6th May 2018, 09:05 | #6041 | Link |
"System exception - Illegal Instruction" ... sounds like either this is a build using a CPU instruction set (SSE etc.) not available in your CPU, or a corrupt DLL for yadifmod2? Or 32/64 bit mixed?
6th May 2018, 09:19 | #6042 | Link |
It's some mistake of the cover. Change of parameters in the bookmark "Filters" - "Deinterlacing" isn't forcing changes in the bookmark "Script".
Edit I exchanged the library from the last update on older - yadifmod2 2016-07-05 0.0.4 -1 and then again deinterlacing is acting. Last edited by Melan; 6th May 2018 at 10:14. |
6th May 2018, 22:32 | #6043 | Link |
2849 scripts with high bit depth are converted to 8 bit when processed internally (e.g. for VideoPlayer). part II 2848 scripts with high bit depth are converted to 8 bit when processed internally (e.g. for VideoPlayer) 2847 [AviSynth Wrapper] added high bit depth support 2846 [Audio Encoder] only use TimeStretchPlugin() if AVS+ is not used |
7th May 2018, 14:32 | #6044 | Link | |
7th May 2018, 21:29 | #6048 | Link |
Yes. But it may be buggy and like with other formats eac3to dropped behind the development of the decoders/encoders in ffmpeg.
So try eac3to cli (with and without -core switch). Then make report to madshi. (But don't hold your breath for a fix.) http://bugs.madshi.net/ |
7th May 2018, 21:57 | #6049 | Link | |
http://bugs.madshi.net/view.php?id=450 See also https://forum.doom9.org/showpost.php...ostcount=14384
8th May 2018, 00:23 | #6050 | Link | |
Zathor, The "Enable Custom Options" option doesn't stay checked after closing the HD Streams Extractor as the rest of the items under the Settings menu do. Was that by design?? Cheers. Last edited by hello_hello; 8th May 2018 at 00:26. |
8th May 2018, 11:54 | #6052 | Link |
If you generalize your bias that much, I won't be surprised about opposition. Especially people encoding anime/cartoons with x264 enjoyed the advantage of higher internal precision to avoid banding in slight color ramps.
Using x264 with 32-bit code is not a great issue; using x265 with 32-bit code is a much greater one (missing several levels of assembly optimization). So let's hope that avs4x26x is still maintained and can be improved shortly. "Der Techniker ist informiert." In the hope that 06_taro still exists. |
8th May 2018, 12:46 | #6053 | Link | |
German anime is another matter though:https://youtu.be/JEBBvIsBAEs Hmmm 06_taro's last forum activity is 28th April 2018 05:56, so he may still be alive. Last edited by Gser; 8th May 2018 at 13:30. |
8th May 2018, 21:11 | #6054 | Link | |
No, it should save that. Let me check. |
10th May 2018, 08:04 | #6057 | Link |
@Zathor, thank you for regular updates to MeGUI. I wanted to mention two observations:
1- Recently a confirmation has been added to the updater in MeGUI that for every single package that needs to be updated, it generates a message that the package is not available offline and asks the user if they want to download it from the internet. To be honest, I don't see why this confirmation is even required, especially for every single package. This forces the user to keep MeGUI on top throughout the update process and confirm the update of every single package manually. An option to disable this confirmation would be very much appreciated. 2- Extracting packages during update seems to be much slower than it should be on all of my machines. Extracting packages takes 10-15 seconds despite their small size, while extracting the same files directly using 7-zip takes less than a second. Correct me if I am wrong but it seems to me that there is a minimum "animation time" for the bar that shows the extraction progress and even if the package is extracted before the bar finishes, the process does not exit before the animation reaches the end. Or maybe there is regular synchronization between the extraction process and the animation process, resulting in sub-optimal performance. Right now, on my machine, extracting the updates takes 5 times longer than downloading them. Last edited by THEAST; 10th May 2018 at 10:22. |
10th May 2018, 13:27 | #6059 | Link | |
Actually, the GUI is a little naughty when --no-psy is checked. Ideally that should disable the PSY strength options rather than let you configure them as I'm pretty sure x264 ignores them. It doesn't write them to the output stream when psy=0 (--no-psy). |
10th May 2018, 13:47 | #6060 | Link | ||
