Old 23rd February 2020, 02:03   #58761  |  Link
SamuriHL
SamuriHL's Avatar
Actually, that depends on the player. If a player entirely ignores any Windows DPI handling, then the desktop scaling would in fact affect the video.
An application (ie. the player) would have to tell windows to not scale it, since it does its own scaling. Windows otherwise cannot scale selectively. It either scales the entire player, or nothing of it.
Well, ok....you obviously know which player I use. Is this something I have to worry about with madvr in JRiver?
Old 23rd February 2020, 02:16   #58762  |  Link
nevcairiel
Not usually. Things only get tricky if you mix screens with different scaling values. And the madVR OSD would tell you the resolution that madVR thinks its rendering to, if thats not the real screen res, then you know something is wrong.
Old 23rd February 2020, 02:16   #58763  |  Link
the madVR OSD is clear about this so you are fine browser have problem with this.
Old 23rd February 2020, 02:24   #58764  |  Link
SamuriHL
SamuriHL's Avatar
Thanks, guys. Much appreciated!
Old 23rd February 2020, 04:16   #58765  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by Siso View Post
Guys, which scenario is right - NGU Sharp low+SSIM 1D 100 AR LL, or NGU Sharp medium+Bicubic 150 AR LL?
Obviously, you put everything you can into Luma, then consider chroma.
If it's downscaling, then it really doesn't matter what the chroma is because you're gonna have enough power to ngu both.
In the case of NGU then downscale, Unless it's from a very very small resolution to slightly higher than native res, then downscale, it doesn't really matter, because NGU makes posterized edges on these. And from a distance they look the same as cheaper algorithms
Ghetto | 2500k 5Ghz
Old 23rd February 2020, 06:12   #58766  |  Link
Klaus1189
Originally Posted by WuNgUn View Post
Can someone help with my scaling...
Whenever I'm in 23Hz film mode, my TV overscans. The TV doesn't give me an option to resize and scaling from the nVidia CP just reduces the resolution to make the image fit...
What to do!?
Manufacturer of TV? What Firmware version?
Old 23rd February 2020, 09:53   #58767  |  Link
Siso
Soul Seeker
Siso's Avatar
I'm using image doubling for 1080p, then downscaling to 3440x1440p.
Old 23rd February 2020, 13:40   #58768  |  Link
WuNgUn
It's a Samsung UN75RU8000FXZC, software version 1351.3
Pictire size settings in settings is just greyed out
WuNgUn is offline   Reply With Quote
Old 23rd February 2020, 15:44   #58769  |  Link
Klaus1189
There's a known bug introduced in firmware version 1290, last working was 1270.
Please try and play a 25fps file or 50 fps file and play it at 50 Hz. Picture should be also cut off.
The only refresh rate which is fine should be 60 Hz.
And what HDMI mode do you use? I assume PC mode for 4:4:4 color / RGB support.
Old 23rd February 2020, 16:31   #58770  |  Link
WuNgUn
Thanks for the reply... Typical swift Samsung updates to fix issues!
Seeing the issue on all refresh rates other than 60hz, correct.
Yes, PC mode on the HDMI input...
There is resizing in the nVidia control panel, but as I mentioned earlier, it isn't shrinking the overscanning, it's reducing the resolution... Which I don't think is something I wanna do. Native resolution only.
Old 23rd February 2020, 17:56   #58771  |  Link
Klaus1189
Yes you are right that you cannot fix this issue in driver settings on the gfx card, because the TV is simply cutting off the picture called overscan. I personally never really understood why TVs which only have digital inputs anymore have the overscan feature built in.
All HDMI signals I am aware of are free on anything that needs to be cut off other than old Video from VHS for example
Old 23rd February 2020, 18:18   #58772  |  Link
tp4tissue
tp4tissue's Avatar
Cable boxes which receive broadcast with bad edges. None of us watch cable. but many still do.
Ghetto | 2500k 5Ghz
Old 23rd February 2020, 18:24   #58773  |  Link
WuNgUn
I guess that makes sense... The TV should recognize the signal though, and treat it as such....
Old 24th February 2020, 02:05   #58774  |  Link
overscan is gone with UHD samsung should really fix this.
try in the nvidia driver display -> adjust desktop colour settings -> content type reported to display.
if they follow specs and you have something like graphic, desktop programs, games or similar you maybe able to beat it but you are most likely wasting your time.
Old 24th February 2020, 08:38   #58775  |  Link
tp4tissue
tp4tissue's Avatar
samsung can definitely disable overscan, Try PC mode.
Ghetto | 2500k 5Ghz
Old 24th February 2020, 09:56   #58776  |  Link
DMU
In PC mode with a frequency of 23, 24, 25, 50 Hz will be overscan. With frequencies 29, 30, 59, 60 the image will be fit to screen.
R3 3200G / Vega8 / Samsung UE40NU7100
Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver
MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit
DMU is offline   Reply With Quote
Old 24th February 2020, 12:00   #58777  |  Link
Klaus1189
It can but there is bug that other than 60 Hz in pc mode overscan is always cutting off the image. 1270 is last working fine.
Old 24th February 2020, 12:45   #58778  |  Link
WuNgUn
Is this older firmware available online? Can the TV be downgraded?
Old 24th February 2020, 16:30   #58779  |  Link
Klaus1189
No, I asked Samsung but it can‘t be downgraded.
Old 24th February 2020, 17:10   #58780  |  Link
tp4tissue
tp4tissue's Avatar
obviously it can, but they won't tell us how.
But don't sweat it, the 60hz works mode works fine. perfect cadence is over-rated.
For future reference, Roku platform tvs are the BEST behaved for monitor use. everything just works, and they don't have any crazy image processing stuff that destabilizes the display response..
My samsung doesn't even support 444 in 23/24hz mode. but on my $200 roku tv no problem,
Ghetto | 2500k 5Ghz
