18th April 2007, 16:19 | #121 | Link |
This one is not working, definitely:
imagesource("D:\Nova pasta\FightersFinal_FFN0000.tga",0,0300) ConvertToYv12() ConvertFPS(24) Neither this one - says there's an error; it says: Convert FPS requires YUY2 input. LoadPlugin("C:\avs_plugins\ImageSequence.dll") CoronaSequence("D:\Nova pasta\FFN.tga",sort=1) ConvertToYv12() ConvertFPS(24) Any ideas? |
19th April 2007, 03:13 | #123 | Link |
Thank you very much David. Now the scrit looks like this:
LoadPlugin("C:\avs_plugins\ImageSequence.dll") CoronaSequence("C:\FightersFinal\FFN0000.tga",sort=1) ConvertToyuy2() ConvertFps(24) There's a warning: Corona Sequence: first picture found cannot be decoded. So what? Is there anything wrong with my Targa 32 files? One more thing: I see a lot of people adding ConvertToyuy2(). In may case (not the case above that is a targa sequence) , when I'm converting from MPEG2 to Xvid, it seems the conversion is made through the Chroma. So, I guess, according to what I've read around here, it is not necessary adding ConvertToyuy2(). Is that OK? Thanks in advance. Last edited by Cunhambebe; 19th April 2007 at 03:20. |
1st May 2007, 22:06 | #124 | Link |
Where is SumStretchFPSMask coming from
Hello all,
I am experimenting with the using MVFps from MVTools within the salFPS scripts in this thread. I cannot get past the call to SumStretchFPSMask. Where does this function come from? I cannot find reference to it in documentation for either MaskTools or Motion. Thanks, cwk |
1st May 2007, 22:36 | #125 | Link |
interlace this!
it comes from motion.dll, but i'm not sure if it's documented. it was designed specially for the script function "motionprotectedfps", which salfps scripts are derived (hacked) from
it makes a mask based on possible discontinuities in the vector field, but i'm not entirely sure how it works.
sucking the life out of your videos since 2004 |
2nd May 2007, 17:02 | #126 | Link |
King of the Jungle
Can anyone suggest the best way to call salFPS3
My current script is; import("C:\Program Files\AviSynth 2.5\plugins\mvbob\mvbob.avs") import("C:\Program Files\AviSynth 2.5\plugins\salFPS3.avs") QTInput("I:\Crossfire\track 1.mov") converttoyv12() mvbob() salfps3(50) lanczos4resize(width,576) assumetff().separatefields().selectevery(4,0,3).weave() I have some particularly difficult 29.97i footage I'm working with, that involves lots of very fast motion and quick flashes. Any suggestions as to a better script would be greatly appreciated. |
15th July 2008, 23:39 | #128 | Link |
Huh?
I am getting a "I don't know what WARP means", pointing to line 6 of salFPS3. Also, I am not sure I'm getting its dependencies right, can someone tell me which are they?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
18th July 2008, 01:20 | #129 | Link |
interlace this!
that "warp" part will be in motion.dll. you could hunt it down and remove it from the script - it'll switch to the default mode "warpfast" which will be slightly chunkier but still good when moving.
