2nd May 2010, 10:53 | #12741 | Link |
Yes ,they fixed it!
http://mpc-hc.svn.sourceforge.net/vi...c-hc/?view=log """""" Revision 1825 - Directory Listing Modified Sat May 1 18:59:00 2010 UTC (14 hours, 53 minutes ago) by kinddragon Problem with auto-loading subtitles fixed This commit fixes ticket #456 """""" |
3rd May 2010, 00:03 | #12744 | Link | |
Thank you very much indeed. |
3rd May 2010, 01:46 | #12745 | Link |
MPC-BE DEV
Media Player Classic HomeCinema (x86/x64), svn 1834
Supported languages: BR, BY, CN, CZ, DE, EN, ES, FR, HU, IT, KR, PL, RU, SE, SK, TR, UA Changes (1830-1834):
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
3rd May 2010, 01:59 | #12746 | Link |
On my laptop, it has an Intel X3100 graphics adaptor. It doesn't support DXVA acceleration of AVC, but I just wanted to try the mpc-hc.ini I have on my main laptop.
Setup: Windows 7 64-bit MPC-HC 1775 32-bit EVR-Custom Presenter Auto-load subtitles Microsoft DTV-DVD Video decoder http://img405.imageshack.us/img405/3394/84845244.jpg What is of note is that the DXVA line says: "MPEG-2 variable-length decoder" with "Playing [DXVA]" also displaying. I assure you the file is AVC/H.264 and it is also in the screenshot. What is happening here? |
3rd May 2010, 02:21 | #12747 | Link |
契約者
Microsoft DTV-DVD Video decoder supports partial acceleration so "Playing [DXVA]" is probably right. It is possible that your graphics adapter can do that.
As for "MPEG-2 variable-length decoder" - have no idea. Maybe some bug... Someone else probably can comment on that. Last edited by Keiyakusha; 3rd May 2010 at 02:23. |
3rd May 2010, 23:01 | #12749 | Link |
I guess since updating to a newer graphics driver DXVA playback produces artifacts. Using the non-DXVA internal filters the video is fine. It looks like this:
System OS is Windows 7 x64, MPC-HC build 1.3.1249.0, graphics card is an AMD Radeon 4870, graphics driver version is 10.4. Output settings is EVR+custom. PS: Just checked and used ffdshow for decoding with hardware acceleration enabled. Same artifacts. So it's a driver issue. Probably not MPC-HC's fault. PS2: reverted back to driver version 10.3. artifacts gone. Aaah. btw, right now seeking with ffdshow+hw shows the same artifacts for a split second. so the bug in 10.4 seems to be that the driver is ignoring I-frames or so constantly... Last edited by Booji Boy; 3rd May 2010 at 23:26. |
4th May 2010, 02:53 | #12752 | Link |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
4th May 2010, 06:23 | #12754 | Link | |
It seems that you see something that others do not.
4th May 2010, 08:16 | #12755 | Link |
The internal x264 decoder must be buggy or something, cause I get lots of broken "squares" on the screen (not all time time, but every few seconds. Sorry I cannot find better words to describe it When I unchecked H264 DXVA in options and let FFDShow handle it, it was all good.
4th May 2010, 08:56 | #12756 | Link |
Octo-puss" What is your GPU, what version of windows and what graphics drivers?
You know, they say an image is worth a thousand words. Post up a link to a screenshot on imageshack.us or other. Last edited by namaiki; 4th May 2010 at 08:59. |
4th May 2010, 09:47 | #12757 | Link | |
4th May 2010, 11:52 | #12760 | Link | |
It's the graphics card driver, revert to 10.3. DXVA is broken in the driver, no matter what decoder you use. You obviously have hardware acceleration disabled in ffdshow. |
