23rd February 2015, 20:04 | #4361 | Link | |
Apparently the XP switch was on in the 768 version. Any chance a new release can be made, this time with the XP switch on? How soon? Thank you so much! |
23rd February 2015, 20:12 | #4362 | Link | |
4th March 2015, 07:51 | #4363 | Link |
Useless idea generator
Stable MeGUI 2507 sometime holds open d2v/m2v files of previously processed demuxed TS/MPEG2 DVB-T recordings.
They stay open, blocked against deletion, even if succeeded in the queue by several next AVS preparations and video encodings. There is no obvious reason why the files stay blocked but they sometimes do. Only thing that helps is MeGUI restart. It seems to happen more frequently ( not confirmed if exclusively ), if video encoding job is aborted by a user, for whatever reason. Perhaps sanity check and release of open file handlers is not done properly. Or, can it be fault of the Avisynth ? I use quite older MT 2.6.0.3 from Aug 28, 2012. Edit:Note that there is no hanging avs4x264mod process in such cases Edit2: Note that System Explorer is reporting these open files Currently processed M2V opened by avs2x264mod Currently processed M2V opened by x264_64 Blocked M2V opened by avs2x264mod Blocked M2V opened by x264_64 Blocked M2V opened by MeGUI Note that there is just 1 instance of avs2x264mod and x264_64.
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 / focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC] Last edited by Poutnik; 4th March 2015 at 08:12. Reason: Additional comment |
4th March 2015, 13:13 | #4364 | Link |
Poutnik,
I've sometimes wondered why a file is locked by x264 after opening it with MeGUI and/or creating a script even though it hasn't been encoded (I'm pretty sure). It's happened for quite a while for me (not just the latest version of MeGUI) but not regularly. Just now and then. And of course when I opened some files just now to test it..... I couldn't get MeGUI to lock a file at all. The folder containing the source file yes, but nothing else. Not even the script it was using for encoding. Anyway, because restarting a program to unlock a file isn't always convenient (and sometimes it even requires a reboot), one of the first utilities I install after a fresh Windows installation is Unlocker. (I think the installer includes some OpenCandy type annoyance, but you can choose not to install whatever it's offering) |
4th March 2015, 17:02 | #4366 | Link | |
But there is no video preview open, and there was no activity done over the file for long time. The procedure AVS cutting - Script generation - Autoencode was done since then for several other videos, and their D2v/m2v files were able to be deleted. Perhaps, there could be difference, if the preview is manually closed before launching other preview. I will test.
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 / focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC] |
15th March 2015, 20:50 | #4367 | Link | |
Version r783 doesn't work on XP either. I haven't tested r775 myself. r768 definitely does run on XP. |
16th March 2015, 11:23 | #4369 | Link | |
I've not had a reason to upgrade when after doing so, re-installing software and sorting out problems, best case scenario would generally be for everything to work as it did before. It's slowly happening now..... XP not being supported by newer software..... so I guess eventually that'll necessitate upgrading to a version of Windows more annoying than XP, and if I build a new PC as I've been planning to I won't have a choice there, but I like the idea of going straight from XP to Windows 10. Assuming it doesn't suck. |
29th March 2015, 11:39 | #4371 | Link |
Swallowed in the Sea
@Zathor : where msvcr100.dll/msvcr120.dll come from ? why they are still required for x265 ?...as soon as I removed them, they are uploaded. That should not be...
@LigH : MeGUI uses your x265 builds...ok but why they are dynamically compiled and not statically ? |
29th March 2015, 13:28 | #4372 | Link | |
The runtime libraries will be copied to the encoder folders in specific cases. E.g. from AviSynth+ directory when this will be used. Or from lsmash directory when AviSynth+ is not used. Both are compiled dynamically and when the runtimes are not copied (or installed in the system) the encoder will fail. core\util\fileutil.cs:538 and 609 |
29th March 2015, 15:02 | #4375 | Link |
@ Kurtnoise (+ Zathor):
All I do is:
I have no experience with C compilers, I am helpless when the build process gets stuck. I would not know how to edit such a script to get more or less dependencies to any Windows DLLs. According to Dependency Walker, the x265 EXEs created by these build scripts only have dependencies to KERNEL32.DLL and MSVCRT.DLL; the EXE is no stub using libx265.dll though: these DLLs are additional, standalone libraries for developers preferring the DLL over the CLI EXE in their own applications. You should not add them in your MeGUI package because you will probably not need them. |
29th March 2015, 16:31 | #4379 | Link |
Not sure if desired: Even though using FDKAAC was not yet enabled in the options of external applications, the updater still insisted in updating it unless I would probably manually disable this package. But I couldn't say whether I would recommend any relation between the updater package enabled and the external programs option enabled.
