Old 8th July 2012, 03:51   #1  |  Link
lansing
need help on removing green bar on top of a vhs video
There's a stationary green bar sitting on top of each frame of the video, I tried to remove it using the overlay function with different color adjusting filters, the best I can get is through coloryuv, but it's still visible, is there a better filter to do this?
sample is here:
http://www.mediafire.com/?hed3y7eg7pkeed2
o=AVISource("top green bar.avi")
AVISource("top green bar.avi").crop(0,4,-6,-468)
ovrlay = ColorYUV(gain_u=0, gain_v=53)
Overlay(o, ovrlay, x=0, y=4, opacity=1.0, mode="blend")
Old 8th July 2012, 04:49   #2  |  Link
You can always crop it! Then resize if necessary. With that terrible video, it wouldn't look much worse. You have head-switching noise that needs to be cropped off the bottom anyway, so why not just do both?
Or maybe you can try something like BorderControl():
http://www.geocities.com/siwalters_uk/bdrcntrl.html
Old 8th July 2012, 12:58   #3  |  Link
lansing
i don't want to crop it out because it still has details in it unlike the bottom
Old 8th July 2012, 14:36   #4  |  Link
juhok
juhok's Avatar
Here's a suggestion for a similar issue by jmac698 at digitalfaq.com forums, adjust as needed:
#Fix Sony 9000 Digital8 video
#A Script which fixes a problem where the top 6 lines of video have a green color
#Version 0.1 by jmac698  Dec/10
dir="G:\project001a\vcr comparison\"
imagesource(dir+"sony9000.jpg")#change this to:
#avisource(dir+"yourvideo.avi")
pal=1#set to 0 for NTSC (obviously would apply to an equivalent NTSC hi8 deck)
goodline=13#increase this until the color is fixed, refers to the cropped coordinates
newwidth=720#The final width of the new video
newheight=(pal==1)?576:480#The final height of the new video
#This script is not completely general, generally only even numbers are supported
left=4#adjust these to closely crop your video
right=9
top=0
bot=7
Crop(left, top, -right , -bot)#Crop your video
addborders((newwidth-last.width)/2,(newheight-last.height)/2,(newwidth-last.width)/2,(newheight-last.height)/2)#Re-Centre your video
converttoyuy2
badcolor=last.vtoy#This is where the green line comes from
fillcolor=badcolor.crop(0,goodline,0,-(newheight-goodline-2)).pointresize(newwidth/2,goodline)
fixcolor=stackvertical(fillcolor,badcolor.crop(0,goodline,0,0))
ytouv(last.utoy,fixcolor,last)
juhok is offline   Reply With Quote
Old 8th July 2012, 19:59   #5  |  Link
Mounir
Didée gave you the solution last time
# Move the chroma Up:
crop(0,0,0,-6).pointresize(width,height,0,0,width,height).mergeluma(last)
pointresize(width,height,0,6,width,height).mergeluma(last)
But it's not perfect with that crappy video once it is deinterlaced with nnedi3 i think i know why only U or V is concerned with the chroma misplacement, let's wait for Didée
Mounir is offline   Reply With Quote
Old 8th July 2012, 21:49   #6  |  Link
lansing
that one doesn't work, it shifted the entire luma upward, making lots of ringing in all other areas.
Old 9th July 2012, 10:22   #7  |  Link
lansing
thanks for this script, there still exhibit some light green and yellow after, so added camcorder color denoise on the top part and it works out pretty well.
LoadVirtualdubPlugin("VirtualDub-1.10.2\plugins\ccd_sse2.vdf", "CCD", 1)
assumetff()
nnedi3(field=-2)
pal=0 #set to 0 for NTSC (obviously would apply to an equivalent NTSC hi8 deck)
goodline=16#increase this until the color is fixed, refers to the cropped coordinates
converttoyuy2
# add ccd on top part
ConvertToRGB32
temp = last
top = temp.CCD(100,1).crop(0,0,0,-(newheight-goodline))
bottom = temp.crop(0,goodline,0,0)
StackVertical(top, bottom)
ConvertToYV12(chromaresample="point") # convert back to yv12
Old 10th July 2012, 03:57   #8  |  Link
jmac698
Hmm, my scripts do get around.. glad it worked
jmac698 is offline   Reply With Quote
Old 17th September 2017, 14:08   #9  |  Link
cooli
Hello,
how can I adapt this to a right vertical green line?
cooli is offline   Reply With Quote
Old 17th September 2017, 19:54   #10  |  Link
LemMotlow
I already did that with chuibbyrain2 in the script in a previous thread. https://forum.doom9.org/showpost.php...58&postcount=2. Here's the part that cleaned it up:
# ------------ chubbyrain2 - interlaced, clean up border stain ----
separatefields()
a=last
a
chubbyrain2()
SmoothTweak(Hue2=7)
crop(690,0,0,0,true)
b=last
overlay(a,b,x=690)
weave()
Adding CamcorderColorDenoisie later in the script finished the job:
LoadVirtualDubplugin("drive:\path\VirtualDub\plugins\ccd.vdf","CamcorderColorDenoise",1)
ConvertToRGB32(interlaced=false,matrix="Rec601")
CamCorderColorDenoise(32,1)
Sorry to didn't take notice.
LemMotlow is offline   Reply With Quote
Old 17th September 2017, 22:33   #11  |  Link
cooli
Hello,
Is there any x64 alternative to CCD?
I'm trying to adapt this part to vertical to see the results but
without any success for no.
converttoyuy2
Tried to install everything in 32bit but how can I force AVS+ to install 32bit instead of X64?
BTW thanks for helping, I really like the output of your script.
separatefields()
a=last
a
chubbyrain2()
SmoothTweak(Hue2=7)
b=last
overlay(a,b,x=690)
weave()
Old 17th September 2017, 22:40   #12  |  Link
LemMotlow
Guess you'll have to wait for 300-plus Avisynth and VirtualDub filters to get re-engineered into 64-bit versions. Sorry to say, it's not likely to happen. I guess that's why so many people still use 32-bit, even with 64-bit OS's.
green bar, remove, top, vhs
