3rd December 2007, 14:16 | #861 | Link | |
I AM AT A CYBER CAFE & WAITING FOR HELP, ASAP, READ ON !
Can you provide a full working syntax sample for 6 mono wav's to 5.1 ac3 with EX mode enabled please, because I have created a working GUI called Aften Mono GUI. But I cant seem to workout the syntax for 6 mono wav's to 5.1 ac3. PLEASE HELP AS SOON AS POSSIBLE !!!!!!!! BELOW IS MY GUI SCREENSHOTS (I SWEAR & PROMISE IF YOU GUYS CAN HELP ME AS SOON AS POSSIBLE on THE SYNTAX SAMPLE, I WILL SHARE THE GUI Named Aften Mono GUI WHITH EVERYONE ON THIS PLANET EARTH !) Stereo AC3 5.1ch AC3 6.1 AC3 Last edited by xbox360; 3rd December 2007 at 14:22. |
3rd December 2007, 15:53 | #862 | Link | |
aften -xbsi2 1 -dsurexmod 2 -ch_fl e:\FL.wav -ch_fr e:\FR.wav -ch_fc e:\C.wav -ch_lfe e:\LFE.wav -ch_sl e:\BL.wav -ch_sr e:\BR.wav e:\outEX.ac3 |
4th December 2007, 01:48 | #863 | Link | |
aften -xbsi2 1 -dsurexmod 2 -ch_fl D:\EncodingStuff\Audio Stuff\New Folder\audi_0.wav -ch_fc D:\EncodingStuff\Audio Stuff\New Folder\audi_2.wav -ch_fr D:\EncodingStuff\Audio Stuff\New Folder\audi_1.wav -ch_sl D:\EncodingStuff\Audio Stuff\New Folder\audi_4.wav -ch_sr D:\EncodingStuff\Audio Stuff\New Folder\audi_5.wav -ch_lfe D:\EncodingStuff\Audio Stuff\New Folder\audi_3.wav D:\EncodingStuff\Audio Stuff\dds.ac3 cannot mix single-input syntax and multi-input syntax |
4th December 2007, 05:41 | #864 | Link | |
I bet using this would work fine: Code:
aften -xbsi2 1 -dsurexmod 2 -ch_fl "D:\EncodingStuff\Audio Stuff\New Folder\audi_0.wav" -ch_fc "D:\EncodingStuff\Audio Stuff\New Folder\audi_2.wav" -ch_fr "D:\EncodingStuff\Audio Stuff\New Folder\audi_1.wav" -ch_sl "D:\EncodingStuff\Audio Stuff\New Folder\audi_4.wav" -ch_sr "D:\EncodingStuff\Audio Stuff\New Folder\audi_5.wav" -ch_lfe "D:\EncodingStuff\Audio Stuff\New Folder\audi_3.wav" "D:\EncodingStuff\Audio Stuff\dds.ac3"
Chumbo |
4th December 2007, 11:49 | #865 | Link | |
Thx for this abriviated explination, i understand it better now. And coming back to my original posting; I understand where these rules-of-thumb came from, it is based on the amount of info you feed the encoder related to the final bitrate. (feed the encoder less info/less audio-detail for a lower bitrate by adapting the bitrate of the original PCM). Last edited by G_M_C; 6th December 2007 at 16:29. |
6th December 2007, 20:27 | #866 | Link |
I get an error when using the multi-mono input;
I've used EAC3To to demux a DTS track into separate WAV's. Then i try to input those with the following commandline; Code:
aften.exe -threads 2 -b 4 -dynrng 1 -ch_fl "d:\howl.L.wav" -ch_fc "d:\howl.C.wav" -ch_fr "d:\howl.R.wav" -ch_sl "d:\howl.SL.wav" -ch_sr "d:\howl.SR.wav" -ch_lfe "d:\howl.LFE.wav" "D:\Howl_384[PAL].AC3" Code:
Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: WAVE Signed 24-bit little-endian 48000 Hz mono WAVE Signed 24-bit little-endian 48000 Hz mono WAVE Signed 24-bit little-endian 48000 Hz mono WAVE Signed 24-bit little-endian 48000 Hz mono WAVE Signed 24-bit little-endian 48000 Hz mono WAVE Signed 24-bit little-endian 48000 Hz mono output format: 48000 Hz 3/2 + LFE invalid bitrate error initializing encoder Then i got this error; Code:
Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. all files must be mono when using multiple input files invalid input file(s) What have I done wrong |
6th December 2007, 21:00 | #867 | Link |
Just wondering: If you're already using eac3to, why don't you let eac3to do the Aften encoding for you? If you want to use the latest Aften build, you can replace the "libaften.dll" that ships with eac3to with the latest version.
6th December 2007, 22:12 | #869 | Link |
As i understand from the long help; -b 4 means: Encode @ 384 kbps.
And why i want to use aften is that i want to verify EAC3To does the transcoding correctly; DVDLab reports an average of 383 kpbs (and not 384), and i'm under the impression that the surround mix levels are off with EAC3To (too loud, no -3 db applied i think, especially noticable when the DVD is played on a system where a downmix to stereo is needed: The center-channel/voices get mixed to faint and get " lost "). And as i said; I want to verify that by using aften directly. |
6th December 2007, 22:58 | #870 | Link | |
7th December 2007, 00:25 | #872 | Link | |
WAV to AC3 Encoder version 1.1 is avaibale for download.
Changes: Quote:
Thanks, wisodev
https://github.com/wieslawsoltes/wavtoac3encoder https://github.com/wieslawsoltes/BatchEncoder https://github.com/wieslawsoltes/SimpleWavSplitter Last edited by wisodev; 7th December 2007 at 00:29. |
7th December 2007, 00:58 | #875 | Link |
I'll change the text to be a little more obvious, but if you read a little more closely you'll see that those are the defaults for different numbers of channels. If your source is 4 channels, the default bitrate will be 384 kbps.
7th December 2007, 01:12 | #876 | Link | |
That said, I went ahead and changed the default number of channels for raw input to 1 instead of 2. I had been meaning to do this ever since raw input was enabled, but I just forgot about it. |
7th December 2007, 09:57 | #878 | Link |
I'm from Holland, so English isnt my native language. It is very much possible I havent understood the help the right way. A "more obvious" description could help out
