27th March 2005, 14:27 | #181 | Link | |
Life's clearer in 4K UHD
"encodes with B-VOP but without packed bit-stream, are not currently supported" And I've corrected my previous statement accordingly! Cheers
27th March 2005, 20:53 | #183 | Link | ||
Be Brave!
27th March 2005, 21:24 | #184 | Link | |
AMD Athlon 64 3000+ 2.0 GHz Nvidia GeForce FX5200, 256 MB Gigabyte nForce3 250, 512 MB RAM Maxtor 80 GB 7200rpm XP PRO 5.1 (Build 2600) SP2 TDK DVDRW882N|TEAC CD-W540E|ASUS E616 |
29th March 2005, 01:51 | #185 | Link | |
29th March 2005, 02:08 | #186 | Link |
Easy Fix
An easy fix - BUY MORE RAM.
Seriously, your PC needs every bit it can get - you should have at least 512MB now-adays - and it's dirt cheap. But it should still run fine - it's a small app, so it shouldn't use too much of your RAM. And you can install .NET without using RAM, it only uses memory when you are actually running .NET applications. |
10th April 2005, 06:53 | #187 | Link |
Hi, is there anyway to re-write the DivX User Data ID? This changed in a recent XviD revision and I have some videos which have the new ID which seems to cause problems with my hardware player. Also, is it possible to fix user data like this?
10th April 2005, 11:20 | #188 | Link | |
you might want to post this on the xvid maillist, as breaking existing hardware players is surely not the goal the update wanted to achieve
10th April 2005, 16:45 | #189 | Link | |
I don't think it is incorrect to have the user data precede the VOP, and DivX does this also. EDIT: I just checked ISO/IEC 14496-2, it looks fine to me.
moitah.net Last edited by Moitah; 10th April 2005 at 16:52. |
14th April 2005, 17:27 | #190 | Link |
Thanks for the screenshots. A while back I tried running MPEG4 Modifier in Linux with Mono 1.1.4, and only MPEG4 Modifier 1.2.0 or earlier would start, because of the drag-and-drop code I added to the source AVI textbox in 1.3.0. It's good to see the progress they are making, and I think it will soon run fine since I didn't use any P/Invokes. I know most of the code already runs fine with Mono, because UnpackCL uses the exact same 3 main .cs files. It's just the Windows Forms stuff that doesn't quite work yet, but it looks like they are getting close .
moitah.net |
15th May 2005, 03:32 | #191 | Link |
This is not a valid MPEG-4 video (startcode not found at beginning of frame)" error
Ooops... I accidently posted this outside of the MPEG4 modifier topic! Sorry for the extra post...
--- When I try to open a divX file (with MPEG4 Modifier) to unpack the bitstream, I receive the following error: "This is not a valid MPEG-4 video (startcode not found at beginning of frame)" (See attached screenshot...) Any idea why this would be occuring? It seems to happen with all divX files (haven't tried any other type of file). Oddly enough, when I use the command line program (UnpackCL), it works perfectly. Just kind of a pain to have to keep switching to command prompt to fix files, so I would love to get MPEG4 Modifier working! Has anyone seen this error before? I searched the forum but couldn't find and messages pertaining to this. Any advice on how to solve the problem? Thanks! Greg |
15th May 2005, 09:11 | #192 | Link |
I can't see the screenshot yet but.... are you sure it's a DivX5 file?
Cheers
15th May 2005, 13:44 | #193 | Link |
note that divx3 is not mpeg-4 compliant (but also doesnt use packed bitstream)
16th May 2005, 15:26 | #195 | Link |
How do I tell what divX version a file is?
The divX files I downloaded are all recent television shows (recorded within the last couple of months), however I am unsure what format they are.
They play with the divX 5 codec that I downloaded from www.divx.com, however some files have a problem with audio sync (especially when played with my Prismiq Mediaplayer). The UnpackCL program solves this issue - just wish I could do it with a GUI (using MPEG4 Modifier). Perhaps the files I downloaded are some weird DivX variant? How do I tell? I believe they are from an HDTV source, if that matters... Thanks! Greg |
16th May 2005, 15:33 | #196 | Link |
divx5 can decode divx3-4
try a tool, like gspot or open it in virtualdub(mod) to see if its divx3 or not
16th May 2005, 15:43 | #197 | Link | |
Cheers
16th May 2005, 21:51 | #198 | Link |
Questionable content...
Not sure what you mean about illegally obtained content. I just re-read the posting rules.
I normally watch the television show in question "on air" and occasionally miss it so I keep a tape in the VCR. If I forget to put the tape in the VCR, I download the episode from the net. Canadian law has upheld the legallity of downloaded content (yes, I live in Canada), but then again, I am not a legal expert. The CRTC might have something to say about Can-Con, but being that the show is on Canadian networks, I don't see a problem. I am sorry if my question is not legal wherever you are located. Please disregard it if this is the case. Greg |
16th May 2005, 22:12 | #199 | Link |
I guess in your instance the legality of the content could be established by knowing more about where you downloaded the media.
For instance, is the web site authorized by the copyright holder? Cheers
17th May 2005, 01:01 | #200 | Link |
codec of file that won't open with MPEG4 Modifier
According to GSpot and VirtualDubMod, the files are XviD. See attached screenshot from VDM. I didn't see a convenient way to log or screenshot the info from GSpot.
So, MPEG4 Modifier should open it, no? Thanks, Greg |
