Old 5th April 2013, 03:27   #18181  |  Link
dansrfe
Originally Posted by Niyawa View Post
I may have missed something, but is madshi working on something else like commercials again? He's been online and all but no replies.
I think he's busy with commercial work atm. I'm sure he'll re-start development and respond to posts when he has more time.
Old 5th April 2013, 03:49   #18182  |  Link
Gelatinous
Thats usually how it works. madshi will drop lots of new builds in the space of a few months, then will be silent for the next few months. It all depends when he's got free time.
Gelatinous is offline   Reply With Quote
Old 5th April 2013, 05:53   #18183  |  Link
Niyawa
Niyawa's Avatar
I see, he probably just stops by to keep himself updated with the issues and stuff.
Noticed that, second time that I've seen at least.
Well, I'm holding up my guide update because I want to update madVR together, so I was curious when I could expect him to appear or something along those lines.
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack
Niyawa is offline   Reply With Quote
Old 5th April 2013, 12:32   #18184  |  Link
Devrim
I was looking at your madVR scaling algorithms chart and I had a question about the smooth motion.
There are 3 options under smooth motion, what is the best one to pick?
-edit-
Nevermind, read the rest of you guide, I changed a few more options too
Devrim is offline   Reply With Quote
Old 5th April 2013, 12:45   #18185  |  Link
DragonQ
madshi, do you know why colours aren't in the same place in EVR and MadVR? Is it to do with the fact that chroma subsampling isn't strictly defined in terms of position?
In the example below you can see the coloured text is shifted by a pixel to the left in MadVR compared to EVR. I have no idea which is correct, if there is a "correct".
MadVR
EVR
Old 5th April 2013, 13:14   #18186  |  Link
nevcairiel
There is two commonly used chroma subsampling positions for 4:2:0, the MPEG1 and MPEG2 way, the latter being used by most modern formats.
MPEG1:
MPEG2:
As you can see from these images, using the wrong position for upsampling can shift the chroma by half a pixel, which results in chroma bleeding over edges.
If in doubt, its usually safe to assume that madVR does it correctly, doubtful that EVR would even be able to distinguish between the two.
Old 5th April 2013, 18:01   #18187  |  Link
dukey
You could at least compare the same video frames.
dukey is offline   Reply With Quote
Old 5th April 2013, 18:24   #18188  |  Link
DragonQ
The text doesn't move.
I chose that section initially because it was text (easy to see aliasing) and I had leeway when pressing Print Screen (MediaPortal doesn't do frame stepping).
Old 5th April 2013, 18:30   #18189  |  Link
kasper93
MPC-HC Developer
Doesn't matter. You need to compare always exactly the same frame.
kasper93 is offline   Reply With Quote
Old 5th April 2013, 18:58   #18190  |  Link
DragonQ
You're not the boss of me.
But fine, for the purposes of this comparison I've updated the MadVR image (CTRL+F5 to see it). Oh look, the same thing is visible.
Old 5th April 2013, 19:36   #18191  |  Link
dansrfe
Guys, chill out. Everyone is just trying to help each other.
Old 5th April 2013, 20:50   #18192  |  Link
Niyawa
Niyawa's Avatar
Well, the chart is still somewhat in a feedback stage. I've been reading some recommendations from other users and I came with this configuration:
The only thing that really changed was the removal of Linear Light from downscaling in High, since it's really demanding indeed. I'm also using "blending" to make it more easy to understand but I still need to make a version with all the details included in the image. Just don't have the right tools to do it right now in the way I would like to.
Old 5th April 2013, 22:46   #18193  |  Link
fairchild
I'm more of a fan of chroma with no AR. I keep going back to the Mid option (chroma: Bicubic75, upscaling: Lanczos3 AR) even though my system is fast enough to run the best settings (Jinc 3 AR). Also don't run FRC since I want as pure of a signal as possible. (hence no AR on chroma, which is perfect for Blu-ray, and AR on upscaling for non 1080p content).
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 5th April 2013, 23:35   #18194  |  Link
Asmodian
Niyawa don't listen to fairchild, I really like your table.
But I am sure it isn't optimal for everyone, there is a reason we have all the options we do.
Old 6th April 2013, 00:02   #18195  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Personally I use Jinc3taps AR for everything so I can't say about other options, but just wanted to comment on Smooth motion option.
I watch anime mostly (like 99% of everything that I watch offline and 95% of what I watch in general), where the difference between frames is often huge even if its not a scene change. And I find smooth motion to look very ugly. I can easily see where it occurs. However without it I can't tell the difference, can't tell that something wrong even if some frames get dropped due to video/display framerate mismatch or whatever.
Maybe I set up something wrong or something, but as I said for me everything looks fine even without this option, so I don't want to invest a time to check this. I just want you to check whatever this option really that useful before recommending it to someone, especially if its many people. Just because this option is there and some people in this thread use it, it doesn't means that it should be used by everyone.
Old 6th April 2013, 00:23   #18196  |  Link
nevcairiel
I agree, smooth motion isn't something that should be directly tied to a quality level table, its quite separate from that (and doesn't eat all that much performance to matter), and more importantly, some people don't even see the 3:2 judder (like most people who have seen this most of their life on NTSC TVs), but maybe would see the extra blur and artifacts it adds.
Old 6th April 2013, 00:42   #18197  |  Link
truexfan81
truexfan81's Avatar
just curious, is there ever a good time to use soft cubic? i notice its not on your chart anywhere
truexfan81 is offline   Reply With Quote
Old 6th April 2013, 01:03   #18198  |  Link
Asmodian
I also agree, smooth motion is not for everyone. I must admit I have never tried smooth motion as I use a 120 Hz display or a 24/60 Hz TV with Reclock so I cannot comment on it.
I was only thinking about resize settings when I endorsed said table.
Anytime you like it more.
Some have reported they like it, I would assume instead of non-AR Bicubic 75 or Lanczos 3.
Old 6th April 2013, 01:46   #18199  |  Link
truexfan81
truexfan81's Avatar
i actually like softcubic better for chroma
Old 6th April 2013, 01:48   #18200  |  Link
dbcooper
Niyawa, are the settings in your chart optimised specifically for Anime or for general viewing?
dbcooper is offline   Reply With Quote
