Old 28th September 2016, 18:51   #1  |  Link
kabelbrand
Compression mode: Lousy
kabelbrand's Avatar
x265 UHD-BD Seamless Connection
I'm running some tests for BD compatibility using the --uhd-bd option. When setting up a playlist with several clips using seamless connection I get the following verifier error:
Error ID : SEAM1211
Target File : 00000.m2ts, 00000.m2ts
Target Field : <HEVC video streams for PlayItems with connection_condition= 5>
Section No : 7.6.2.5 -2)
Error Message : HEVC streams in TS1 do not terminate with end of sequence.
Explanation : Video data in TS1 shall terminate with end of sequence (end_of_sequence_rbsp()).
http://www.blu-raydisc.com/assets/Do...24.pdf#page=49 Section 3.12 also states:
2) Video data in TS1 shall terminate with end of sequence (end_of_sequence_rbsp()).
I used x265 2.0+2 with the following possibly related options:
--uhd-bd --no-open-gop --repeat-headers --hrd --aud
Am I missing a specific option or is it not (yet) possible to add an end of sequence NAL? Thank you.
kabelbrand is offline   Reply With Quote
blu-ray, seamless, x265
