8th November 2008, 18:46 | #6902 | Link | |
NO, the version is 2.73. Now, i tried it with 2.74 and it works. Damn, only one time I missed to install the newest version and..... Last edited by htpc@rischer.at; 8th November 2008 at 19:21. |
8th November 2008, 18:47 | #6903 | Link | |
8th November 2008, 23:10 | #6905 | Link | |
Of course there is a (slight) chance that eac3to produces a buggy file and that tsMuxeR/TsRemux fail because of that. But as far as I know this has never happened yet. So unless there's a clear indication that eac3to is at fault, I will consider any tsMuxeR/TsRemux error message as being the fault of tsMuxeR/TsRemux and not the fault of eac3to. |
9th November 2008, 00:51 | #6907 | Link |
I hope you don't misunderstand me. I'm very much willing to fix any bugs in eac3to. I'm just a bit tired of having to respond to tsMuxeR and TsRemux bug reports all the time. Why do I have to suffer from bugs in other developers' software?
9th November 2008, 04:06 | #6908 | Link | |
I swallow bugs!
PS. First Dibs Hey, Maddhi ...My sister is available next Friday night! hehehe! btw: Thanks for your great tool ea3to. Last edited by frogman; 9th November 2008 at 15:57. Reason: typo |
9th November 2008, 09:37 | #6909 | Link |
Hi!
I have manually register the nero 9 filter "neaudio2.ax" with the radlight filter manager, but it does not work C:\Tonspuren\eac3>eac3to -test Nero Audio Decoder (Nero 7 or older) doesn't seem to be installed http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. ArcSoft DTS Decoder doesn't seem to be installed http://www.arcsoft.com/products/totalmediatheatre Sonic Audio Decoder (2.74.0.0) doesn't seem to be installed Haali Matroska Muxer (2008-03-29) is installed Nero AAC Encoder could not be located http://www.nero.com/eng/nero-aac-codec.html Copy NeroAacEnc.exe to the eac3to or to the Windows folder. Surcode DTS Encoder (1.0.29.0) is installed MkvToolnix doesn't seem to be installed http://www.bunkus.org/videotools/mkvtoolnix C:\Tonspuren\eac3>eac3to c:\tonspuren\test.ac3 c:\tonspuren\test_neu1.dts -nero AC3, 5.1 channels, 1:52:21, 448kbps, 48khz, dialnorm: -27dB I'd like to use the Nero decoder, but it doesn't seem to work. Special Thank to Rica for try to help over PN !!! Thank you !!! |
9th November 2008, 15:54 | #6911 | Link |
Actually Nero9 should work (the protection Nero8 had was removed), and madshi did ask for some sort of output from graphedit to help him get it to work, but the last person who had Nero9 didn't reply back with the info.
So if madshi can re-state what it is he needs, maybe malibu will be able to provide what is needed, and we'll all have Nero9 support.
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 |
9th November 2008, 16:47 | #6912 | Link |
Lexor i agree.
Nero7 is just a default decoder and if you can use Nero9's filters in direct show, eac3to should use it when we force nero9 decoder to be used by -nero option. I've already asked to malibu if he has bd-blu ray plugin but haven't gotten the answer. As far as i guess malibu doesn't have this plug-in and in this case he can see and register nero audio decoder2 filter but he can not use in graphstudio which means eac3to can not use it as well. |
9th November 2008, 16:52 | #6913 | Link |
Nero 9 filters can be used outside nero showtime. This has nothing to do with eac3to though. eac3to is programmed to use nero 7 filters.
Do you think that if nero 9 could be used *right now* with eac3to, the 1st post would say otherwise? And instead of speculating, why don't you try it first? |
9th November 2008, 17:00 | #6914 | Link |
nautilus, i suppose you are confusing programmed filter (to be used as default) with any other filter forced to be used.
Malibu says he hasn't nero7; in this case eac3to would want to use programmed secondary free filter coming with eac3to. But if you force eac3to that you will use that filter , why do you think eac3to won't use it? Edit: why i don't try? Because i have to buy nero9 and the plug-in. Last edited by rica; 9th November 2008 at 17:03. |
9th November 2008, 17:11 | #6915 | Link |
Can eac3to accept multiple mono wavs input? eg. L.wav, R.wav, C.wav, LFE.wav, SL.wav and SR.wav
I tried using "wavs", "*.wav" and "+" as input parameter, but all fails. Or is there any method to join them to a multichannel wav again? |
9th November 2008, 17:45 | #6917 | Link | |
Sox -M FL.wav FR.wav FC.wav LF.wav SL.wav SR.wav multichannel.wav
9th November 2008, 17:52 | #6918 | Link |
Pig on the wing
@madshi: Will the next build include feeding 32bit floating point data into the Nero AAC encoder?
9th November 2008, 17:57 | #6919 | Link |
@rica, nautilus7 knows eac3to very well. Normally you can trust in what he says. So instead of trying to argue with him, you should just believe him. He told you 3 times that eac3to doesn't support Nero 9 and he is absolutely right with that.
Yes. |
9th November 2008, 20:32 | #6920 | Link |
eac3to v2.75 released
http://madshi.net/eac3to.zip Code:
* added (E-)AC3 5.1 "EX" detection * added (E-)AC3 2.0 "Surround" detection * added (E-)AC3 2.0 "Headphone" detection * NeroAacEnc is now fed with up to 32bit float (if available) * resampling option "-quality=low|high|ultra" not supported, anymore * new option "-fast" switches SSRC resampler to fast, but low quality mode * new option "-r8brain" forces use of r8brain resampler instead of SSRC * added support for AES3 PCM streams in TS container * started working on encoder plugin interface |
eac3to |
