5th October 2019, 09:33 | #17381 | Link |
.lwi file is always created in order to avoid huge delay when you decide to switch from ffms2 to lsmash (indexing may take few minutes)
5th October 2019, 16:19 | #17382 | Link | |
ByteShare
The more you know Thank you for answering. --To be clear the muxing issue isn't all of the time. If I can get it to work once then the following jobs keep working. Right now I've been restarting a job until it doesn't fail and then the jobs after work...then I don't touch anything because even adding more jobs seems to have a possibility of breaking it again. Last edited by byteshare; 5th October 2019 at 16:52. |
6th October 2019, 08:43 | #17383 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
6th October 2019, 13:17 | #17384 | Link |
Can report same behavor. CombineAllChunks.cmd has to be started manually. D:\Temp\RipBot264temp\job8\video.264 is not created before job8_MuxFiles.cmd is executed.
Very annoying. Some jobs succeeded and after any point all jobs finish with ERROR and no output files is created. |
6th October 2019, 13:30 | #17385 | Link |
Your program is what I have been looking for in the past…
thank you very much! In the past I used DGDecNV for video decoding, which is the preferred (most reliable if I can say something like this) one in Ripbot? I think sometimes I would like to use some denoiser on my sources (very rarely when bitrates are getting higher very much). Do you have some guidelines when to use which? I am reencoding only high bitrate HD sources but sometimes grain, noise doesn't let me reduce the bitrate in the amount I would like to. Distributed encoding is just amazing on my 32 cores! I have never seen anything like this in other programs. Thank you very much for your amazing program. |
6th October 2019, 17:38 | #17386 | Link | ||
7th October 2019, 16:42 | #17387 | Link |
ByteShare
If anyone missed it. New update to x265 (3.2+5), MKVtoolnix (38.0.0), and Core (2019.10.06)
Thank you for the update. How do we use the "Run Script after finished job"? Last edited by byteshare; 7th October 2019 at 16:57. |
7th October 2019, 17:24 | #17388 | Link | |
7th October 2019, 17:30 | #17389 | Link |
ByteShare
I don't see an option/where to define what script it will run, unless it is an internal script?
I can check it but I don't see what it does, so I don't know how to use it. --Oh, thank you for adding GPU as a option in the settings for decoders and not just a right click option. Other than needing Intel or NVidia to use, any downsides to it over FFMS2 or LSMASH? |
7th October 2019, 17:53 | #17390 | Link | |
7th October 2019, 20:41 | #17392 | Link |
I'm also encountering the video.265 could not be opened for reading: open file error issue. Started after a recent update, everything worked perfectly fine for months before, through multiple previous updates. And I too discovered that running the CombineAllChunks then then jobx_MuxFiles scripts manually will complete the process. Please fix.
Also, separate question: Are there any plans for a Linux encodingserver? I have a couple of Linux machines that I'd like to throw into the farm. Thanks for the software, it's fantastic! Dhry |
7th October 2019, 22:42 | #17393 | Link |
Install windows (win10 works without activation forever) on virtual machine and you are good to go.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 7th October 2019 at 22:45. |
8th October 2019, 06:57 | #17395 | Link | |
ByteShare
8th October 2019, 07:23 | #17396 | Link |
Possibly yes. Your x264 build does not support hardware acceleration (if there is a speed-up at all), but that doesn't keep it from finishing its job correctly with usual CPU routines only.
There may be x264 builds out there which can use some OpenCL functions of a modern GPU. So you might replace xour x264 executable; but I won't guarantee that they work correctly with RipBot264, they might interfere with other filters using the GPU too, even. Test and get experienced. |
