably one of those titles that you might need to use the Alternate Movie-Only Playlist setting for. I did so on one of mine to ensure the correct size playlist was loaded into 0.18.07.......
MBK
MikeyBK is offline   Reply With Quote
Old 8th February 2009, 09:22   #1090  |  Link
Jake802
Well, I just got Nick & Norah, Skips & Lock-ups on both the PS3 and the LG Player. Full BD Copy, LG BD-RE, I am going to try just a movie only rip with TSMuxer and see what happens there, just so I can get some clarification, its not the discs or something. Thanks guys!
Jake802 is offline   Reply With Quote
Old 8th February 2009, 13:32   #1091  |  Link
jdobbs
A full backup is skipping? Is the symptom the same as reported earlier? And it's doing the same thing on a standalone player?
Old 8th February 2009, 16:06   #1092  |  Link
TheOfficeMaven
Hi jdobbs,
With all the bad (skipping) news going around, I thought that you could use some good news for a change... I just finished doing a couple movie-only high-quality encodes to BD-5 using v0.18.7 and they play perfectly on my Samsung BD-P2550 (using the Stricter AVCHD compliance setting). The quality of the movies is absolutely amazing seeing that they have been shrunk down to fit on a single-layer DVD. I can hardly tell the difference between the re-encodes and the originals (Hancock and The Dark Knight). Kudos to you!
Also, I ended up picking up a new Core i7 (920) machine (that's running a 64-bit version of the Windows 7 beta) and I can now pull movie-only encodes off in about 5 hours (or less). My old Core 2 Duo machine took 31 hours to do a movie-only encode of The Dark Knight and my new machine did it in just over 5. What a difference!
Keep up the great work!
BTW, I've done about 7 movie-only encodes so far using the various beta versions of BD-RB and I've yet to run into a single problem. I thought for sure that Hancock would give BD-RB problems seeing as the main movie is split into 11 different M2TS chunks, but it worked just fine (i.e. no skips or audio sync problems at all). Guess I've just been lucky with my movie choices. I'll keep plugging away at it though.
TheOfficeMaven is offline   Reply With Quote
Old 8th February 2009, 16:21   #1093  |  Link
jdobbs
I think you're more lucky with your standalone choices... Thanks for the positive feedback. Of course X264 deserves most of the credit... great software.
Old 8th February 2009, 19:13   #1094  |  Link
Jake802
Yea unfortunately JDobbs, I am getting skipping issues with FullBackUp on a PS3 and LG-300. At first the movie like freezes/pauses and the sound plays. Then shortly after words, it sorta stutters along like its on a fast forward mode and I get no sound. I used TSMuxer and did just a movie only copy I am gonna burn that to disc, and that way I should no if, its maybe the disc or the players. I am thinking its the program or the disc(s) though, because I did TSMuxer of The Incredible Hulk and dont have the stuttering issues.
Old 8th February 2009, 19:13   #1095  |  Link
GaPony
I think the differences in various Blu-Ray players is going to be your biggest challenge. What appears to be a bug to one person, isn't an issue for someone with a different player. I would have never guessed there to be such a broad range of "standards" among different brands or even models within brands. Hopefully, time will cure that ill.
GaPony is offline   Reply With Quote
Old 8th February 2009, 19:43   #1096  |  Link
Sophocles
This is why many are opting to build their own BD play back units by building an HTPC. One of the nice things about an HTPC solution is that there are few if any compatibility issues to contend with. Not only can one check their reencode before burning it by playing back and ISO, but virtually all burns are compatible even if they won't play in a standalone player.
That of course is my two cents.
"Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep." Scott Adams
Sophocles is offline   Reply With Quote
Old 8th February 2009, 20:12   #1097  |  Link
brogan
jdobbs,
Just wanted to say great work on this app! Before this came out, I was pulling extras out of BD50s & trying to fit them on BD25s. I've done about 10 full movie rips to DVD+R DL & a couple movie only rips & they all look awesome w/out any problems. I do have one request, I know its not that big a priority for you. Are there any plans for a HD (untouched) audio option? Even if it's just for BD25s, having a TrueHD or DTS HD MA track would be amazing! Hopefully, that will turn up in a future version of this wonderful app. Thanks again...
brogan is offline   Reply With Quote
Old 8th February 2009, 21:15   #1098  |  Link
drmih
brogan,
I may be wrong but in setup you have the option within the audio not to reencode to ac3. It says dts to ac3 but I think it just leaves the audio untouched.
Old 8th February 2009, 21:31   #1099  |  Link
bobrap
Are you saying that playback quality on a HTPC is as good as stand alone or PS3? If so, could you give me an idea of the hardware specs. Thanks.
bobrap is offline   Reply With Quote
Old 8th February 2009, 22:42   #1100  |  Link
brogan
brogan,
I'm pretty sure it downsamples to DD or DTS...can someone confirm? As far as I know, you can't shrink a BD50 to BD25 & keep the TrueHD or DTS-HD MA stream...if I'm wrong, someone please correct me...
